Fab-work Request?
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Fab-work Request?
I'm looking to have something small made. Basically want a gauge pod and aux port box made that fits under the two middle vents but doesn't exceed the width of it, something i could just bolt under it.
[heres a quick sketch of something]
I just wanted something kind of to look like factory not just slabbed in there like a pillar pod with black duck tape... lol maybe some ideas might make me think of something else. I just have times where I have use to use all 3 aux ports and I'm kind of wanting to add a 3 gauge row.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Fab-work Request?
...guess not? I'm just trying to figure out a clean way to add more aux ports and gauges without making it look bad but still have it look like its almost stock.
you know like subarus wrx can change out their top dash pad center piece for a gauge pod or something.. i don't know. I just need ideas how to add more aux ports, gauges, cup holders? ideas & pictures would help.
you know like subarus wrx can change out their top dash pad center piece for a gauge pod or something.. i don't know. I just need ideas how to add more aux ports, gauges, cup holders? ideas & pictures would help. Banned
Car: 87 GTA
Give people more than 1 day to see your post & respond.
Patience young padawan.....
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
i'm excited to put some ideas into my car. I just want some people who have gone through the trouble already and know what they did. I want something to come out looking good and not bad :\ don't want to ruin the car to much
Car: 87 GTA
Check out electronics places like Radio Shack/Fry's....etc. For something in the hobby/experimental areas.
You might find a box there, that will suit your needs.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Hmm maybe..
btw I have that overhead hvac light that's right below the center vents. is that 12v? if so i could just parallel the 12v to the gauges and aux ports.
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
what about sheet aluminum covered with black vinyl?
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't have any measurements handy. The pod in the picture was put in by the car's original owner when it had a turbo. It was bent from sheet aluminum and tig welded together. I wanted to make a taller version of the same thing to mount another row of gauges, so I built a wooden jig with dowels to bend some sheet styrene around while softened it with a heat gun. I never got around to putting it into the car though.
tonys91rs
Oct 10, 2015 03:31 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
any measurements or anything of how you did it?
