Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
basic weldin question
Old Feb 16, 2008 | 11:36 PM
jake wagoner's Avatar
i have a chrome exhaust tip i would like to attach to an aluminum muffler. since i cant attach any clamps to the tip i would weld it but i only have an arc welder and that wont do the job. i was wondering if i brazed them together would it hold? i would just do it and find out for myself but i would hate to loose the tip even though it was free
Old Feb 16, 2008 | 11:46 PM
billyhoss's Avatar
Re: basic weldin question
you can not weld steel to aluminum, it will just not hold, are you sure its an alum muffler and not stainless steel?
Old Feb 17, 2008 | 12:10 AM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
The muffler is most likely aluminized not solid aluminum. Dont try brazing. Your arc welder would be better than that.
Almost all aftermarket mufflers / tubing are aluminized steel. It's like a thin coating, kinda like galvanized except different. A mig welder will weld it just like any other steel.
For this particular case, just go to an exhaust shop. They have good welders, and experience. Shouldnt be more than $10 -$20 to get 1 tip welded on.
Old Feb 17, 2008 | 12:53 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i had a muffler welded on, just around the pipes where they slip joint, so i could take the clamps off and the kid didnt charge me at all for it! Meineke muffler
Old Feb 17, 2008 | 02:49 AM
thanks for the help. i guess i will just have to find somebody to do it for me then
Old Feb 17, 2008 | 07:23 AM
AC's Avatar
AC
Car: Used to drive a camaro
All good advice on going to the muffler shops for this quick easy stuff. Alot of shops do the real quick things for free. Menieke here welded on an O2 sensor bung for me for free on an exhaust extension.
Old Feb 18, 2008 | 01:53 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
my friend paid $70 because the weld just behind his muffler and it fell off but I'm in Massachusetts so everything is more expensive than it should be
92GTA
Apr 9, 2016 07:39 AM
ezobens
Aug 19, 2015 10:29 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
