Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
lets see some pics of your custom mods and/or fabrication
Old Nov 10, 2009 | 11:39 AM
  #201
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: lets see some pics of your custom mods and/or fabrication
Originally Posted by Stephen
You have 2 stereos in your car?
thats what I thought too, it's just two separate pics one ash tray open, one closed.
Old Nov 10, 2009 | 11:50 AM
  #202
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
You can obviously see that the top pic is the ashtray fliped open and the bottom is the ashtray flipped closed.
Old Nov 10, 2009 | 11:54 AM
  #203
Stephen's Avatar
Car: 87 GTA
I understand after ericjon262 said that, but if it had been obvious to ME, I wouldn't have asked. I saw 2 steros in 1 pic.....
No need to be a ***** about it being "obvious", much less that it was already explained. Your post was 110% unecessary.
Old Nov 10, 2009 | 12:02 PM
  #204
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
I think you are seeing the two photos with no space between them - note one photo is ashtray lid open, one is closed.
Old Nov 10, 2009 | 12:03 PM
  #205
Car: 1992 RS
Engine: Carbed 350
Unless ... it makes me that much cooler! Then YES, I have two stereos!
Old Nov 10, 2009 | 12:05 PM
  #206
Stephen's Avatar
Car: 87 GTA
Yeah....I realize now when someone pointed it out.
Old Nov 10, 2009 | 12:37 PM
  #207
ericjon262's Avatar
Old Nov 10, 2009 | 12:57 PM
  #208
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
obviously! haha
Old Nov 10, 2009 | 01:08 PM
  #209
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Old Nov 10, 2009 | 02:10 PM
  #210
Engine: 350TPI/ S50
I really didn't mean to offend any one by saying obvious, my sincere apologies to any one whom i offend by that, it was completely unintentional.
BTW i did not see the ericjon post, it was on the next page. i thought i was the first to answer the question on the two stereos.
Once again. SORRY.
Old Nov 10, 2009 | 06:38 PM
  #211
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Originally Posted by cprepared125
BIG_MODS great job. I had hoped to do all the gusseting to the body like you did but I really wanted to get my autocross car back on the track this season. I just ended up notching the windshield frame and welding the halo directly to it. I also notched the structure between the t-tops and welded it to the main hoop.
Thanks. I've decided to do it all at once. That way I only have to clean the paint off it once for welding and repaint it once. I missed this whole season anyways, car hasn't left the jackstands in a solid year now.
working in a sheetmetal shop i have access to the dies to do it
LUCKY!
Old Nov 15, 2009 | 11:17 AM
  #212
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Haven't got anything real exciting done on mine lately, just fabbed up a couple plates for the strut towers... The larger ones on the side are for the engine front plate mounts, the smaller ones will be for a brace tube running back inside the car to the cowl hoop..... Also lengthened the upper strut mounts to accomodate the lowered suspension... Still have to do some fabbing on the inside of the mount for the coilovers to fit where I want them......
Attached Thumbnails lets see some pics of your custom mods and/or fabrication-002-43-.jpg
Old Nov 15, 2009 | 01:37 PM
  #213
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Hey radical,
Where are you planning on running that exhaust to? If I were to do a turbo set-up I've thought about running the exhaust in that same direction but cutting a hole in the fender and letting it shoot straight out. That'd be way too loud for a NA car, but the turbo might quiet it down enough.
Old Nov 15, 2009 | 03:29 PM
  #214
radical82's Avatar
Car: '82 Camaro
Engine: 383
Originally Posted by BIG_MODS
Hey radical,
Not doing a turbo... Just a set of fenderwell headers and outside exhaust similar to the mid 60's Vette option... Not enough room under the car to put an exhaust system on it, car sits too low..... Going to be a stroker engine with mechanical roller cam, don't want to choke down the exhaust with Y pipe underneath the car....Frame ties are taking up the little bit of room that was under the car anyway...
Old Nov 15, 2009 | 03:37 PM
  #215
82blackout350's Avatar
Car: 1982 Camaro
Transmission: saginaw 4spd manual
Finally got both doors done, I dont know if i like how it looks, or what i should do differently...any thoughts or ideas?
