Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
aluminum diamond plate ideas
Old Nov 29, 2007 | 10:14 PM
Thestriped1's Avatar
Car: 89 2.8 RS
Engine: the 2.8
Transmission: 700r4 auto
Axle/Gears: stock one wheel squealer
so ive made a guage bezel out of sheet aluminum and im thinking of making one out of diamond plate my dad is grabbing me from work.... ialso want to create a center console peice to replace that plastic. i figured i could install the exhaust cutout switch into it looking much better trhan on the black cuz they switch is a row of three fighter style with a aluminum base that i got from pep boys
as i go through it ill post pics again
Old Nov 29, 2007 | 11:05 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: aluminum diamond plate ideas
Diamond plate pedals are sick too
Old Nov 30, 2007 | 01:25 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
i did a radiator mount for the top piece out of diamond plate......its easy to work with but very expensive
Old Nov 30, 2007 | 01:55 AM
travishenry's Avatar
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
that would be sweet. Ill buy one lol
Old Nov 30, 2007 | 08:55 AM
emory 4-4-2's Avatar
for some things yes, i dig the plate. pedals, engine parts...
Old Nov 30, 2007 | 02:00 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I tried making replacement panels for my gauges, hvac/radio, and center console out of aluminum diamond plate and I haven't liked the look of any of them. I'm not sure what it was, but it just didn't look right. Maybe it was because I was trying to use the factory gauges? I don't have the $$ right now to replace them, just thought I could dress them up a bit. I still have the pieces I made somewhere, I'll have to grab some pics tonight and post them up.
The other problem I ran into with them is that since the diamond plate is diamond plate, the gauges/radio/hvac controls don't sit flush with the front of the panel and I didn't like the way that looked.
I did make some pedals out of diamond plate that turned out great, pic attached below. Sorry for the low quality, it was taken with my cell phone.
I did see on here someone made some replacement door panels out of diamond plate that looked great. I can't remember who it was though. I was thinking of doing that at some point.
I'll be following along though, I want to see how yours turns out. Hopefully it looks a lot better than mine did.
Old Nov 30, 2007 | 04:40 PM
Car: 89 2.8 RS
Engine: the 2.8
well price isnt an issue at all... im not rich but my dad is getting it for me and its because hes working with 1/4 inch thick 4 by 8 sheets of aluminum diamond plate at his job. The job ordered way to much so my dad said hed bring me home some pieces cuz hes done with it on the job and they still have a foot high stack of it. I've seen the door panels toon and they did look great as for your pedals they arent bad i think you just picked bad spots to cut out off when you made them you really need to consider where the diamonds will be so im going to take a picture when i get the stuff and photo shop it to figure out where i want to cut so i can see the potential piece in the shape of the pedal. i was thinking abaout doing more with it too but not too much more. My radiator support is cracked from an accident so that a great i dea to replace it and i was thinking since its aluminum and it doesnt conduct heat well i can use it as a heat sheild for my starter and make a battery box out of it. theres alos the panels under the dash that cover the access from below that i didnt get with the car when i bought it and i want to make a trauck liner out of it because i throw my tools in it all the time.
Its also a good excuse to get and learn to use a welder.
Well i can get alot of it and my dad said since there is so much and the compnaies are so massive that its pocket change to them he can see about bringing the truck one day and taking 3-5 sheets of it that would be perfect cuz if i mess up then who cares
92 try polishing your pedals up with a buffer and some mother billet aluminum polish. it works amazingly and i think you'll like the pedals a lot more
Last edited by Thestriped1; Nov 30, 2007 at 04:42 PM. Reason: Automerged Doublepost
Old Nov 30, 2007 | 06:08 PM
Mathius's Avatar
Someone made a diamond plate console for their Camaro and posted pictures here... was like a few years ago maybe. Do a search.
It looked awful, and it had nothing to do with craftsmanship. Its just a really bad idea.
Mathius
Old Nov 30, 2007 | 06:11 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
yeah diamond plate doesnt look right on the interior of a car..........in my opinion it does look good under the hood along with all its other aluminium friends......heads, valve covers, timing covers, intakes, air cleaner covers, etc
Old Nov 30, 2007 | 06:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Stuff like pedals isn't bad. If you want to do the dash or anything in the interior, you can do it very cheaply with decal material available at Walmart. The dash in my race car was made with sheet aluminum and a circular prism decal sheet over it.
