Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
My Fabrication and Build...
Old Jun 2, 2010 | 04:59 PM
  #101
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
Re: My Fabrication and Build...
Time for a little update. I got the flywheel/clutch installed and matted the two together for the final time. Started getting the Cross member TQ arm mount built and I have 90% of the 4" down pipe and boom tube exhaust tacked together. Its starting to take shape im off on vacation for the next two weeks, when I get back its getting the radiator and intercooler mounted and start working on the engine wiring harness and maybe fuel system.
Old Jun 2, 2010 | 09:45 PM
  #102
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Work is progressing quite well!!! Some very, very nice fabrication going into the build! Takes more then just "bolt ons" to build a really first rate Hot Rod, congrats on the most excellent craftsmanship!
Old Jun 11, 2010 | 10:06 PM
  #103
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Lookin good! Any updates?
Old Jun 11, 2010 | 11:24 PM
  #104
89rs305-DP's Avatar
Car: 89 Camaro RS
Engine: Built 357 Vortec
Axle/Gears: 3.23 from an '87 iroc
Originally Posted by Tricked-Out-Toy
That is the most beautiful engine i think ive ever seen lol. Nice work
Old Jun 18, 2010 | 10:55 AM
  #105
Car: 91 Z28
Engine: Lt1
Thanks guys! as for updates I just got back from vacation so ill be getting back to work on it. Im going to start getting the body wiring laid out and finish up the welding on the down pipe.
I did come to some kind of mental acceptance that Im really not happy with the way the A2A intercooler is setup. having it in front of the radiator at the angles it has to be at is really going to cause me more headaches sicne ive got real doubts that ill see enough airflow though the intercooler... So Im pretty much decided to go A2W with the intercooler flat mounted behind the radiator with a 5 gallon water tank in the back..... So itll take me a little more time to source the parts and get the mount fabbed up but in the long run its the best option.
Old Jul 13, 2010 | 09:22 AM
  #106
Car: 91 Z28
Engine: Lt1
Well I got the A2W intercooler mounted and have mocked up the charge piping. Its starting to look like a complete engine bay! I also got the radiator hoses made and installed... $300 bucks for radiator hoses is retarded ... but it looks good and should work like a champ.
I also took the entire LT1 wiring harness apart and pulled out all the BS that I didnt want/need. stuff like transmission sensors, rear O2, fan and fuel pump wiring, oil pressure sensor etc... Then took it all and added the LS1 PCM ends along with coil,cam and crank sensor plugs I also relocated the MAP sensor and coil connections to the interior and relocated the IAT sensor up through the frame rails to where Ill mount the sensor in the charge piping.
Old Jul 13, 2010 | 11:28 AM
  #107
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Very interesting build!
Have you test fitted the steering box and linkage?
Old Jul 13, 2010 | 11:47 AM
  #108
Car: 91 Z28
Engine: Lt1
Yup it fits like a dream
Old Jul 13, 2010 | 12:05 PM
  #109
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
some may say it's unnatural, but I'm in love with your car
Old Jul 20, 2010 | 08:20 AM
  #110
steNcho's Avatar
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 355 SBC
Transmission: TH350 with 3500 stall
Axle/Gears: GM 12-bolt with 4.10 gears
subscribe ftw! Very very nice work. Keep it up!
Old Jul 20, 2010 | 08:39 AM
  #111
Car: 91 Z28
Engine: Lt1
hahaha your not the only one! One of my friends wants to marry it and another wants to have sex with it! you might have to get in line lol
Heres just a little update. Ive been SLOWLY and methodically pulling all new wires and laying out the main body harness. Right now I have ALL the wires that run to the front (horn, lights, fans, IAT, boost contor solenoid) routed in the passenger frame rail. I have it sleaved in a rubber coolant hose so no chance of chaffing. Ill get some pics of that when I get home tonight.
I also have ALL the charge piping welding up and the intercooler 100% mounted. Im jsut waiting on my flange for my BOV to get here so I can weld that on. once thats on and I relocated the 3/8 npt IAT bung the charge piping will be 100% The boost blow out prevention struts for the silicone TB connection are actually spoiler stuts for a asphalt late model
Old Jul 21, 2010 | 11:08 PM
  #112
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
love your build... Makes me wanna get my turbo project rolling
Old Jul 22, 2010 | 09:38 AM
  #113
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
amazing build. i thought i was paying attention to detail and was going to have one of the better camaros out there..... thanks for popping my bubble lol just amazing. how much $ do you think you will have wrapped up in it. and what kinda of hp #'s are you hoping to achieve? again amazing build.. wow hands down one of the best i'v seen and i'v had 7 camaro and restored 3 of them on my 4th now.... I'm an armature after seeing this one lol lol
Old Jul 22, 2010 | 10:01 AM
  #114
Twin_Turbo's Avatar
Where did you get those turnbuckles? That's a real nifty idea for holing up the pipe and keeping it from popping off.
