Space saver spare inflator
Car: 1986 IROC-Z28
Engine: 5.0 TPI
Axle/Gears: Factory axle,and gears
I have an 86 Iroc with the space saver spare,that came with the tire inflator. The label is peeled off,so I have no directions on how to inflate the spare. Can someone please tell me how to do this? Also, can you air up spare like a normal tire,with a valve stem,or does these spares not have one? Thanks!!!
Car: 1990
Axle/Gears: stock
Re: Space saver spare inflator
most just let you screw in the tank and it will inflate. look at the screw in part and it should have a fitting opposite to the tire itself allowing filling the tire, like a gas station hose.
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
i have one of these to.. its a lil blue cylinder right? i think u need a hose because the threads are on the outside of the fitting.. or they are on mine atleast.. i have the cylinder but not spare tire lol
You can inflate the space saver spare with regular air (30PSI is max). The cylinder can also be refilled with compressed air (try a dive shop or fire ext. place). I have only used my spare once in 22 yres and I had AAA road service fill it for me when I had a Flat.
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
I looked long and hard to put all the spare tire pieces back together.
IIRC the label on the inflator says to use it just like any air pump, put it over the valve and push. It also says they have to be refilled at a GM dealer! (Yeah right) and are charged with C02.
You can see the valve on the collapsible spare in this pic.
Car: 87 camaro iroc
Engine: 5.7L
What did these kinda of spares come with?
i have an '87 Iroc and it just as a normal donut tire..
I've never seen anything like in this picture before.....
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/brak...e-4th-gen.html
JamesC
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
In general full size (inflatable) spares were for posi equipped cars.The smaller(inflated) was for open differential rear ends.
air, collapsible, gm, inflate, inflator, kit, refill, saver, space, spacesaver, spare, spareair, sparetires, tire, tires
