Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fuel Cell Mounting
Old Aug 30, 2009 | 04:58 AM
IROCFAST's Avatar
Fuel Cell Mounting
I am going to put a 16 gallon fuel cell in my car. I was considering mounting it in the rear "luggage well". Please post pics. Please do not tell me to use the search, I have...there is hardly anything on this subject that is relevant other than some people telling you to use the search. Also, if you do not have a fuel cell or have not mounted one in a thirdgen fbody, please do not post. I do not want to sound rude, I just do not want to have this flooded with uneducated opinions. Thanks in advance.
Old Aug 31, 2009 | 11:38 AM
Shagwell's Avatar
Car: projects.......
Re: Fuel Cell Mounting
Just for note, if you do a trunk mounted cell you will have to build a "firewall" that divides the entire back end of the car off from the passenger compartment.
I personally have never done a fuel cell in a vehicle that still had stock type flooring/trunk.
Old Aug 31, 2009 | 02:04 PM
zlathim's Avatar
Here's how we mounted an eight gallon fuel cell in the race car:
Shagwell is right though, you need to seperate the rear portion from the passenger compartment:
Hope this helps.
Old Aug 31, 2009 | 10:04 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
1badrZ's car
http://jweltonbrown.pho.to/albums/ge...im_f/index.htm
Old Sep 1, 2009 | 05:07 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Originally Posted by grover85
Good looking guy in picture 13. Thanks for posting Kevin. By the way it is a 12 gallon underneath there.
Old Sep 2, 2009 | 08:43 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Never noticed that. Creepy as hell.
Old Sep 6, 2009 | 08:07 PM
IROCFAST's Avatar
Awesome guys...thanks so much, this is what I was looking for. I really appreciate it!
Old Sep 16, 2009 | 01:35 AM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
here is how i did mine, if your interested.
Attached Thumbnails Fuel Cell Mounting-img1233788591343.jpg   Fuel Cell Mounting-img1233789064125.jpg   Fuel Cell Mounting-img1233788939948.jpg
Old Sep 18, 2009 | 06:02 AM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
why not just get a stock tank and sump it?
Old Sep 18, 2009 | 10:30 AM
1Aauto's Avatar
Former Sponsor
Some pretty goos ideas.
Old Sep 18, 2009 | 10:30 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Some people just want a fuel cell I guess.
Old Sep 20, 2009 | 07:55 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
ed quay makes a nice setup for our cars take a look give ya some ideas
Old Sep 21, 2009 | 11:49 AM
Shagwell's Avatar
Depends on a lot of things. For starters, it's not an easy job to get done properly on these cars, and line routing can be an absolute PITA. A lot of racers would preffer not to carry so much fuel(weight + safety), and only running a few gallons in the bottom of a stock tank could easily result in starvation.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
89fast5oh
Sep 27, 2015 09:04 PM
Elliswon
Aug 10, 2015 12:33 PM
