Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Post up pics of your custom dash!
Old Nov 3, 2009 | 08:17 PM
F-Body Demon's Avatar
Hey guys, im starting a ultralight dash project on my GTA and I was wondering if anyone on here has done one yet? I searched and found one custom dash made of wood... coughfirehazardcough. But thats all.
Anybody?!
Old Nov 5, 2009 | 09:01 PM
Orangepeeler's Avatar
Re: Post up pics of your custom dash!
I'm in the middle of installing a fiberglass dash that looks very close to stock. I'm trying to get all the weight out of the car and still be able to drive on the street. I have an ARC switch panel and Racepak dash that will be mounted to the frame behind the dash. I will try to post the pics tomorrow night.
Old Nov 6, 2009 | 10:45 AM
Exactly! Im going for a similar idea, to minimize the weight of the car but maintain functionality of a street driven car.
Old Nov 7, 2009 | 06:22 PM
Well, you will have to excuse all the dust. It has been an ongoing project for a couple of years now. Damn economy!! Here are the pics of how I did my dash. I know it is not for everybody but, please be constructive with the criticism.
Here's how I mounted it:
That's it. Hope it will give you some ideas.
Old Nov 7, 2009 | 09:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Nice mount design although it looks heavy. Nice steering column support.
This is what my dash looked like for a few years. I'm in the process of rewiring the car so I finally ditched this dash and made one completely out of aluminum.
Old dash, or at least the best picture I had of it taken back in 2007. The dash pad was cut on both ends to fit around the cage tubes. The face of the aluminum panel is covered with some decal material that I picked up from Walmart.
This is what the new dash looks like. I just made and installed it today. 0.032" thick aluminum. I need to make a few more braces for it and need to wire up the gauges and tach. Nothing but an oil pressure warning light, oil pressure, oil temperature, coolant temperature. All the toggle switches and a voltage gauge are mounted in an overhead switch panel which can just be seen at the top left. With the 5 point harness cinched down tight, it's easier to reach the switch panel than the dash.
Old Nov 8, 2009 | 09:32 AM
Stephen, your dash turned out well. I've been following the re-wire and it's turning out very well also. The dash is not as heavy as it might look. I think the fiberglass part is only like 6 lbs. The mount part is made of .049" CM so it is actually pretty light too. I wanted it to look as close to stock as a fiberglass replacement could. I was happy with the way the steering column worked out. Got all of the supplies from Larson Race Cars. He gave me a little guidence as to how he might do it. Still have a ways to go but, I will try to update as I make progress.
Old Nov 17, 2009 | 01:15 PM
Justinlf16's Avatar
wow bro you got a nice ride i bet you got 50k in that car
Old Nov 18, 2009 | 12:30 AM
my-roc's Avatar
Car: 1987 Camaro IROC Z-28
Engine: 305 T.P.I.
Transmission: 700 R4
American Flag Dash. This isn't what ya may be looking for but it doesn't hurt to look. I did complete dash strip down to metal and built it back up and made the flag on it. All 50 stars and 13 stripes. It is an ongoing project,final surface isn't finished. It will be flat black in color though.
Attached Thumbnails Post up pics of your custom dash!-0407071608b.jpg   Post up pics of your custom dash!-8-5-2007-8   Post up pics of your custom dash!-7-16-2009-12
Old Nov 18, 2009 | 02:52 PM
88camaroluvr's Avatar
What did you use to build the foam back up, my-roc?
Old Nov 18, 2009 | 03:01 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
orangepeeler, that is freakin AWSOME!! how did you mold that whole structure with (appears to be) ONE piece???
Old Nov 18, 2009 | 07:53 PM
It's actually a fiberglass dash made by Hairy Glass. I chose it because from a distance you can't tell it apart from the stock dash. It even has the grain in the dash top, so when the doors are closed it REALLY looks stock. Thanks for the replies.
Old Nov 18, 2009 | 11:55 PM
my-roc's Avatar
Engine: 305 T.P.I.
I stripped it down to metal,then had some rubber matting i used for the first layer.Then I used a yoga mat from target.You can see the texure of the mat in the pic of my windshield vents. I do have all the vents cut and fitted to fill in gaps. It came out real nice.
Attached Thumbnails Post up pics of your custom dash!-p4170023.jpg   Post up pics of your custom dash!-10-13-2007-3   Post up pics of your custom dash!-7-16-2009-12
Old Nov 18, 2009 | 11:59 PM
my-roc's Avatar
Engine: 305 T.P.I.
Steven, how do I get my pics to be normal size like yours. Mine are thumbnail attachments.
Old Nov 19, 2009 | 02:58 AM
my-roc's Avatar
Engine: 305 T.P.I.
