Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
TPI Fuel line
Old Jul 25, 2008 | 09:12 PM
ar1424's Avatar
TPI Fuel line
Converting 1975 Chevy truck to TPI...I tried to fabricate a fuel line using 3/8" inverted flare from Kragen and WeatherHead 1446 fitting(Saginaw->inverted flare) I could not get a good seal between the 3/8 fitting...I tried to tighten it as much I can still leaks. I even converted it using barb connector between WE1446(saginaw->inverted flare) fitting and the barb fitting still leaks between the barb. No matter what I hooked up WE1446(saginaw->inverted flare) fitting still leaks. Any alternative what I need to use?
Old Jul 26, 2008 | 07:50 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: TPI Fuel line
are u using stock TPI hard lines that run from the fuel rail to the front of the engine? accel sells adapter fittings from the metric to -6an... then get a -6an to barb and run rubber to the hard lines or just use -6an braided and connect to the hard line
Old Jul 26, 2008 | 08:20 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
Re: TPI Fuel line
I used the accel TPI fuel jumpers lines from Arizona TPI on my 82 corvette. They come straight and you bend them to you application.
Worked great for me
http://www.aztpi.com/home.php?cat=18
Old Jul 27, 2008 | 10:31 PM
75chevytruck's Avatar
Re: TPI Fuel line
The aztpi fuel jumper is it a barb type at the other end or did you made you own barb...
Thanks for the reply...
Worked great for me
Old Jul 27, 2008 | 11:00 PM
Car: 1971 Camaro
Re: TPI Fuel line
I'm not sure what you mean by "barbed". It's completely straight on the other end. I slipped a piece of fuel hose about 4" over the arizona TPI line and secured it with two clamps on each line.
Then I ran the other ends to the lines on the frame rails and secured them with clamps. There is about 12" - 15" of rubber fuel hose on each line going to the frame lines.
Old Jul 28, 2008 | 03:49 PM
Car: 87 TA clone
Re: TPI Fuel line
this is a barb fitting
http://store.summitracing.com/partde...5&autoview=sku
it is used to connect rubber lines more securly and promotes better sealing and grabbing of the hose. with use of one hose clamp. this is far better than using a smooth peice of line with 2 clamps... the barb has the ridges to grab the inside of the hose. not saying 2 clamps dont work on smooth line. a hard line adapter to a hose barb fitting will securely seal the rubber line for the best posible connection.
and you would need about a ft of rubber line betweent he engine fuel hard line and the body due to engine flex and to absorb vibration.
Old Jul 28, 2008 | 04:52 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: TPI Fuel line
The fittings you need are Saginaw ends. Here are the Dormans part numbers available on the web (use google) and at http://www.partsamerica.com/productd...goryCode=3120B. They are $12.88 each.
800151
800153
One is 5/16" x x18" and the other is 3/8" x 18". Use a flared end on the non-Saginaw end along with SAE 30R9 (EFI hose) and EFI clamps like this http://cgi.ebay.com/ebaymotors/30-FU...spagenameZWDVW
Ideal 52F16 and 52F15.
Old Aug 17, 2008 | 10:19 AM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
Re: TPI Fuel line
[QUOTE=85TransAmFreak;3836658]I used the accel TPI fuel jumpers lines from Arizona TPI on my 82 corvette. They come straight and you bend them to you application.
Worked great for me
Are those the Vette fuel lines your using for the injector rails? if so what year did you get them off of. Im trying to clean mine up, when I did the initial install using the 89 F-body set up I made my own fuel lines from front to back using 3/8 and 5/16 brake lines, some pretty ugly bends that I know are restricting fuel flow so Im trying to get it cleaned up and use the stock monte carlo fuel lines.
Also what type of rubber lines are you using? if I can hose clamp it on the orriginal fuel lines that would save me a whole lot of hassles.
TIA
Old Aug 17, 2008 | 11:57 AM
Car: 1971 Camaro
Re: TPI Fuel line
Yes they are vette fuel rails, I'm thinking they were off a 86 model.
I'm using 3/8" and 5/16" fuel injection rated fuel hose I purchased from O'Reilly auto parts. I'm clamped to the original metal lines on the passenger frame rail.....worked out great for me.
Old Aug 17, 2008 | 03:32 PM
monte-ss's Avatar
Re: TPI Fuel line
SWEEEET! thats good news, how long have you had your set up? and how did you mount the fuel filter? Sorry for the Q's but looking for other ideas. Ill have to figure a different place for the filter Im sure.
Now to look for those fuel rails, I guess the 9th injector wasnt installed on those vettes? thought they were still on there at that time but apparently not.
Old Aug 17, 2008 | 03:42 PM
Car: 1971 Camaro
Re: TPI Fuel line
I had my set-up for about a year..
Since my car was originally crossfire, my filter is mounted along the frame rail sandwiched between the metal feed line.
Yes they had the 9th injectors, since my car was swapped to Speed density I bought a injector block off kit for my fuel rail....I got it from Street and Performance in Mena, AR
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
