Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Battery Tray
Old Sep 7, 2008 | 03:25 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Battery Tray
Has anyone fabricated their own battery tray to replace the rusted one. My battery was on the pass. side and has a good amount of rust there. Pics? ideas (other than buying OEM piece)?
Old Sep 7, 2008 | 05:16 PM
mesterz2889's Avatar
Re: Battery Tray
mine rusted out so i cut out the tray and im gonna put the battery in the back
Old Sep 7, 2008 | 06:27 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Battery Tray
one of the best fixes ( IMO ) is to install a 4th gen battery tray/coolant tank . i did this on my 89rs , as we speak i just finished cutting out the bottom of the battery tray in my 88s/c . ( cuts on my hand are still bleeding ) get one from a dealership ( $40.+ as i recall or hit J/Y ) cut out bottom of old battery tray . clean cancer/rust , paint . set new tray in position , mark and drill mounting holes . battery will set about 2" inbd. and 1" higher . no clearence problems with me . you get rid of ugly coolant recovery container and have a new battery tray that will not rust . has worked for me . good luck .
Old Sep 7, 2008 | 11:04 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Battery Tray
Good idea with the 4th gen. battery/coolant tank. Did you get a tetanus shot recently? A doc. asked me that the last time I had a cut from metal.
Old Sep 8, 2008 | 02:48 AM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
Re: Battery Tray
Anyone have a pic of what it looks like?
Old Sep 8, 2008 | 07:26 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Battery Tray
https://www.thirdgen.org/forums/atta...22_63_full.jpg
I found this pic on another thread.
Old Sep 12, 2008 | 06:03 PM
Mathius's Avatar
Re: Battery Tray
The 4th gen idea sounds cool if it works. Otherwise, about 20 minutes with a shear and a box and pan brake I could make a nice one.
Mathius
Old Sep 13, 2008 | 02:13 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
Re: Battery Tray
im curious to see what the 4th gen battery tray works or looks like any more pics, need some extra room to mount my msd box, i was contemplating just removing my water resovoir but the 4th gen battery box looks like a better way to go
Old Sep 13, 2008 | 05:12 PM
UNCLE TOM's Avatar
Re: Battery Tray
forgot to mention , when installing tank there is a fender brace that needs to be repositioned below battery tray . no biggie , remove , install tank/battery tray , just shorten brace , reposition , secure . i have done 2 and each work great . good luck .
Old Sep 13, 2008 | 08:35 PM
godreject's Avatar
Re: Battery Tray
thanks tom the 4th gen tank looks good, so good i picked one up from the local j/y for 6 bucks, will install tomorrow, now im anxious to remove that ugly water tank and makes some room for an msb box, also the same car maybe a 98 or 99 ls1 car had the full front brake set up(minus 1 caliber) makes me want to go back and do an ls1 brake upgrade my c6's look bare rigth now
Old Sep 17, 2008 | 02:12 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Re: Battery Tray
I just made one out of some sheet steel. It might not be pretty, but it does the job.
Old Sep 18, 2008 | 10:58 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: Battery Tray
What is the thickness of that steel piece? My welder tends to burn through the thinner steel. If it didn't I would've bought the replacement tray for $40.
Old Sep 22, 2008 | 02:42 PM
Car: 1988 IROC
Re: Battery Tray
This was some 22 gauge I had laying around. It's probably a little too thin and it is hard to weld without burning through it. I did this before I found out there were repro trays available.
Old Sep 22, 2008 | 08:43 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
Re: Battery Tray
Yeah, for all of you guys that have the battery on the right side there is a repo out there; if you can find it. For all of us that have the battery on the left side; we're screwed.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