I just made an album of all the pics from my dash restoration, in order of progress. I don't know how to make a link to view them. So if ya want, click on my name, then pictures. I only have 1 album right now. It is of my "Flag Dash".
Old Nov 21, 2009 | 08:18 PM
zzzzknightzzzz's Avatar
Car: 1992 RS CAMARO 25TH ANNIVERSARY
Engine: 305 TBI
have you tried vaccume forming its very simple to do and its fun .well i dont know how much it will cost you for the plastic but to make the machine is like 70 bucks.all you need is a 6ft by 4ft piece of peg board 2 6ft 2by4s 2 4ft 2by4s a 6ft by 4ft piece of mdf or plywood whatever is cheaper it would be the ply cause mdf is 35 t0 45 dollars a panel. and a shop vac a 10 gallon would work and some heating coils . and you heat the plastic drop it on your dash thats off turn the vac on and it basicly copies your dash pad and it very detailed so whatever you dont want on it fill it in with putty and mod it but you get great results by that but google vaccume forming and watch it on you tube the skys the limit when vaccume forming .you can redo your interior plastic pieces or mod them you can make your own anything and its cheaper and less messy than fiberglass well i hope this helps you or anybody maybe get the creativity flowing
Old Nov 21, 2009 | 08:44 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
dude, that sounds pretty neat, ima have to look that up, because I have my interior out of my car, and im loooking into different mods
Old Nov 21, 2009 | 08:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Your thumbnail pictures are because you're using TGO to host your pictures. My pictures are hosted on my own domain and I simply use the IMG tags to display the picture URL. To use the IMG tags, the picture needs to be hosted somewhere on the internet. For the forum, try keeping the pictures no larger than 800x600.
Old Dec 3, 2009 | 07:24 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
A/C blockoffs short console and 4th gen gauges
Old Dec 3, 2009 | 08:18 PM
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
very very nice
Old Dec 4, 2009 | 02:30 PM
amng04's Avatar
Car: 1980 Malibu
Engine: 496 BBC (E85)
Transmission: TH400 w/brake
Axle/Gears: Moser 12 bolt 4.10
some nice custom work by you guys, here is a pic of mine
Old Dec 4, 2009 | 03:09 PM
stroked_n_blown's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: Richmond Gear street 5 speed
from VFN
82-92 Camaro One piece Dash . Weight=4 each Ship: UPS Items. Price=$279.00
Old Dec 11, 2009 | 12:13 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
wow thats a nice dash
Old Dec 13, 2009 | 02:48 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Huh, I wonder why I've never seen that dash before this... Pretty slick
Old Dec 19, 2009 | 09:23 PM
fenton06's Avatar
This is what I'm doing eventually
Old Dec 21, 2009 | 01:16 PM
BPWilliams's Avatar
These are the early pics of my dash in my AI car. KISS aproach!! I will post soem finished Pics when I get done.
Attached Thumbnails Post up pics of your custom dash!-dsc00191.jpg   Post up pics of your custom dash!-dsc00189.jpg   Post up pics of your custom dash!-dsc00194.jpg
Old Dec 21, 2009 | 08:45 PM
BPWilliams's Avatar
here it is complete...
Attached Thumbnails Post up pics of your custom dash!-dsc00197.jpg   Post up pics of your custom dash!-dsc00198.jpg
Old Dec 30, 2009 | 10:51 PM
thenjoshsays's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: 4th Gen/3.23/Posi
Hey - Do you have any more info on how you put just the 4th gen gauges in there? I really like that. I don't care much for full 4th gen dash swaps because I think the 3rd gen interior fits the car stylistically. Your approach seems like a nice compromise...
Old Jan 10, 2010 | 10:59 PM
91ls1t56's Avatar
Car: 91 Z28
Cut trim and fit. Once you start you cant go back,get a spare dash from 91 - 92 .
Old Jan 10, 2010 | 11:10 PM
Car: 92 RS
Engine: 305 TBI
Any pics of it closer up? Detail shots? I have no problem with going all-in... I just wouldn't mind seeing how it came out before I give it a shot.
Old Jan 11, 2010 | 03:56 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
is that some kind of aftermarket 1 peice dash like the 3rd gen above?
if so where can i get 1?
Old Jan 11, 2010 | 09:20 PM
91ls1t56's Avatar
Car: 91 Z28
Attached Thumbnails Post up pics of your custom dash!-pooters-pics-062.jpg   Post up pics of your custom dash!-pooters-pics-063.jpg
Old Jan 14, 2010 | 02:35 AM
procamaro85's Avatar
Car: 1985 Nascar Budweiser IROC replica
Engine: 358 CI .040 11.88 aluminum heads
Transmission: Muncie 4 speed
Axle/Gears: Moser Axles, Auburn Pro posi,410's
Here are pic's of two different ones I made, the first pic is with the factory dash with a custom panel added on for the Autometer gauges. I painted it with VHT wrinkle paint so it matched the dash.
