Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Tow hook mounting?
Old Feb 11, 2010 | 11:00 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Tow hook mounting?
I'm planning on doing some track days with my car, and as long as its apart I might as well add some tow hooks just in case (and to help get it in a trailer instead of wrapping a strap around the axle!). I've seen some pictures of them poking out under rear bumpers and through the front grille, but where are they being attached under the car? Are the bumper mounts strong enough?
Old Feb 11, 2010 | 12:26 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: Tow hook mounting?
I'd like to see some tow hooks also, specially front hooks on Firebirds...
Old Feb 11, 2010 | 03:00 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
How about right here.
http://www.camaros.net/forums/showthread.php?t=171132
Or a write up on location placement.
http://www.ehow.com/how_5954186_hook...vy-camaro.html
Old Feb 11, 2010 | 03:18 PM
HCR13's Avatar
Car: 1987 Trans Am
looks pretty cool. I'd like to see hooks that slide out, I wouldn't want a red hook sticking out the front on my daily driver...
Old Feb 11, 2010 | 03:23 PM
Stephen's Avatar
Car: 87 GTA
Mount them in a square tube, like the slide-in receivers for trailer hitches. A flat bar could be mounted like a Class 1 hitch. Short rectangular mount for a simple bar, like that tow hitch above.
Old Feb 11, 2010 | 03:36 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Would either of those work on a third gen though? Both of those links talk about bolting through a frame, I'm not sure how well that would work on the unibody. That sheet metal doesn't look strong enough to be dragging a 3000+ lb. car around..
What about a straight shot off the K member? Assuming the steering and sway bar aren't in the way..
Old Feb 11, 2010 | 06:37 PM
HCR13's Avatar
Car: 1987 Trans Am
yeah, I thought about using the tow hitch idea before. I'm not quite ready to do this mod, so I haven't given it alot of thought...
Old Feb 11, 2010 | 08:20 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
You could eaisly make something to work in the fog light holes. I made one at work that retracted. I looked similar to the one pictured above. I mad to three inch slots. Added a spring and it worked great. Slid out when being pulled on and slid back when no pressure was on it. Sorry no pics. Plus it was on a vette.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
TBRays98
Sep 6, 2015 05:05 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
