buh-bye rag joint and header clearence issues
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
heres the lower joint, the stainless 3/4 dd shaft and upper joint are still in the mail. I'll take more pics when complete, but this complete will run maybe 150 total in parts all polished stainless
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: buh-bye rag joint and header clearence issues
Details? what are the part numbers, etc.
Car: 82 Trans Am
Transmission: t-56
I'll do you one better and link you to a few ebay auctions selling what you need... it all simply bolts together, no welding, simply cut your shaft to length, (should be somwhere between 12" and 15". if you think you need a collapsable shaft then do a search for 3/4" dd shaft and you find collapsable types as well.
top joint:http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
shaft:http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=007
lower joint:http://cgi.ebay.com/ebaymotors/3-4-3...Q5fAccessories
Car: 1984 Z28
the shaft link goes back to the top joint but it looks like a nice system, hopefully you'll post up some finished pics shortly
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
how will you get on and off without a slip joint? just wondering
Car: 82 Trans Am
Transmission: t-56
easy, take out the 3 bolts on the column/firewall, loosen the 2 under the dash and slide it back. should only need maybe 3/4" slide room
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I did mine dirt cheap. I used the lower slip shaft from a third gen and welded on the u-joints from an Astro van steering shaft. The Astro van's steering shaft is too short to use in a third gen. My headers are a tight fit. I had to relocate the upper column up and away from the headers to clear the tubes. The upper column is nothing more than just a shaft.
Car: 82 Trans Am
Transmission: t-56
the main reason behind mine is SLP header clearence. My car is 100% new for any removable parts and I have a rubbing issue. New mounts, you name it it it un bolts its new or rebuilt to new specs of better. so I am going to turn the center section of the shaft to a slightly smaller diameter and re-polish it.
I have a ton of polished parts underhood, so I thought it would be a cool addition and clean up the ugly stock rag joint and plastic cover and slip shaft.
that and the added precision in the steering feel will be nice
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i need to do this, subscribing! I want pics too!
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Stephen, are the u-joints in the Astro van just bolted in, or welded in, when they are on the Astro van?
Car: 87 IROC L98
They bolt onto the steering box with the same size 3/4" splined end and they're bolted onto the upper shaft with the same 1"DD. They're welded/pinched to the slip shaft but can easily be cut off the Astro van shaft. Cut the third gen shaft off it's ends, insert into Astro van ends and weld
Car: 82 Trans Am
Transmission: t-56
That’s surely a way to do it on the cheap and achieve the over all same idea.
I think the level of precision on the joints I am using and the polished stainless, no need to weld, no rust etc… makes the difference between a used part, that will rust, needs to be welded and isn’t as “pretty” and a part such as mine.
so over all concept isn't new, but it'll be more along the lines of something that you would buy turnkey from a vendor.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Subscribing for future use. Need to kill the slop.
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
I used a shaft from a 96 up full size chevy van, they have a boot around em and the joint is kept covered in grease. just cut a sction from my old shaft to use as an extention for the van outer shadt and welded it up, worked great on my monte carlo.
Had maybe 20 bucks into it.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Did mine some 5-6 years ago.Ive got all of 6 bucks in my astro/4th gen/3rd gen U-joint set-up.It still has the slip joint so it will collapse in a front end collision.The box end(astro)also has a rubber isolator built-in to absorb any vibrations.The firewall end(4th gen) slips right on the OEM steering shaft & uses the same style clamping bolt.
wouldnt this help for 40 bucks..... I was thinking of getting this ...any openions against of for ?
http://www.unbalancedengineering.com...Rag_Joint_3rd/
Car: 82 Trans Am
Transmission: t-56
[quote=screeminchicken;4009085]wouldnt this help for 40 bucks..... I was thinking of getting this ...any openions against of for ?
http://www.unbalancedengineering.com...rd/[/quote]
tons of threads on this one. the only issue I hear is slight binding while turning. in my case It isnt the rag joint that is my main problem, but the header clearence.
with my set up as well, it a show piece too.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Car: 82 Trans Am
Transmission: t-56
parts are here. cut the shaft down to 13"
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Very nice! I'm going to have to make me a collapse version of that.
Car: 86 Trans Am
looks good!
did you actually gain any clearance at all at the header tube? it still looks really close.
Street Lethal
Apr 30, 2019 12:14 PM
evilstuie
Feb 28, 2016 03:33 PM