This is the current one I made(same car) out of aluminum, "Nascar style"
Old Jan 14, 2010 | 11:28 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
how hard is it to install those autometer gagues... I have no idea where to start!
Old Jan 15, 2010 | 10:58 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
After looking at some of these ideas I'm really thinking about making mine a reality. I want to do a custom dash for electronics on mine, and hopefully keep the 91-92 styling.
Old Jan 30, 2010 | 10:53 PM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
I emptied out the entire dash & the only thing there now is the top dash pad & the facia w/ 1/4" ABS plastic cemented to the back of the facia & holes cut out for the AutoMeter gauges sitting in the factory location.
Old Jan 31, 2010 | 12:01 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
pretty sick dashes..wish i had the time :P
Old Feb 17, 2010 | 11:37 PM
Project-RS's Avatar
i started on mine again after putting it to the side for a few months. the dashpad is fully fiberglassed with no vents at all now. i took all the vents out the dash and now ready to do step 2 of the radio instal
Old Feb 28, 2010 | 10:17 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Here's mine. I made the guage cluster myself. All the AutoMeter guages are electric including the speedometer. All the AC ducts have been taken out of the dash. I also removed the box for the evaporator and heater core. Its completely empty behind the dash except for wiring, which you can unforunetly see throught the AC vents. The two cirles under the small guages in the middle are LED's. They are for the turn signals.
Never mind the ugle hood
Old Mar 1, 2010 | 09:57 PM
Spifz's Avatar
Car: 1986 Z28 / 2012 CLS550
Engine: F-1R -> Aluminum block 540
Transmission: T56 Magnum + GForce gears
Axle/Gears: Ford 9" 3.00's + Eaton Truetrac
The aluminum dash wraps all the way down and around, about 10 inches short of the firewall so you can't see anything but carpet unless you really get down. Behind is an amplifier and computer. The top is wood/fiberglass wrapped in fake leather. The computer is a single board 1.6Ghz with a SSD drive running Linux and my own interface to the Holley 950, cameras, gps, etc. Center gauge on drivers side is the Autometer D-PIC. I'm working on the center console.
Attached Thumbnails Post up pics of your custom dash!-img_0113s.jpg   Post up pics of your custom dash!-img_0116s.jpg
Old Mar 1, 2010 | 10:34 PM
Am I seeing that right? Do you have a tach and speedo for the passenger too? I like it
Old Mar 1, 2010 | 10:37 PM
Car: 92 RS
Engine: 305 TBI
Ya I noticed that too... what's the purpose of that?
Old Mar 1, 2010 | 10:43 PM
  #42
Spifz's Avatar
The passenger side gauges are navigator gauges, so they have a speedo/odometer for target time/distance events or road races. And where there is a speedo, might as well have a tach, eh.
Old Mar 2, 2010 | 07:44 AM
  #43
EvilCartman's Avatar
Car: '82 Z28
Here's the one I did a while ago.
Also made this about 8 years ago since I took out the stereo.
Old May 6, 2010 | 07:36 AM
  #44
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Are your speedo and tach 5" gauges?
Old May 6, 2010 | 12:11 PM
  #45
Spifz's Avatar
Most of the tach/speedos on the page look like the larger autometer 5" gauges. They do make an intermediate size, 3 5/8 or something. You can fit a 5" in place of the factory stuff with a bit of plastic trimming; I originally had mine mounted behind the factory front black bezel with the clear plate removed.
Old May 6, 2010 | 02:49 PM
  #46
Engine: 355 chev
i figured they were 5's but i was just making sure
Old May 17, 2010 | 08:08 AM
  #47
500+hpta's Avatar
Car: 1984 trans am
Transmission: 350
I gutted everything behind my dash and just used the shell.
Old May 17, 2010 | 12:55 PM
  #48
bohndog's Avatar
Car: 1984 Camaro Z-28
Engine: 5.0 HO L69
Did you make that steering wheel? I like.
Old May 17, 2010 | 05:20 PM
  #49
500+hpta's Avatar
Car: 1984 trans am
Transmission: 350
Yep totaly clear you lie it? I havn't figured what steering wheel to go with.
Old May 17, 2010 | 09:53 PM
  #50
Engine: 355 chev
Let me know how this goes. i have a TV that installs in a radio slot, that i'd like to put up there