Old Nov 30, 2007 | 11:07 PM
Car: 89 2.8 RS
Engine: the 2.8
yea im just throwing out ideas cuz im bored and it'll stop me from spending money that i dont have to be spending plus the diamond plate is free so if i dont like it i bring it to a scrap yard or sell it on here and make a few dollars
Old Nov 30, 2007 | 11:37 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
free always helps.......i just think its too flashy for interior.....fine if you like that ghetto cruiser look
Old Dec 1, 2007 | 12:44 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I got some pics of the dash and console. I never really completed them as I'm still deciding on whether or not to use them, so they are still just a little rough, but its enough to get a good idea of how it would look. This was originally a little side project, there is so much other work that needs done on the car(like welding the front clip on) that the aluminum plate is kind of on the back burner right now.
I should have paid more attention to how the diamond pattern ran vs. the shape I was trying to cut out but I was limited in my placement as I didn't have very large pieces to work with. Just some scraps I got from my brother(he tried removing the back seats in his Eclipse and making a new floor from diamond plate). They had partial cuts in them, and holes drilled in random places, and it looked like he tried sticking some kind of foam tape on in places for some reason.
Striped - I did use some aluminum polish on them, but I don't have a buffer, so I tried it by hand and wasn't that impressed with the results. My brother has one so I'm gonna try and get my hands on it next time I see him.
Attached Thumbnails aluminum diamond plate ideas-1201071328-00.jpg   aluminum diamond plate ideas-1201071329-02.jpg   aluminum diamond plate ideas-1201071330-00.jpg
Old Dec 2, 2007 | 03:45 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Thanks for sharing and for your work but I am just not feeling it brother. Like stated earlier it just doesn't look right in the interior.
Old Dec 2, 2007 | 06:18 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
All that matters is if you like it..
I like the pedals though I want to make some of those
Old Dec 2, 2007 | 09:31 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I did my center console plates in aluminum, then polished it. Ill try and get some pics sometime. Was a pain though cause I had to get it cut out on a CNC.
Old Dec 6, 2007 | 08:02 AM
Stephen's Avatar
Car: 87 GTA
Good for 4x4s, not our cars.
I made a radio plate for my lifted Jeep, still have the plate, not the Jeep.
Old Dec 6, 2007 | 10:16 PM
Car: 89 2.8 RS
Engine: the 2.8
im gonna use a dremel to cut it most likely. It is only aluminum rather than stainless steel so it shouldnt be too bad even if it is 1/4". I found out the that it costs 340 per 4' x 8' sheet of this stuff and im definately stoked not to be paying for that. my main thing i want to do with the stuff is really make a removable trunk liner to protect the carpet and some of the plastic from my tools being tossed in and out of it. With it welded too i can also through oil and stuff into it with no worries
Old Dec 6, 2007 | 11:28 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
WOW i really like the center consoul. good job.
Old Dec 7, 2007 | 11:30 AM
my dad made a new floor for an old work truck with aluminum diamond plate. stuff would dig into the soft metal when tossed into the bed and not move. could be good or bad. but then, i'm sure you're not using your thid gen for an a/c service vehicle.
Old Dec 7, 2007 | 08:40 PM
DillonRager's Avatar
i was the one who made the door panels out od diamond plate. my dad got it from work free too. i got a new computer so i dont have any pics. youll have to search "diamond plate" it looked pretty good but it was too much so i covered them. still got them in the car. ill probably have them forever . they wont wear out im going to get them covered professionally though.
found it https://www.thirdgen.org/forums/inte...t=#post3184689
Old Dec 8, 2007 | 02:11 PM
Car: 89 2.8 RS
Engine: the 2.8
it does look god but i think the door panels are too much for me. after a short time i feel like i would get annoying with them. plus my dad want to try to get one or two full sheets to do some stuff in the boat and to fab something up for the bronco in the back cuz the carpet is rank and the diamond plate would look badass with the top off the bronco.
midge54
Dec 27, 2019 04:14 PM
Fronzizzle
Mar 18, 2019 08:29 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
