Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
need something like this
Old Nov 30, 2007 | 01:22 AM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
Need something like this made.
Old Nov 30, 2007 | 01:56 AM
travishenry's Avatar
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
Re: need something like this
like what
Old Dec 1, 2007 | 02:17 AM
OS3Fleming's Avatar
Engine: 357 SBC
I cant get it to take the pic on the site. Ummmm. You know the Ashtray up front. I wanted to make that a plate for the Window switches and an extra Cig outlet on the driverside for my IPOD.
Old Dec 1, 2007 | 02:24 AM
Engine: TPI 350
Transmission: TH350
That would be a good idea. What would you charge to make somthin like that. I dont need the ash tray for nething.
Last edited by travishenry; Dec 1, 2007 at 02:28 AM. Reason: Automerged Doublepost
Old Dec 1, 2007 | 09:48 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
You have PM!
Old Dec 5, 2007 | 11:36 PM
OS3Fleming's Avatar
Engine: 357 SBC
Old Dec 6, 2007 | 02:38 PM
85_ZED28's Avatar
Car: '85 Z28
If you can't get the picture posted, you can email it to me and I'll post it for ya:
colin911@gmail.com
Old Dec 7, 2007 | 01:02 AM
OS3Fleming's Avatar
Engine: 357 SBC
Old Dec 7, 2007 | 06:40 AM
85_ZED28's Avatar
Car: '85 Z28
Here's the pic, do you have any bigger pics? Its pretty hard to see:
Old Dec 10, 2007 | 03:30 PM
OS3Fleming's Avatar
Engine: 357 SBC
I will try to get it to be bigger.
Old Dec 16, 2007 | 07:17 PM
Stephen's Avatar
Car: 87 GTA
I couldn't tell what the buttons/switches were for...
Old Dec 17, 2007 | 12:33 AM
OS3Fleming's Avatar
Engine: 357 SBC
Today I will be doing alot of work on the car being my day off. Project will include but not limited to:
New Dist
Valve lash Adjustement-shop lied about doing it and now that I am in KS It sounds Like I have exshuast in the Carb. Took carb off and there was carbon on the intake walls.
High Speed Blower Relay
Fast Idle Relay
Now for that panel. I have some 1/8 in plexie glass I will be using. I am going to print of the template for the Cup holder thing and modify that to take the window switchs and an out let for my Ipod. I am thinking of doing two layers of plexie and having label paper in the middle. So I can put the up and down lable in it. Then frost the bottom layer and paint the top layer with under carage paint. And for the last bit is to but a blue bulb under the new panel to light up the labels. Sound easy but will take pics of the thing. I am converting the crank windows to electric and didn't like the factory locations of the switches.
Old Dec 22, 2007 | 02:52 AM
OS3Fleming's Avatar
Engine: 357 SBC
Heres what I got complete this last Monday - Wensday, cause Iam stupid. Got good hatch struts on, put a new dist on, Valve adjustment ( this where I am stupid.) Crossed the wires for the dist while putting the valve covers back on. Car would not run so I could not finish the drivers side valve lash. So the next day I sat and looked at it and found the problem. Thats what I get for working on it all day and not planning right. Then I fixed the vent issue. I found that the hose of the intake manifold was pluged to what looked like the MAP but it really was the BAP. So I placed the hose on the A/C tank and it worked.
Tomorrow I will be trying to knock out the panel. I will take some pictures to put on here.
Old Dec 22, 2007 | 12:57 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
search for jimmy jams?
there is a site that makes those plates you are referring to.
Old Dec 23, 2007 | 02:13 AM
OS3Fleming's Avatar
Engine: 357 SBC
I am not putting in NO2 switches. I am putting in window switches cause I don't like the stock location. I hope to start tomorrow when I get up. I work nights so I sleep during the day.
Old Dec 27, 2007 | 01:03 AM
OS3Fleming's Avatar
Engine: 357 SBC
Alright this is where I stand. My cut out was terrible and so tomorrow I will be going to a fab shop to get it done. i will be ordering a pass side motor and regulator with switch soon to be fully power windows. HAHAHA..... Will take pics when all complete.
Old Dec 27, 2007 | 10:21 PM
OS3Fleming's Avatar
Engine: 357 SBC
Tomorrow I will be getting my panel. $35 total. Its going to be nice. Now I just need to wire the new outlet to a power source. Does any one know a good way to do this.
Also Will be hiding a kill switch in the center console hidden under the carpet. Hopefully I can find it if I was to forget.
Last edited by OS3Fleming; Dec 27, 2007 at 10:24 PM. Reason: Automerged Doublepost
Old Dec 29, 2007 | 01:20 AM
OS3Fleming's Avatar
Engine: 357 SBC
GOT IT DONE TODAY!!!! It is awsome alittle gap but I can fix it with some putty. You can see it here and the pos that I am trying to get back together. https://www.thirdgen.org/forums/vbga...ber-63433.html
Old Dec 29, 2007 | 09:46 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Originally Posted by OS3Fleming
alittle gap but I can fix it with some putty.[/URL]
did they make the plate to your specifications, or is it the wrong size?
last thing i would do is fill a gap with putty if i had a custom part made.
its going to take away from it, IMO.
Old Dec 30, 2007 | 01:07 AM
OS3Fleming's Avatar
Engine: 357 SBC
I took the ash tray part of the console out and took it to them. But I also took the the measurements from the Cup holder 101 to them as well. As far as putty I mean the magnum steal. I will be taking the shifter panel off to rejoin the two. I still have to finish the part "painting it". The gap is between the shifter plate and ash tray. I cut it in two to take it to them. Thats why there was a gap.
Old Dec 30, 2007 | 01:01 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
you must have used a 1/2 thick saw blade by the pics.
how large is the gap.
it may look decent after painting.
Old Dec 31, 2007 | 04:26 AM
OS3Fleming's Avatar
Engine: 357 SBC
The Gaps not very wide. It will be easy to fix. I will put up better pics today As I will be trying to cure that 3rd gen bog.