Old Nov 15, 2009 | 03:44 PM
  #216
radical82's Avatar
Car: '82 Camaro
Engine: 383
Depends on how you plan on finishing the inner panels.... Will you be painting them, brushed finished, polished, or ??????
I think once you get the door handles in place and clean up the edges of the aluminum a bit it will look fine!!!! I used to polish the inside aluminum panels, but as I got older I've discovered that paint is a whole lot less upkeep!!!!!!!!!
Old Nov 15, 2009 | 03:59 PM
  #217
Car: 1982 Camaro
haha thanks, and i honestly dont have a clue on how im gonna finish the inner pannels, but right now im trying to decide if i should fab up a dash out of sheet metal, aluminum, or diamond plate..
Old Nov 16, 2009 | 08:51 AM
  #218
101btp's Avatar
Car: 86 Trans am
Engine: workin on a 383 for it!
Just finished the drivers side A-pillar up today:
Hey I had wanted to know did you put in the lightning holes your self?
Old Nov 17, 2009 | 11:54 AM
  #219
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Yeah, made templates out of poster board, transfered to sheet metal, hole sawed the holes, sent them to a guy to have the flaring done.
Old Nov 17, 2009 | 03:27 PM
  #220
101btp's Avatar
Car: 86 Trans am
ok was not sure if it was a job that you did to flare the holes?
how much did they run you for getting that done?
Old Nov 17, 2009 | 08:33 PM
  #221
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
About $80.
Old Nov 18, 2009 | 12:13 AM
  #222
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
check out this car. A lot of custom work.
http://www.camaroforumet.se/viewtopic.php?id=6577
the thread is on swedish but you can atleast look at the pictures its 4pages of pictures!
some samples
Old Nov 18, 2009 | 12:14 AM
  #223
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Old Nov 18, 2009 | 11:25 AM
  #224
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
that is pure sickness. Love it when someone takes the things they don't like about a car and says.. "i'll make it better"
Old Nov 18, 2009 | 03:53 PM
  #225
Engine: 350TPI/ S50
That decklid is sick. the entire car is pretty cool. But that decklid is just a great idea.
Old Nov 18, 2009 | 07:10 PM
  #226
Car: 1982 Camaro
Originally Posted by gta324
Dont think it is, but for a second i thought that was a fuel cell in the back! if so that is way bad @$$, car looks so good!
Old Nov 18, 2009 | 08:06 PM
  #227
Engine: 350TPI/ S50
Is it just me or does that decklid look C3 corvette inspired. Correct me if i'm mistaken but it looks king of like of the C3 rear decklid, coincidence.... maybe. Either way it is way cool.
Old Nov 18, 2009 | 08:43 PM
  #228
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
it looks like a vert decklid,
Old Nov 18, 2009 | 10:08 PM
  #229
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
It looks a little diff. Prob just sheet metal make for it.
looks like what i started with one of my old cars.
Vert trunk lid. then a lexan rear window.
Old Nov 20, 2009 | 02:03 AM
  #230
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Before
After
B&S 5.5hp lawn mower.
Polished head and piston. added a 0.000" head gasket, hotter plug and higher amp wire. K&N fillter. stright pipe with some muffling capabilities. modified carburetor and adapted a linkage to control the throttle blade. This mower spun an extremely high RPM at a almost wide open throttle to consistently keep it stable at such a high level of rpm the the blade had to be perfectly balanced. it was then field tested on many various items that one would find in a yard or in a alley, success!
Old Nov 20, 2009 | 09:15 AM
  #231
Firebat's Avatar
This reminds me of the C5 Z06 that was a regular corvette with a smaller back window. Looks sweet. Like to see more pics, especially from the side. Might want to do something similar if I ever buy a camaro.
