3RD GEN LAMBO DOORS
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
3RD GEN LAMBO DOORS
ANYBODY DONE LAMBO DOORS ON A 82-92 ? MY DOORS ARE OFF FOR BUSHING REPAIRS. THIS IS THE BEST TIME TO DO IT. SO FAR I CANT FIND A TRUE BOLT ON KIT. IM NOT GONNA CUT OR WELD MY FRAME SO BOLT ON IS THE ONLY OPTION. ANYBODY SEEN OR DONE A KIT THAT IS A BOLT ON WITH MINIMAL FENDER MODIFICATION AND NO CUTTING / WELDING ON THE FRAME OR DOORS
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Re: 3RD GEN LAMBO DOORS
Dude you don't need All Caps...
And aparently you didn't search hard enough, or at all..?
all i did was search on google 1982-1992 Camaro door kits.
THis was first link; They're going to cost ye 1299$ plus shipping and time/work to put them on
http://lambodoorspal.com/lambodoors/...sort=2a&page=1
Chevy Lambo Doors Description: Lambo doors conversion kit for CHEVY CAMARO 1982-1992 (ALL Models). This Authentic Vertical Doors, Inc. kit will enable you to easily modify your vehicle and attain the look you desire! Direct "Bolt On" hinge kit. Mounts to Factory Bolt Pattern. Made in USA from Domestic Hardened Steel. Completely Reversible
MOD'S REQUIRED
High quality CHEVY CAMARO Lambo doors / vertical doors kit. This Lambo doors kit is made specifically for your 1982-1992 CHEVY CAMARO. The kit comes with 2 door hinges, 2 shocks, all the mounting hardware, and installation instructions.
MOD'S REQUIRED
IT LOOKS LIKE VERTICAL DOORS INC HAS THE ONLY BOLT ON. 1299. OUCH. THE OTHER KITS DONT GUARANTEE BOLT ON. I DONT WANT TO BUY ONE WITHOUT CHECKING FENDER CLEARANCE HOLES LINE UP ETC...
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Check out your local board (Southwest region) There are a few members here in town who do this sort of thing and at least one who has it done to their car. As far as I know, there is no true "Bolt-on" kit for this. Keep in mind, if you go to the pavillions or some of the "Shows" on the west side they will give you a hard time for doing lambo doors on a Camaro. Good luck!
Car: 1988 camaro sc
Engine: nasty 305 tbi,tba 632 big block
Transmission: built 700r4
and you have to be carefull about them becuase some of them are crap and will fall back on you, heard about a few people getting broken knee caps becuase the hinges or something broke and the doors swung back down on them.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
also the door frame is not really the frame of the car. so hacking/cutting into them wouldnt make too much of a difference. My car had both front fender/door/floor sections where your feet rest completely rotted out and the car had no structual issues.
IM LEANING AWAY FROM LAMBO DOOR KITS. IT LOOKS LIKE ALL REQUIRE CUTTING FACTORY HINGES. NOT EASILY REVERSIBLE. ANYONE DONE IT ON HERE LET ME KNOW WHERE/WHAT CUTTING WAS REQUIRED. IM KEEPING REGULAR DOORS UNTIL I KNOW EXACTLY WHAT IM GETTING INTO. CHANGING BUSHINGS ON AN 88 IROC-Z REQUIRES DOORS TO COME OFF. I FIGURED PERFECT TIME TO GET DOOR KIT ...
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Go to the junkyard and get a set of hinges dirt cheap.
THE HINGES BOLT TO THE FRAME AND ARE WELDED TO THE DOORS. NEW HINGES WILL FORCE CUTTING THE OLD ONES OFF THE DOORS AND WELDING NEW ONES ON. MY HINGES ARE INTACT. THEY ONLY NEED NEW BUSHINGS / PINS.
Car: '87 Z-28
Engine: LT1-topped 400
Also, please turn off the caps lock... typing in all caps is the internet equivalent of yelling and is a terrible way to make friends.
Car: 1986 Trans AM
Car: 1988 camaro sc
found this link it my help, https://www.thirdgen.org/forums/fabr...-fab-help.html just thought id post it.
Car: 84 Camaro
Engine: 350 Goodwrench with Edelbrock pkg
Transmission: rebuilt 700R4
my ears hurt from reading all the caps, i don't trust Lambo Doors to hold out, and the fad kind of died when import tuners started using them, and the steep price isnt worth changing from regular swing open doors, sorry i can think of too many ways that this would be a bad idea
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