Old Jul 22, 2010 | 11:17 AM
  #115
Car: 91 Z28
Engine: Lt1
Thanks guys! Im trying really really hard to keep it super clean and not rush it. Ive probably got about 15K, def no more than 20K and that includes buying the car for 2K 10 years ago haha I have a solid 5-6K worth of stuff to buy for it but ALL of the work is dont by myself so I dont have to pay labor I dont even want to think about the time I have into it. lol
ive been working toward a goal of 650-700hp at 20-22PSI on pump gas and a solid 800hp at 25-28psi on E85. I think the goals are very realistic, Im staying 6speed for the time being but i plan on having a TH400 with a trans brake setup up for a quick change so one weekend Ill got road racing and the next ill hit the strip. but thats down the road a ways
The turnbuckles are from a local asphalt racing supplier. they are made for holding the rear wings and front splitters.
Old Jul 22, 2010 | 11:19 AM
  #116
Twin_Turbo's Avatar
Ah ok, I know where to get some then. Day motorsport, Coleman or SpeedwayMotors should have them (unfortunately I have to order everything in the US)
Old Jul 22, 2010 | 11:25 AM
  #117
89fbrestor's Avatar
I'm getting ready to start hot rodding my 66 mustang and this thread is definitely making me think differently. keep it up look great.
Old Jul 22, 2010 | 11:42 PM
  #118
Zak.V's Avatar
Car: 92 players unraced
Engine: LB9
Very Sweet, great fab work
Old Jul 23, 2010 | 06:38 PM
  #119
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
very nice work
Old Jul 23, 2010 | 08:21 PM
  #120
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
NIce work so far! Going to be a great car.
Is that turbo oil drain going to be vertical enough?
Old Jul 24, 2010 | 02:53 PM
  #121
Twin_Turbo's Avatar
That drain looks fine to me, no horizontal sections, no sloping upwards, it's all downward, it'll drain perfectly.
Old Jul 27, 2010 | 12:04 PM
  #122
Car: 91 Z28
Engine: Lt1
Ya like TT said its all sloped downhill and its more vertical right at the turbo so it should drain away nicely. If I have any drain problems ill just add a scavenging pump.
Im working on my battery kill switch setup now and I think i have it all figured out enough to actual get the pieces machined Heres a couple screen shots of it and the tank im having Donny at dads tanks fab up for me. I would build the tank myself but for his prices and the quality of the welds i jsut cant justify it.
also got the driver side travel limiter finished.
Old Jul 27, 2010 | 06:07 PM
  #123
anthony714's Avatar
absolutely brillant. just one word "sick". i see a twin turbo shoot out coming??????eh guys?
Old Aug 3, 2010 | 01:54 PM
  #124
231TurboCar's Avatar
Very cool project. Can't wait to see some more progress!
Old Aug 16, 2010 | 03:08 PM
  #125
Car: 91 Z28
Engine: Lt1
Just a lil update. got my battery cut out mounted and its pretty pimp! its cool to see something go from a rough sketch to a drawing then to the real deal.
Also got my BOV mounted
Old Aug 20, 2010 | 04:20 PM
  #126
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
That battery disconnect is awesome! My battery is in the trunk as well and if I ever have to put a disconnect in I hated the idea of drilling through the taillight. I may have to steel your idea or see how much you would want for one if I ever need to
Old Aug 20, 2010 | 10:30 PM
  #127
Car: 91 Z28
Engine: Lt1
150 for everything to need including the switch. You would have to do some slight modification to the brackets that weld to trunk area
Old Aug 21, 2010 | 12:06 AM
  #128
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Looks great! is that a piston on the push rod of the kill switch? Nice touch man.
Old Aug 23, 2010 | 02:39 PM
  #129
Car: 91 Z28
Engine: Lt1
Ya its a dished piston. Its a lil something extra.
Old Sep 7, 2010 | 09:42 AM
  #130
Car: 91 Z28
Engine: Lt1
Got my water tank from DADS over the weekend and all I gotta say is DAMN! I sent him the dimensions I wanted and what pump im gonna be running and he knocked it outa the park! If I could weld like that I would be in heaven! If you are in need of ANY aluminum tank work hes super cheap and does amazing work.
