Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Removing t-top tint??
Old May 11, 2009 | 07:35 PM
irock_667's Avatar
is it possible to remove the factory smoke tint from t-tops?
mine are scrached up, and id like to tint them black.
86 iroc
Old May 11, 2009 | 08:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Removing t-top tint??
Can't be any worse than taking regular tint off windows. Razer blades, glue remover, maybe a heat gun.
Old Jun 12, 2009 | 07:24 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I can see it being much worse! It might be etched in to the point where you have to pretty much sand/scrape/grind the tinted layer off the glass and polish it afterwards. I've seen some small scratches in t-top tint, but overall they hold up pretty good over the decades so it can't be easy to remove the tint completely.
Old Jun 12, 2009 | 07:41 AM
irock_667's Avatar
yeah its looks like a painfull process! I may scratch the idea and just have them done in suede. Keep the sun out completly and look nice as well.
Old Jun 16, 2009 | 06:17 PM
tattooeddiva's Avatar
Car: 82 camaro unique
Engine: 327 out of a 68 vette
maybe u wanna try what i did.
take a spray bottle with a dishsoap and water solution. get little corner off and spray kind of behind the tint. worked fine with all my tint, and didnt leave anything behind, but please take your time. good luck
Old Jun 16, 2009 | 07:07 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
t-top tint from the factory is different than window tint. it isn't a sheet that's adhered to the glass... it's sprayed on and can't be peeled away.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
