Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
I really want to take the t-tops off but.....
Old Jul 17, 2008 | 04:28 PM
dwright69's Avatar
The interrior headliner is completely shot!!! The years of leaking every so often has completely rotted the molding and fabric!!!!!! Any ideas on where I can find a new headliner, WITHOUT SENDING ME TO THE POOR HOUSE?
Old Jul 18, 2008 | 01:30 AM
Pocket's Avatar
Car: 91 Trans Am
Re: I really want to take the t-tops off but.....
If the fiberglass backing is still intact just recover it yourself
Plenty of info in searches for this
Option 2 is the ABS plastic aftermarkets
They leave some to be desired on fit and are decently priced for what they are
Your call
Old Jul 19, 2008 | 03:10 PM
'86 Camaro BoSs's Avatar
Car: 1992 Camaro RS - 1971 Chevelle
Engine: 3.1L - 5.7L
Transmission: T-5 - TH350
fiberglass? backing, do you mean fiberboard, or do you just have a unique thirdgen...
as for what to do about your headliner.. i yanked mine off.. it doesn't look that bad to me.. and the breeze you get on 100 degree day's outweighs the look factor.. but the abs plastic one's are your only other option really.. from all i've read about them, doesn't really matter where you get them cause ther'es only 1 or 2 places making them.. just look for the cheapest price..
Old Jul 19, 2008 | 08:37 PM
Pocket's Avatar
Car: 91 Trans Am
Stockers are fiberglass
There are more forms of FG than the hard smooth stuff used for boats and hoods
Old Jul 21, 2008 | 08:07 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Mine looks like crap too. I was thinking of brushing some fiberglass resin on mine to harden it and then paint it. Would this work? Maybe I should lay some fiberglass and resin on there to make more of a shell? It's be cool to have a paintable surface up there.
Old Jul 22, 2008 | 01:20 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I had this same idea. What I'm worried about is getting it installed once it's hardened. It's a tight fit and from what I remember, you may have to flex it a good bit during installation.
Old Jul 23, 2008 | 12:27 AM
Pocket's Avatar
Car: 91 Trans Am
Youll have no trouble getting it in/out of the car if you go thru the hatch
Old Jul 23, 2008 | 01:06 AM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
good call. I think I'll try i soon. Mine will be black metallic with PONTIAC on the upper headliner area where it's visable with the tops off.
Old Jul 23, 2008 | 02:37 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
I covered my stock headliner with resin and hardener and reinforced it with fiberglass cloth. Haven't reinstalled it yet. I found a place on the net that sells headliner material. I'm waiting for color samples to match the rest of the interior. Mine was in pieces when I started.
Old Jul 23, 2008 | 12:28 PM
Pocket's Avatar
Car: 91 Trans Am
I use common felt
It stretches to fit the curves of those especially difficult T-top headliners
The visors and sail panels are cake
Once all 3 are done noone will ever know its not stock
Old Jul 23, 2008 | 03:39 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
You can recover a t-top headliner with headliner material. it just takes a lot of patience. Here is a link to a write-up I did for mine:
https://www.thirdgen.org/forums/inte...tml?highlight=
Old Oct 2, 2008 | 04:38 PM
townaj's Avatar
Car: 1985 Z/28 Camaro
Engine: 383 baby!!!
Transmission: NWC T5
I have been looking around but I can't find a place that sells just the headliner material. Do you know where to get it?
Old Oct 3, 2008 | 07:20 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
any fabric store should carry it and know it by the name "headliner material". Around here, Joann Fabric carrys it in many colors and you can usually special order additional colors. It's basically felt with a 1/8" foam backing.
Old Oct 3, 2008 | 09:16 AM
townaj's Avatar
Engine: 383 baby!!!
Oh really? I never thought to look there. Thanks! Is there a special glue or anything I need to get?
Old Oct 3, 2008 | 09:31 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
in my link above, I mentioned Permatex Heavy Duty Headliner and Carpet Trim Adhesive. It worked better for me than the 3M brand did. I got a can of it at Autozone.
Old Oct 3, 2008 | 04:46 PM
townaj's Avatar
Engine: 383 baby!!!
Cool thanks. I just bought my car about a month ago. The guy was the first owner so I consider my self pretty lucky. But the headliner was gone. I have no idea why because mines a hardtop so it wouldn't see any water. But stuff keeps coming off and getting on the interior stuff so it gets annoying.
Old Oct 4, 2008 | 11:50 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
nothing more true has ever been spoken. i tried using 3 different types of 3m cause i figured it was quality (i work at a stereo shop so they were lieing around) before i motored down to autozone and bought the Permatex.
Old Oct 5, 2008 | 12:24 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Whatever you do don't get the ABS headliners you see at various places online. I would say they fit like complete ****, but that would be a lie, because they actually don't fit at all. I had to completely destroy mine to get it in.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
