The Japanese heat extractor build...for my bird
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: The Japanese heat extractor build...for my bird
the hood came out really nice.
Im actually picking up a GTA hood this weekend that will be a winter project for me. Im going to use your ideas with some adaptations and see what i come up with. I think it will eventually find its way onto my 92.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Phenomenal! That is one pimptastic custom hood.
You completely misunderstood what I meant by "straight up".
Still following the same lines, but straight UP, not back, walls of the new cowl scoop.
What he did, was basically what I Photoshopped last year, then added the Japanese-style extraction reverse scoop to it.
https://www.thirdgen.org/forums/body...loed-hood.html
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
Wow thats awesome. Nice job. I would love to have a hood like that on my camaro. I have a spare hood but no welder or anything or id try something like this. I think its because its so different. I love it.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
wow that is an awesome cowl hood
Car: 87 GTA
I still want to extract the air from the engine compartment. After looking at several different designs i think I've settled on a series of louvers on each side the hood like those on the late model vipers. I plan to follow frychickens's method of making three-sided cuts and boxing in the sides.
I got the hood for less than half-off from the scratch and dent table at a local speed shop. I think I can make this for a total cost of around $250.00 (hood was $150). This part of the project won't start till next spring or summer but i'll post a thread with pics on the whole conversion.
Great job on the hood, nice to see somebody make something unique and not buy the same cookie-cutter parts that most guys are running. Ingenuity, and the courage to carry it out seem rare these days. Again great job, your project seems to have generated a lot of interest and maybe it will motivate others to do similar projects.
On a side note, I never heard of Bastrop tx until my daughter moved there last year. I just spent a week there visiting with her. Nice town, I really liked the Deli Depot and the bakery.
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Dude, your work is awesome!
A couple of ideas that occurred to me for your winter project:
With the wide cowl area at the rear, you have a huge area to grab air. You could make the cowl a lot less tall and still pull more air than you'll ever need. I
It's just my opinion, but most of the aftermarket hoods i've seen screw up the Firebird's beautiful lines. Why don't you photoshop some pics of this hood, making the cowl shorter and see how you like a more subtle version?
I used to have a '72 Trans Am. The coolest thing on that very cool car was the vacuum-actuated flap on the shaker. It was so cool to see it open and close in synch with my foot on the gas pedal. A buddy of mine has an '81 Z28, and it has two cacuum actuated flaps on the mini-cowl on his hood. He actually mounted his shift light in the cowl; it's only going to go off when the gas is floored and the flaps are wide open. How cool would it be to put a flap like that on your cowl?
Great, great work.
Great, great work.
Car: 1985 Pontiac Trans Am
Engine: 305TPI
I was going to say the same thing. Other than that, it is one of the nicest non-standard hoods I've seen for these cars. Well done.
Car: 87 Trans Am
Transmission: 700r
Axle/Gears: ones that turn
Continued....
Here's a shot of the underside with the sides tacked into place. The piece tacked in at the rear of the hood is just to keep it from sagging in the middle for right now. I still haven't decided exactly what I'm going to do back there yet but the majority of it will remain open.
Here it is before I cut the extractor hole. I came real close to just leaving it like this. But, I have another Bird now that will probably end up with one like this.
And here's with the hole cut and the sides getting tacked in.
It all looks kind of sharp and square on the edges at the moment, but I haven't gotten to it with the hammers/dollies yet either. There is still a good bit of small things I need to do to it like cleaning up the edges of the opening to where they look stock and deciding what I want to do with the openings.
What about support. how flimsy did it get with out the supports?
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Before I put the supports in it was pretty flimsy. I had to tack weld a couple of pieces of 1X1 tubing across the bottom to keep it somewhat in shape while taking it off and putting it back on the car 20-30 times.
Now it is SOLID. Check out post #57 to see the supports.
I am very anxious to get this little project wrapped up but it rains EVERY DAY now and I don't have the luxury of a garage or even a car port. It's still sitting on my 89. As soon as the weather clears up I'll finish blocking it out so I can get a coat of paint on it......Then the rest of the build for my 89 will begin.
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Engine: LT-1
Car: 87 Trans Am
Transmission: 700r
Ok here we go you got me started. I gotta build one. Im heading to the junk yard today to get a spare hood. I am gonna use a hood off a Trans Am (with the vents in it) and keep the vents and try to make them active. kinda like that white one. my problem is I need the room for carb and air cleaner. Got a stupid question for ya what size of welder did you use? I got a 90 amp flux core. 1 other question did you have any trouble with ***** ping from heat? I will have to get my camera fixed to post pics of this project lol. Here are my ideas. Just a little different from yours. If I make the vents in the front active that should help with weat exchange also I would think kinda like ram air.
I hope no one minds me borrowing there pictures to make some sketches THANK YOU..........
