Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
some help on a 2nd battery plz
Old Nov 5, 2008 | 04:01 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
i searched and didnt find what i was looking for but im sure its been done. i want to put a 2nd battery in my 88, kinda to run the lights and sterio when the car isnt running. but i want the 2nd battery to hook up to the main system so it gets changed and if 1 battery is dead the other could take over(but when the extras are on it doesnt kill the main battery). besides the obvious of finding a place for the 2nd battery, how would i hook up such a system? and would i need to upgrade to a stronger alternator? the motor is a 350, mechinal fan, umm t-5, stock motor. i think this would be a good idea or is it bad? any help ofcourse is welcomed and thank you.
or should i hav put this in the electronics board?
Old Nov 5, 2008 | 08:03 PM
Mathius's Avatar
Re: some help on a 2nd battery plz
Search for dual battery isolator on yahoo or google. Offroad sites are going to have the most information. There are several ways you can configure such a setup I think... as extra power, as a backup, etc. Also, lowrider sites might be helpful as well... I'm not positive on that, but they do have to run an awful lot of batteries to run their hydraulics, so I have to assume they know something about it.
Here's some I found: http://www.4crawler.com/4x4/CheapTri...atteries.shtml
http://www.bajataco.com/dualbatts/dualbatteries01.html
http://www.pirate4x4.com/tech/billav...tery_setup.htm
http://store.summitracing.com/partde...5&autoview=sku
As far as placement goes, you can relocate both batteries to the trunk, go to a 4th gen washer fluid resevoir and put the second battery there, or perhaps relocate your charcoal canister. Some would recommend you remove the charcoal canister, but it does serve the purpose of dealing with gas fumes, and doesn't cost HP. I'd leave it.
Mathius
Old Nov 5, 2008 | 09:34 PM
DARKmj16's Avatar
Engine: 305 tbi
wow thanks a bunch.
Old Oct 19, 2010 | 12:58 PM
zed's Avatar
zed
Car: 1991 Z28, 1984 Z28, 1990 Toyota 4x4
Engine: L98, L69, 22RE
Transmission: 700R4, 700R4, 5Speed Manual
Axle/Gears: 3.73, 3.23 Posi, 4.10
Hiya, I know it's an old post, but where would you relocate the charcoal canister to?
thanks
Zed
Linson
Oct 24, 2025 02:00 PM
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
Lbibb
May 5, 2016 12:00 AM
drumstixer
Sep 29, 2015 03:02 PM