Old Sep 7, 2010 | 10:31 AM
  #131
quick87formula's Avatar
Car: 87 formula
Transmission: 700
Axle/Gears: 12 bolt strange 3.73
incredible job. i wish i had the time space and the money to do that my self.
Old Sep 7, 2010 | 11:54 AM
  #132
Car: 91 Z28
Engine: Lt1
Right now all I have is the space lol Time and money are in short supply!
Old Oct 27, 2010 | 08:50 AM
  #133
Car: 91 Z28
Engine: Lt1
Time for an update. Ive got the K-frame 95% complete weighs in at 24.6lbs. I still want to add a hand full of gussets but for the most part its complete. I got the hot side wrapped, I still have to wrap the down pipe but thats no big deal. I got the Line lock and Proportioning valve mounted along with reinstalling the booster/master and clutch master/slave. Also got a 3/8" bung welded into the charge piping for my IAT sensor and routed all the fuel lines... I was hoping to get all the odds and ends done by the weekend to get it fired up btu I had to put a few parts on hold since I found a pretty good deal on a coil over setup so I had to scoop that up.
Old Oct 27, 2010 | 01:13 PM
  #134
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
looks great man! very impressed. I love the fuel tank btw... how much did it cost to weld that up for u? I want a overflow tank and perhaps some valve covers... idk if DADS would do that?
Couple of questions tho... the intake piping from the pass side to the TB... is that mounted/fixed at the battery tray area (on pass side) just thinking that the engine should rotated about 1/2" or so under throttle which could pull on that area.
Also how did u fab up the Kmember? create a JIG from the stocker and work from there? and what type of tubing is it? moly? Since u seem to be about looks, i would of sprung for some TIG welding on the Kmember since the welds look kinda bulky.
Also could u come up with something like a Piston shifter handle? I love the little piston and think thats sick, i would love a piston on my B&M megashifter... hell id love a pistol grip lol but the piston is much cooler
Old Oct 27, 2010 | 01:51 PM
  #135
Car: 91 Z28
Engine: Lt1
The tank is for my A2W intercooler and with then supplying all the fittings and material it was $150]. The can make pretty much anything out of aluminum and you can look on there website for pics of thre other work.
Couple of questions tho... the intake piping from the pass side to the TB... is that mounted/fixed at the battery tray area (on pass side) just thinking that the engine should rotated about 1/2" or so under throttle which could pull on that area.?
It is fixed with a plate and if the engine moves so much as a 1/8" we have SERIOUS problems since its a solid motor motor plate Engine movement is no longer a concern.
Also how did u fab up the Kmember? create a JIG from the stocker and work from there? and what type of tubing is it? moly? Since u seem to be about looks, i would of sprung for some TIG welding on the Kmember since the welds look kinda bulky.?
Yup started with the stocker and made a Jig off of that. I dont trust myself tigging something that critical yet and I dont trust anyone I know to Tig it either. I know my mig welds are strong and on the K frame I was really going with stong welds over cosmetic welds. Chromoly is something I thought about but since this was my first attempt I didnt want to have a bunch of money tied up in expensive tubing just to find out I couldnt make my design work. Also tigging chromoly is a must in my book and again im pretty good on alminum but structural elements im not comfortable enough to put my life on the line. Also I would not have reduced tubing wall thickness if I switched to chromoly so there wouldnt have been any weight savings.
My machinist would be all about that! not sure how well a piston would feel as ashift **** tho.
Old Oct 27, 2010 | 02:29 PM
  #136
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Damn, those tanks DADS makes are nice! And really well priced too....
If he made custom fabricated valve covers, I'd be all over a set. No one makes them for the motor I'm building, lol. But from what I saw on the website, they don't do them
Heh, and I guess you're right, a 150# spring might be a bit light for your car Looks great though, I want to see this finished. Can't believe I missed this build earlier
Old Oct 27, 2010 | 02:33 PM
  #137
Twin_Turbo's Avatar
what are you building that no one ha valve covers for then???
As for the original post, I'm loving it. Awesome fab work. Love the scooters valve covers.
Did you build that crossmember yourself?