Car: 87 Trans Am
Transmission: 700r
a little more color appropriate lol.
just a thought for graphics
Its kinda rough
This is my plan for graphics and hood only my car is being painted GM Red jewel tintcoat.
Ok last pic this is as close as I can get to red
Its kinda rough
Engine: LT-1
Go for it.
I used a 130amp MIG with .030 flux core wire. Yes, the flimsy stock sheet metal is going to ripple like hell if you're not careful with it.
Car: 1999 Camaro Z28
Engine: 5.7
That's awesome man! Great work!! Can't wait to see it "finished". I REALLY want a hood like Stephen posted about, I've had the idea in my head for awhile and he photoshopped it perfectly:
Engine: 305TPI
Car: 87 Trans Am
Transmission: 700r
I sure hope you didn't mind me using your pics to make scatches. Some people get upset.
Car: 87 GTA
Awhile back, right after he did the hood, I wanted to know what FYRCHKNs hood would look like on my car.....I want one without the extractor part though, for my GTA.
Engine: 5.7
Yup that's Stephen's. Nice looking GTA though huh? I might approach VFN about something like this next year if someone else doesn't do it. They made me a custom hood for my 70' not too long ago that turned out real nice.
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Engine: LT-1
I have a temporary car port..
It's a small tarp stretched out between some trees with ratchet straps and old extension cords. It worked great for painting my 91. Check it out:
Check out the link in my sig for the results. If Earl Schieb had this kind of setup maybe they wouldn't have so much dirt and crap in their paint jobs
Hey Black Knight...where at in Texas? This is a pretty big place.
.Hey Black Knight...where at in Texas? This is a pretty big place.
Engine: 305TPI
I don't care for the whole "hood is left unpainted/carbon fiber/etc." and the car being a different color. The graphics are also a bit too much. Then again I like clean appearances for these things. The hood is an awesome idea and depending on how things work, it would be a nice alternative to the cowl hoods which I think look like *** in general. Beyond that I'd like to see the same basic design without the GTA hood vents in the front. It makes the hood too busy for my tastes.
Despite my long list of thoughts on the idea, I really do like the design.
Car: 87 GTA
I know of a local place that PROBABLY would, if I had it in person to show them.
Engine: 5.7
I dunno, they used some in-house pieces to make a hood for my 70' so that might be why, since it wasn't really "one-off". There's a guy here local to me that will do Power Bulge hoods in fiberglass or carbon fiber
Engine: 305TPI
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
I wonder how hard it would be to do a simple copy of the IMSA hood. You make this stuff look too easy.
Car: 91 Camaro RS
Engine: TBI
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
THIS IS AMAZING make some for camaros and youll have my business
Hey kandied where da hood at??
Car: 86 Trans Am
Transmission: Pro-built 700R4
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
do you mind if i steal your design idea?
Unless you start making them in FG or CF i'll be forced to make my own lol.
Car: 1991 Firebird T-Top
Engine: 305 tbi
Transmission: t-5 manual
Axle/Gears: 3.08 Open
About time this got a bump. Any new progress?
Car: '91 TA vert
Engine: turboLSx
Car: 85 Camaro
updates?
Car: 92 RS(sold) 1989 IROC-Z
I think this hood is cursed anytime someone is working on it they pretty much disappear, and we never hear anything else about it lol, but I believe frychkn will pull through I have faith in his skills
Engine: LT-1
I still have it and it's still almost finished. My life has been VERY busy the past few months. Once everything slows down a little and I get time I will finish it up. It's mounted on my '89 at the moment and when I get around to prepping that car for paint I'm going to go ahead and finish smoothing out the hood.
It IS built though. Structurally it IS FINISHED. All that's left is a little smoothing work with filler to get it perfect...I'm kinda **** about how my finished products look.
Car: 85 Camaro
Oh i know itll get done im just anxious to see pics of the finished product this hoods been like a world wonder till now.
Engine: LT-1
How about an update?
I finally had a couple of nice weather days that I didn't have that J.O.B. interfering with my "car time". I had to let the car sit on the battery charger all day yesterday. I finally got it started around 7 pm yesterday and drove it around to the driveway from the back yard.
Today I did a little rough sanding with the palm sander to smooth out the mud that I put on it a few months ago. As I was looking at it I really don't have that much left to do for it to be perfect. There's not a whole lot of change since the last pics but now it's up in the driveway and I think I'm going to have some time to work on it now. The passenger headlight assembly is just sitting in the car. It's not even bolted up so that's why it's a little off. Also, the nose and the passenger fender are both just barely on the car with only a couple of bolts holding them on.
Here are current pics taken about 30 minutes ago:
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
i cant wait to see the finish product.
Even though im more of a camaro guy, that hood looks insane
Good work bro keep it up
