Shorten stock shifter rod
i have a 1992 Camaro RS 3.1L V6 with a 5 speed trany..what i have been wanting to do is cut the stock shifter rod shorter and re-thread it, just so it is physically shorter.
is there anything bad with doing this..will it still shift correctly?
is this okay to do?
thanks
is this okay to do?
thanks
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Shorten stock shifter rod
No. Yes. Yes.
If you want the benefit of a real short throw, you might consider one of the after market versions.
JamesC
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Wouldn't it be easier to chop a section out of the middle, then weld it back together? That way you don't have to mess with re-threading it.
yeah..but i just want a shorter handle..i would eventually like to get a short throw shifter..but for now i was just wondering if it would mess it up any cutting it shorter?
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
I did this to mine a year ago, i cut it so short that the top of the shift **** is only an inch above the top of the console.
no problems with it at all.
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
When my shifter broke from too many speed shifts, I cut the two surfaces off flush and welded it back together. It still retains the stock **** thread but is a good bit shorter than stock...a quality short throw, limited travel shifter would be much nicer and have a larger variety of ***** available, but this works for a guy on limited funds.
ambainb
Apr 25, 2016 09:21 PM
NBrehm
Aug 25, 2015 11:49 PM
Dialed_In
Aug 20, 2015 01:45 PM
