Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Forming Polycarbonate....
Old Jul 4, 2008 | 01:36 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I'v been kicking around the idea of doing a polycarbonate
hatch to replace the glass with, iv been doing some pricing i can get a sheet thats the about the same length, width and thickness of the hatch glass for around $60.
iv done small things in plexiglass before.
but nothing like this. i have a few hatchs that i can possabily use for forming. assuming they wont break.
does anyone have any experience with this? or made anything out of a smiler compound?
Old Jul 4, 2008 | 05:54 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: Forming Polycarbonate....
why not just buy the one summit sells?
Old Jul 4, 2008 | 11:04 AM
FueledSoul's Avatar
cost
Old Jul 4, 2008 | 10:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
lay the poly over the stock glass and heat it up with a heat gun and let it sag.
You really need an oven to do a good job, but this might work...
Old Jul 4, 2008 | 11:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I tried doing a hatch in Plexiglass many times and I broke lots of sheets. Plexiglass is very brittle and the heat gun doesn't produce enough heat over a wide area to get a good bend.
Finally gave up and bought some Lexan. Just about impossible to break it and it bends easily. All my windows are now Lexan.
My hatch isn't designed to open. I have a fabricated deck lid that can be removed to access the battery and the Lexan is riveted in place.
Trust me. It will be cheaper to just buy the kit from Jegs or Summit.
Old Jul 5, 2008 | 12:18 AM
Sonix's Avatar
Car: 1982 Trans-Am
Just for some readers:
Lexan = trade name for polycarbonate
Plexiglass = trade name for acrylic. (more brittle stuff)
Old Jul 9, 2008 | 01:20 AM
FueledSoul's Avatar
Anyone else have any other input?
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
Brother Al
Oct 14, 2015 06:39 AM
S10K20
Oct 7, 2015 06:45 PM
mrestrictrplate
Sep 21, 2015 11:24 AM
scottmoyer
Sep 5, 2015 09:33 AM
