Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
fuel flush
Old Feb 8, 2010 | 03:49 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
fuel flush
i didnt know exactly where to post this but i fabbed a fuel sump and welded it to the bottom of my tank but now i want to make sure theres no junk in the gas tank what is the best way to flush a tank out while its in the car?
Old Feb 8, 2010 | 05:21 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: fuel flush
Run the car? Let it plug up the filter, and change the filter a few times.
Q-jet filters are $1.88 each, i'm not sure what kind of filter you have there?
Old Feb 8, 2010 | 06:18 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: fuel flush
that's a horrible idea there sonix. wow.
hook a garden hose up to the tank and shove it in the fill port where you'd pump gas and let it run for a while. It'll flush everything out the sump. Then blow compressed air into the tank until it drains out and hook your lines up and fill with gas.
Old Feb 8, 2010 | 07:47 PM
Pocket's Avatar
Car: 91 Trans Am
Re: fuel flush
How did you weld a sump onto the tank with it still having remnants of gas in it?
+1 on the garden hose. There shouldnt be much in there. A few specks of rust and a few grains of dirt maybe
Old Feb 8, 2010 | 09:32 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: fuel flush
ok ill do the garden hose. no i drained the gas and washed the inside out with simple green the inside was still in great condition im just worried about some of the spatter that may have gotten in the tank while welding and whatnot. thanks alot i appreciate it...the worst thing about that idea is it is about 20 degrees here so i wont be able to do that anytime time soon. thanks again for the help fellas
Old Feb 9, 2010 | 02:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: fuel flush
I suppose you can do it anyway you like, my suggestion was because I had no idea what contaminants he was trying to remove (ie, sludge, rust, scale, welding slag, etc etc). I am uncomfortable using water due to internal baffles. I am never sure if you can easily get all the water back out? Plus due to the configuration of the tank (ie filler neck) it's hard to get an air gun in there far enough to dry it out reliably. Water will sink to the bottom of the tank (below gasoline) and will be pumped directly through a fuel filter into your engine. I would rather have some chunks of dirt/dust etc go through my fuel pump and into my filter, than water. But as I mentioned, I had no idea what contaminants were expected, what pump style is used, and what filtration medium is used.
I originally was going to recommend flushing it out with a gallon of solvent (varsol, paint thinner, etc) since it will burn with your gasoline, or more likely, flash off and dry before you're done.
Old Feb 9, 2010 | 03:19 PM
Pocket's Avatar
Car: 91 Trans Am
Re: fuel flush
Dump a cup of rubbing alcohol in there and any trace of water will evaporate
Old Feb 9, 2010 | 04:15 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: fuel flush
ok i will do that thanks alot guys i really appreciate it maybe when i fill it up with the e85 ill pour some heet in with it
Old Feb 9, 2010 | 06:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: fuel flush
Acetone works too and might be easier to find in larger quantites.
Old Feb 9, 2010 | 07:24 PM
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
Re: fuel flush
excellent. ideas keep getting better and better thanks
eightsixseven
Dec 16, 2024 01:50 PM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
LittleFranks
Sep 17, 2015 12:22 PM
z28_AJ
Aug 27, 2015 08:59 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
