Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fiberglass firewall
Old Dec 6, 2007 | 11:23 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
fiberglass firewall
i was just wondering if anyone has tried to fiberglass their firewall. i started mine a few days ago. i will be posting progress pics in the next day or two.
Old Dec 7, 2007 | 06:16 PM
Mathius's Avatar
Re: fiberglass firewall
This is probably going to end up being a really bad idea. You should always try to bond similar materials. I.e. metal for metal, fiberglass for fiberglass. At some point your fiberglass is going to crack from the vibration in the metal, if it doesn't just fall right off, because you're basically just gluing it to the metal. There isn't any real bonding going on except the fiberglass resin.
I'm guessing your intent is to smooth the firewall? If you can't weld, I would try to get some stainless, or aluminum, and just make some nice polished covers. Cut them out, get some nice stainless screws to install it, or even stainless rivets.
Mathius
Old Dec 7, 2007 | 06:45 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
i did weld in sheet metal where the blower motor and heater core were. i also filed in where all of the extra holes were except one for my wires.
Old Dec 7, 2007 | 06:52 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
http://F:\DCIM\101HP960\HPIM1400.JPG
http://F:\DCIM\101HP960\HPIM1401.JPG
http://F:\DCIM\101HP960\HPIM1392.JPG
here are som progress pics
nevermind, those links dont work
Old Dec 7, 2007 | 07:16 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
photos dont seem to work.
are you replacing your firewall??? like taking it out and putting in fiberglass or just covering it up???
Old Dec 7, 2007 | 09:45 PM
Mathius's Avatar
Well so then what is the fiberglass for?
Mathius
Old Dec 7, 2007 | 10:56 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
to make it all look smooth
Old Dec 7, 2007 | 11:02 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
just covered it up to make it smooth
Old Dec 8, 2007 | 05:16 PM
Mathius's Avatar
Again, I think you're going to have issues with cracking, etc. possibly with the fiberglass falling off altogether depending on how much and where you applied it.
The right thing to do would have been to weld it, grind your welds smooth, and then if necessary apply a small amount of body filler to smooth it out.
Mathius
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
