Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
CNC Plasma table ideas
Old Oct 7, 2008 | 11:22 AM
jfg455's Avatar
Car: 89 formula *sold*
Engine: 305TPI
Axle/Gears: 3.45 9 bolt
Just to let the board members know, I have a CNC plasma table in my garage that I use for my metal fab/art hobby. If anyone has ideas for stuff to be cut out IE: mini tub frame reinforcement plates or front lower control arm boxing plates let me know. I would definately give a TGO members a group discount. I am also a 3rd gen owner and lover. Thanks. G
Old Oct 7, 2008 | 10:37 PM
Pocket's Avatar
Car: 91 Trans Am
Re: CNC Plasma table ideas
Can you cut .25" steel?
Old Oct 8, 2008 | 07:55 AM
jfg455's Avatar
Engine: 305TPI
Yes. I can cut up to a 1/2" thick plate and the table will take a full 4' X 8' sheet.
Old Oct 8, 2008 | 10:55 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
could you do custom orders if I sent you an audocad file or dimensioned print? I was thinking of something like an aluminum shifter plate and/or radio trim piece.
Old Oct 8, 2008 | 11:42 AM
jfg455's Avatar
Engine: 305TPI
I can do custom orders either from a dimentional drawing or a DXF file. The finish of the cut on something like a radio or shifter trim plate in aluminum is probably rougher than you are looking for. You would want it cut using a water jet or a laser cutter. I could do it but you would have to finish the cut edges IE: sanding or filing to a smooth finish. Thanks. G
I will try and post some pictures of what the cut looks like so people can judge for themselves.
Old Oct 8, 2008 | 03:22 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
That would be great to see what the edges look like. thanks
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
ericjon262
Sep 11, 2015 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
