Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Home made “off road” engine stand?
Old Sep 11, 2009 | 03:49 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Any suggestions, tips or build plans to share?
I can probably stumble my way through making one but thought id ask.
Yea you can buy em cheap and could mod one but I know I can do better then starting with a cheap HF one.
I need to be able to push it through grass, stones and what not. Not a single piece of pavement anywhere.
Old Sep 11, 2009 | 03:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Home made “off road” engine stand?
buy one, then change the small casters out for some larger inflatable wheels that are strong enough for the load, not quite wheelbarrow tires, but same idea. Maytbe gocart or minibike tires
Old Sep 11, 2009 | 03:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Think I want to make it so it can raise and lower Like make the main stem i guess a pipe n a pipe, and use a cheap $10 bottle jack that can raise it up and down, to grab a engine out of the bed of a truck with out having to hoist it first, then onto the stand or just make it easier on my back so I’m not bending over, but also so it doesn't have to stay up high and be a tip over risk when not working.
HF does have em for $60 but it would need to be around $40 to make my idea worth it to chop one up. As id only be using the top and bottom parts, all new middle.
crude drawing, would need a tighter fit for stem.
Old Sep 11, 2009 | 03:40 PM
IROC UR WORLD's Avatar
I'm no expert, but I think your design will bind up.
Old Sep 11, 2009 | 04:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
nope, good point.
refresh browser, pic updated.
With engine weight pulling it down / to the right, the jack should be on the other side to help it bind less. But some grease and 10tons of force will make it go up, and gravity will make it come down.
Old Sep 11, 2009 | 06:39 PM
Better. Next question, Is a bottle jack going to give you the lift your looking for? You get what, 6 maybe 10 inches of lift out of one?
Old Sep 11, 2009 | 09:16 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Gumby looks like it should work but why dont you put a small piece of pipe for jack neck to go into so it wont or cant slip off under pressure.
Old Sep 11, 2009 | 10:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
big long bolts for pins like an older style jack stand.
jack up, pin, reset, jack pin. crude but no differ then putting a car up on stands, just 1/3 less annoying.
Old Sep 11, 2009 | 11:10 PM
Stephen's Avatar
Car: 87 GTA
Just make sure it has 4 wheels, not 3. My dad has a 3-pointer & even on smooth concrete, it is easy to push over, if you are trying to push sideways to how the wheels are pointing.
midge54
Sep 2, 2020 07:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