Old Oct 27, 2010 | 02:37 PM
  #138
4.3 V6, to be swapped into my '85 Toyota
There are some valve covers out there, but they're cheap crap. I'm not gonna spend money on cheap crap, I'd rather powdercoat the stock ones gold and black to match everything else
Old Oct 27, 2010 | 02:57 PM
  #139
Car: 91 Z28
Engine: Lt1
Hahaha are you saying I look fat! Everytime I walk out in the shop my car asks me "does this turbo/radiator/intercooler make me look fat" lol I have to lie to her every time... I think ill be lucky to get away with a #325 spring....
Old Oct 27, 2010 | 03:01 PM
  #140
Car: 91 Z28
Engine: Lt1
Thanks man! the valve covers are PIMP and im really glad I splurged on them. Yup I did the crossmember myself. I built a Jig out of some scrap roll cage pieces I had lying around and then started srawing it up in autocad. Sadly the cad file was lost when my office comp took a dump and I didnt back up my local drive....
Old Oct 27, 2010 | 03:07 PM
  #141
Your car isn't fat... It's husky
I mean that in a good way of course
Old Oct 27, 2010 | 03:10 PM
  #142
Car: 91 Z28
Engine: Lt1
Ive been going with big boned
Old Oct 27, 2010 | 06:28 PM
  #143
radical82's Avatar
Car: '82 Camaro
Engine: 383
The K-member came out superb, Tony!! Excellent work! Fit, finish, and detail is what it's all about and IMO you get an A+ in each catagory. Too bad you don't live a bit closer...I've had the same guy doing my tig welds since back in the sprint car days (where I thoroughly "tested" his welds)---he's a geezer like me and it'd be great to hook you up with him for some OJT!!!! My Camaro keeps sliding down the priority list, about 3 customer projects ahead of it now, hopefully it can find it's way to the chassis table next spring....
Keep up the excellent work and the high standards!
Old Oct 28, 2010 | 10:11 AM
  #144
Car: 87 TA clone
ahhhh i forgot about the motor plate! yup that would stop her from twisting lol. Where did u get the driver side limiter from? and why u running a limiter if you have the motor plate?
Im looking for a set of valve covers for my 460 ford (now a 521 monster)swap into my bird. I can get a set for 215$ from canton but there not that nice. Ive contacted a guy in austrailia and he wants 500$ plus shipping... but they are sooooo frigin nice! Ill look on DADS site and see what he has to offer.
What tubing thickness did u use for the Kmember? I gotcha... still tho the car is so pretty u should def think about getting some moly tubing and having a Go at it, IMO moly should and ONLY should be Tig welded, i dnt think u can MIG moly? But its a pain in the A$$... so i understand. Would u be willing to make Kmembers? i would take one lol... my BBF is a fat lil piglet, more room for custom headers would be nice lol.
Old Oct 28, 2010 | 11:03 AM
  #145
I looked on DADS site, I want a pair of valve covers fabricated too!
If I remember right, on the site they said they do ALL their stuff our of .100" aluminum. Which is probably about right for valve covers, except the base/gasket rail so I dunno. I'm all over a pair if they'll actually do them
Old Oct 30, 2010 | 10:22 AM
  #146
Car: 87 TA clone
.090- .100" aluminum is what ive seen used on fabricated valve covers. .100" is pretty normal, the gasket rail should be a machined piece of billet aluminum (if its a good pair of valve covers) billet will give the gasket a much more stable mounting/sealing surface against the head.
Well chris at DADs got back to me... the valve covers would cost me something like 500$ still and i would have to send him a head to design the covers...
Old Oct 30, 2010 | 10:26 AM
  #147
Car: 87 TA clone
LOL i wouldnt even care... still that would be sooo sick. Ask him how much for a piston shifter handle (has to have a slight angle in it for the palm facing upwards towards the front of the car) with the threads for a B&M mega shifter? if its not too insane i would see about it, not to mention i might have potential buyers perhaps one for a munci 4 speed manual?
Old Oct 30, 2010 | 10:47 AM
  #148
Yep, .090" and a 3/8" billet gasket rail is what was used on my SBC covers... Man I loved those. But there's no way I can justiify $500 I thought they'd charge less, considering what they charge for the tanks!
Maybe it'd be a lot less if you had a local shop machine the rails, and just shipped them, so DADS didn't have to do that? Then you shouldn't need to send them a head either
Old Oct 30, 2010 | 05:37 PM
  #149
Car: 87 TA clone
perhaps... but they would still need to know the height of the covers etc. I should correct myself heres what he wrote me.
"They would be more than $500 if we custom made them."
Old Nov 7, 2010 | 12:05 PM
  #150
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Sweet build, you got skills
