mini-tubbing to tuck 335 tire?
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
Has anybody minitubbed a thirdgen? I am planning on mini-tubbing the rear of my 87 to fit a 335/30/zr18 tire and want to know what is the best way of going about it. I want to use a 4-link and don't mind cutting into the floor pan as I currently run a 10-point cage and don't have rear seats anyway! I don't want to have to completly back have it with custom frame rails. I want to know if I can get away with installing the crossmember for the 4-link, notching the floor to provide clearence and cutting out the factory wheel wells and fabricating larger ones to tuck the rear wheels? Anybody done it or have any opinions about it?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: mini-tubbing to tuck 335 tire?
https://www.thirdgen.org/forums/fabr...f-project.html
if you are going to use a 4 link setup, you are probably going to have to backhalf the car.
Wolfe Race Craft sells a mini tub kit for 4th gen cars, it would be a real close fit in a third gen, the rest of the suspension mods are on you
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
I have read his thread on his back-half project, but I was looking to do something slightly more "stock" appearing. As I said befor, I don't mind cutting into the floor to install the 4-link, but I wanted to try and stay away from having to use custom framerails like the one's in his thread. I have done back halves before, just nothing without using the fabricated fram rails.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Take the tires off and look inside the wheel well. Except for the raised area around the spring pocket which can be cut out and plated over to allow a little more room, what you see as the inner fender is also the frame rail. You can't go inwards any more than that. The best you can do is to modify the front of the inner fender so it's more square than rounded to allow a taller, wider tire.
The space between the inner and outer fender is all the room you have to work with unless you do a complete back half and install new frame rails.
You're not going to get a 4-link under the factory floor.
This is the best you can to to install bigger tires.
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
A "mini tub" is moving the inner fender towards the factory frame rails to allow wider tires. On a unibody car such as a third gen, there is no such thing.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Few diff ways you could go. Stock frame rails in this one.. Well they were not anymore as you can see..
http://www.cecoatings.com/images/oth...3TUBBED3rdgen/
And what I did before my car got totalled.
I just cut the bump stops out
http://www.cecoatings.com/images/Car...2Z/MiniTubbes/
This was a 28x11.5x15
http://www.cecoatings.com/images/Car...s/DSC01192.JPG
http://www.cecoatings.com/images/Car...s/DSC01195.JPG
I dont know if a 335 would fit w/o going into the frame rail a little (notching it)
That cas has been replaced and im doing another mini tub now.
Coil over 9inch, etc..
http://www.cecoatings.com/images/Car...r/DSC03644.JPG
http://www.cecoatings.com/images/Car...d/DSC03646.JPG
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
Well, I guess what I'm going to do then is custom fab new boxed rear frame rails that are moved inboard to give the clearence I need. I will mount a upper crossmember for the new shock mounts and tie in a lower crossmember between the subframe connectors to provide a mount for the 4-link. I will then build a new floor/trunk pan with notches to clear the 4-link, and to clear the rear shock mounts. I think I will build new wheel wells close to the factory shape that will be just deep enough to run a 335 tire. The tire height won't be an issue as the od is only 26", so it just be a matter of making the wells deeper. I am going to try to make it as clean an install as possible as I do want it to look like it should have came from the factory that way. Then I need to try and figure out how to cover it all with the factory interior panels. I am going to start on this project in about a week. I will take pics every step of the way and keep you all updated! Are there any flaws or issues I'm going to run into that you jump out at you guys?
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
How wide of rear tires are those car's running? I love the stance of that white car. And the pic in the middle looks as clean as ever, exactly what I'm shooting for! Do you know what size of tires those guys are running?
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
lol, I agree! Obviously orginization is not his strong point!
1 Post
Car: 92 Z28
Engine: Boosted LSX
not sure on tire size on the white car.
Its actually clean now. You should have seen it before.
http://www.cecoatings.com/images/Car.../2Projects.jpg
Thank god I have a shop to really work out of. (my old TA)
http://www.cecoatings.com/images/Car...A/DSC01986.JPG
http://www.cecoatings.com/images/Car...A/DSC01989.JPG
I'll get ya some pic's of how Im notching and plating the stock rails on the red car soon.
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
By far the best I have found to date...
http://www.lateral-g.net/forums/showthread.php4?t=5519
Jason
Jason
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
Wow, that car is absolutly beautiful! But, not trying to be critical, those don't look like 345 tires? I've seen lot's of pics of car with 335's (not third gen's mind you) and they are way wider than that.
1 Post
Car: 92 Z28
Engine: Boosted LSX
Jason
Jason
lateral-g and http://www.pro-touring.com/forum
That is by far the nicest thirdgen i have ever seen and exactly what i want to build. A car with big 18inch wheels that are WIDE and yet a clean look to it. And twin turbo'd with HUGE hp numbers. The whole car is complete. That car is amazing.
Car: 1987 Camaro
Engine: 383ci
Transmission: th350
Ok, I just looked at the WHOLE thread! Ya those tires he's puting on are definitly 345's! That car is sick!
Car: '91 Camaro RS
Never. It's clean for the little space that it is. Come on over and get this wreck out of the garage and I'd have all kinds of clean space.
Car: 87 GTA
Jason
Jason
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I think my heart skipped a few beats after looking at that Nelson Beast.
Car: 91' Camaro
Engine: 383 ci
P.S. how are things Stephen? I have not seen you on this forum in probably 7 years or so... Glad you are still here! Remember TC ? What ever happened to him? He had the white RS that he did a 350 swap in years ago...
Jason Aschle
1 Post
Car: 92 Z28
Engine: Boosted LSX
http://www.cecoatings.com/images/oth...urbo%20camaro/
Car: 87 GTA
He is a member of this site too. I beleive his board name is 84camaros , he may send pics to you or post them up if PM'd...
Jason Aschle
Jason Aschle
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