Old Nov 20, 2009 | 09:21 AM
  #232
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Old Nov 20, 2009 | 04:17 PM
  #233
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
lol at the lawnmower.
who would have thought... high compression mowers.
pretty cool either way though.
now just put it on a kart and it will really be cool.
btw, a HS buddy of mine emptied a half a tank of N2O into a lawnmower (50 shot i think) and it held for the entire 2-3 minutes
i guess briggs and straton really knows how to build stuff to last
Old Nov 20, 2009 | 11:55 PM
  #234
procamaro85's Avatar
Car: 1985 Nascar Budweiser IROC replica
Engine: 358 CI .040 11.88 aluminum heads
Transmission: Muncie 4 speed
Axle/Gears: Moser Axles, Auburn Pro posi,410's
Looks like I'm not the only one that made some custom A pillars with plates, I just finished mine last week and painted the interior white. That and my custom made dash are my favorite mods I did........Frank
Old Nov 21, 2009 | 08:53 PM
  #235
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Looks nice Frank. You have any more pics of the dash and interior to show?
Old Nov 21, 2009 | 10:05 PM
  #236
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
x928347293849879 Frank, we need more pix of that bad boy.... Come on, cough 'em up!
Old Nov 21, 2009 | 11:45 PM
  #237
83 Crossfire TA's Avatar
Frank & BigMods... what are you guys planning on doing for the weatherstripping around the window/door... looks like you welded the plates to the flange that it attached over originally.
Otherwise, looks great, I've thought about doing the same myself.
Old Nov 22, 2009 | 12:02 AM
  #238
Thanks guy's, I don't have any side windows on my car so no weather stripping is needed. I smoothed all that out Nascar style. I'm building my car like a IROC race car from the 80's, but with some modern stuff too like the plates on the A pillars. It will have a old school look to it Nascar style. But here is a better dash pic.......Frank
Old Nov 22, 2009 | 08:53 AM
  #239
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Here,s a few of mine, more comming soon!
[Name:  100_0724-1.jpg
Size:  87.2 KBIMG]Name:  100_0727.jpg
Old Nov 22, 2009 | 09:12 AM
  #240
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
I'm putting weatherstrip back in mine. I didn't overlap the gussets with the original flange that held the weather strip. I took the original black weather strip "flange", put it on the car, scribed a line. Made sure my gussets didn't go in that area.
Old Nov 22, 2009 | 10:00 AM
  #241
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
anybody know were i can get the hockey stick stripes and stripes like this for the hood of my car
Attached Thumbnails lets see some pics of your custom mods and/or fabrication-ss850046.jpg
Old Nov 22, 2009 | 10:51 AM
  #242
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
you mean for the side of your car?
bc unless im losing my eye sight those stripes arent on the hood
but try ebay and pheonix graphics
Old Nov 22, 2009 | 11:33 AM
  #243
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Dean, more pix of your center dump exhaust? I was going to do something similar after my IRS swap is done but I'm not sure I want to cut my rear bumper cover.
Old Nov 22, 2009 | 11:34 AM
  #244
kennyglm's Avatar
Car: 87 irocz
Engine: 5.0
both the hockey stripes and the hood stripes
Old Nov 22, 2009 | 11:48 AM
  #245
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
oh ok.
Old Nov 22, 2009 | 01:20 PM
  #246
radical82's Avatar
Car: '82 Camaro
Engine: 383
Originally Posted by procamaro85
Thanks guy's, I don't have any side windows on my car so no weather stripping is needed. I smoothed all that out Nascar style. I'm building my car like a IROC race car from the 80's, but with some modern stuff too like the plates on the A pillars. I don't want to show any current pic's of the body yet because I haven't applied my custom decals yet. It will have a old school look to it Nascar style. But here is a better dash pic.......Frank
Great looking car!!! and the dash is very first rate and business like!!!! Very well done!!!!
Old Nov 22, 2009 | 02:01 PM
  #247
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
yeah, love that dash, someday I want to do something like that, keep it very simple, very clean.
real nice!
Old Nov 22, 2009 | 05:12 PM
  #248
DeanJ's Avatar
Engine: LS6
[IMG]http://i194.photobucket.com/albums/z171/stitchergigi/Cars/100_0747.jpg
[/IMG]
There's more to this than you can see in the pics. The trunk well has been cut and raised about 6". I originally had them under the bumper, NASTY looking. If you aren't willing to cut and raise it all, I wouldn't do it. Later, Dean.
Old Nov 22, 2009 | 05:15 PM
  #249
DeanJ's Avatar
Engine: LS6
More pics!
Old Nov 22, 2009 | 05:17 PM
  #250
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
those are nice exhaust tips. I like it.
