Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Relocating fuel lines
Old Mar 6, 2008 | 01:29 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I am going to relocate my fuel lines this summer to clean up under the hood. I am going to cut them in the tunnel and run braided line up to the feed line and regulator. Has anyone else done this? Does anyone have pics? I want to remove the part on the drivers side frame rail near the steering column. The car has an LT1 and I am going to run the lines to the rear of the intake. I am looking for pics, opinions, suggestion on type of hose and comments. I would also like to find pics of stock lines in the tunnel.
Old Mar 11, 2008 | 04:02 PM
Firebat's Avatar
Re: Relocating fuel lines
ttt. I am also interested. I also have a LT1 thirdgen.
I would think you would just cut the line right as it exits the tunnel and flare the lines there. I don't know, I would like to see some good pics.
I am concerned about if its legal for the track or not.
Old Mar 11, 2008 | 04:09 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I have these fittings. http://cgi.ebay.com/ebaymotors/LT1-L...0716QQtcZphoto
It converts the factory fuel rails to AN. The big one threads directly on to the regulator. I am planning to use this on a friends car and mine. It will move my lines so they are hidden completely by my fuel rail covers. I am wanting to clean up my engine compartment and this is step one.
Old Mar 11, 2008 | 09:20 PM
2fast4u92z's Avatar
Car: 2 camaros 1 trailblazer SS
Engine: 346twinturbo, 383tpi
Transmission: t56 and 700r4
Axle/Gears: 3:46 4:11
what size line are you planing on using? -6? Cuz unless those fittings are the ones needed on the "factory" rails I don't see the need. Also what power are you having?
Old Mar 11, 2008 | 09:26 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
-6 for supply and return. It is a matter of aesthetics for me. I am running an 11.2:1 compression LT1 with an LE1 package. I don't have any horespower numbers for my car.
Old Jun 26, 2008 | 11:59 PM
Firebat's Avatar
bump (Somebody has to have pics of hidden fuel lines)
Old Jul 24, 2008 | 12:12 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Mine are not hidden but I thought I had a good idea. I ran -08 from the sending unit to my home made fuel block. Then I rand -06 from there. I did the -08 knowing I am going to upgrade in the future. Oh and the return is -06.
Pic
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
