Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Accelerator Pedal
Old Nov 3, 2008 | 06:05 PM
almsfan21's Avatar
Accelerator Pedal
I searched but wasn't able to really find anything. The previous owner of my 84 L69 cut off the accelerator pedal. I have NO idea why. All that's left is the cylindrical rod in the driver's compartment. I hooked up the linkage last night, so it's "driveable", but it'd be nice to have an actual pedal. With no access to a welder, does anyone have any ideas on how to fix this?? Thanks.
Old Nov 3, 2008 | 06:28 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Accelerator Pedal
buy a pedal assembly from another user or a junkyard?
Old Nov 5, 2008 | 11:48 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
no other method is worth your time! The pedal assembly is mounted to the firewall with 2 bolts. Then the throttle cable has a ball at the end that sits in a recess in the pedal assembly... you just pull it outward and slide it through the slot to detach it. It's incredibly easy to replace your damaged pedal and I don't believe there were any functional changes to the pedal assembly from 82-92, so any 3rd gen in a junkyard will have what you need. Find anyone parting out a car in the classifieds section and you should be able to score the part you need for $10 or less.
Old Nov 7, 2008 | 05:53 PM
nhrata's Avatar
Car: 82 pontiac t/a
Engine: 23 deg headed 434ci sbc
Transmission: rossler T350 with brake
Axle/Gears: moser 9" ford 4.56
The plastic petal part might have fell off the rod . the pin brakes and it just leaves a rod
Old Nov 11, 2008 | 09:40 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I have a Pedal Assembly for sale, if your interested, Pm me with an offer. Thanks!
Old Nov 11, 2008 | 10:08 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Is there a hole through the end of the rod? If so, then it's just the plastic pedal that's come off. My car was like this when I got it. Took about 10 minutes to fix, most of which was trying to get the little spring and pin in place.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ironbmt
Sep 27, 2015 06:00 AM
