Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
deleting AC keeping heat...
Old Feb 13, 2010 | 01:46 AM
tylerrentays's Avatar
Car: 1987 Z28 Camaro
Engine: TPI 5.9
Axle/Gears: 3:11
im sick of that ugly condensor in my engine bay im not even using air conditioning,
but i defintalty want to keep my heat?
is there a special box i need?
is this what im looking for?
http://cgi.ebay.com/ebaymotors/82-92...item439d355cd9
thanks in advance
Old Feb 13, 2010 | 06:17 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: deleting AC keeping heat...
Thats exactly what you need. and reluctantly that is one of the tgo members on this forum. JohnInRI
Old Feb 13, 2010 | 06:30 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
thanks in advance
I used to throw these out.. Now they are worth a fortune!
Anyhow, a mid 80s/early 90s S10 will have the same box. Check the local junkyard.
Makes it a lot easier to tighten #8 header tube.
-- Joe
Old Feb 13, 2010 | 07:57 AM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
-- Joe
If I grab one of these would my heater still work? I dont want the A/C though.
Tony.
Old Feb 13, 2010 | 08:08 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Tony.
Yeah they are just heat only boxes. S10 and fbody shared a few things, such as rear end gears, heater box, blower motor, I think steering column is similar, front brakes.
-- Joe
Old Feb 13, 2010 | 08:29 AM
Engine: 3.0L 2JZGE
How much would you espect these to run at the local junk yard?
Thanks. Tony.
Old Feb 13, 2010 | 10:28 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I got one of these for roughly 100$ from thirdgenranch awhile back... Installed it (was newly painted and i think new blower motor).. WOrks like a charm but only has 3 levels instead of the 4 levels i had with the AC version... Still good, not like you need heat blasting at level 4 anyways lol.. REALLY cleans up engine bay, less weight, and makes it easier to work on passenger side motor!
Old Feb 13, 2010 | 10:44 AM
one92rs's Avatar
Car: SOLD!!!!!
i put one in mine fron third gen ranch. i to only had three speeds at first. i then wired in the relay and had fourth. now i have all four speeds and the factory a/c resistor.
Old Feb 18, 2010 | 12:07 AM
rybread11's Avatar
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
Hey guys, is there a detailed drawing or schematic of that box somewhere? I was thinking I could just make one out of sheetmetal or something. I always wanted to do that mod but havn't gotten to that yet. I'll bet it sure does make getting at 8's header bolts alot easier. that furthest back one is a real pain. In case it helps, I made sure to get header bolts with the smaller head size, I think its 3/8's instead of some that have the 7/16th. For you guys that have hedman's I think you need those anyway, but my newer hookers could get by without them.
Old Feb 18, 2010 | 08:06 AM
Pocket's Avatar
Car: 91 Trans Am
Trace the perimeter of the HVAC box and go from there. The design really isnt very complicated
Old Feb 18, 2010 | 08:51 AM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
I scrapped my ac compressor to get rid of that assembly. I never used my ac anyway, and my heater still works! But this box is pretty nice. I didnt even know about it. I will have to check into that.
Old Feb 18, 2010 | 11:31 AM
Pocket's Avatar
Car: 91 Trans Am
Assuming you just removed the HVAC box and covered the engine bay holes, your heater system will still function. You just wont have any control on how fast it comes out. Itll still bleed out
Old Feb 18, 2010 | 06:08 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
-- Joe
Really? if it just bolts in then Im going to go rummaging in the junk yard soon.
Old Feb 18, 2010 | 06:45 PM
camaro379's Avatar
Car: 1986 camaro z28
Engine: 355
Transmission: turbo 350
got one from junk yard for $15.00 a couple years ago. it saves a ton of space all while retaing the use of heater and defog. i have hooker super comp headers that feature a removable # 8 tube , by loosening that tube i can change the starter from the top side. one of the best modifications i have made to my 86 z28 and best of all it was cheap and easy
Old Feb 19, 2010 | 09:53 PM
rybread11's Avatar
Engine: 40 over 350
Transmission: 86 T5
So there isn't any baffles or anything inside the box?
Old Feb 19, 2010 | 11:25 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Here's some pics if it will help.
Attached Thumbnails deleting AC keeping heat...-dsc02296.jpg   deleting AC keeping heat...-dsc02297.jpg
Old Feb 21, 2010 | 01:14 AM
rybread11's Avatar
Engine: 40 over 350
Transmission: 86 T5
Thanks for posting up the pics! These will definetly help me when I get that far.
Old Feb 21, 2010 | 05:25 AM
Scorpner's Avatar
Engine: V6, V8
No problem, had them on the hard drive so it only took a second. Good luck with it and post pics if you come up with something.
Old Feb 21, 2010 | 10:00 PM
rybread11's Avatar
Engine: 40 over 350
Transmission: 86 T5
Will do.
Old Feb 21, 2010 | 10:25 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Don't mean to hijack thread but is it okay just to pull the tubing and the compressor out and leave the silver canister in the heater box?
Old Feb 22, 2010 | 08:19 AM
Pocket's Avatar
Car: 91 Trans Am
People do it all the time. The biggest issue is any remaining freon left in the system when the lines are first cracked open. It is HIGHLY toxic, both to you and the environment when released to the atmosphere. If the lines are empty, you can remove whatever you like without consequence. It just looks terrible
Old Feb 22, 2010 | 02:03 PM
JTNKTZ's Avatar
Engine: 355/350
Well my AC doesn't blow cold so I think I should be fine right?
I plan on making it look good it's just for temporary though.
Old Feb 22, 2010 | 02:55 PM
ShMaCk2004's Avatar
I don't know if you remember when I showed you under my hood or not but thats what I did. I think I may have said something to you about getting an s10 heater box or maybe it was someone else...anyway go for it.
Old Feb 23, 2010 | 10:15 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
ok same cuestion but lil different... if i get rid of both heater and ac... do i have to bypass any relays or plugs? or can i just leave the there hidden????
Old Mar 25, 2010 | 04:15 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
Watch out for which s10 you get a box out of!! I got one out of a 84 s10 and it doesn't quite match up as well as the ones that I have seen on here. I think you need to get it out of a S-10 that is at least a 91.
The box I have doesn't bolt up at all, and the blower fan doesn't line up with the hole in the firewall.
check out my thread:
https://www.thirdgen.org/forums/cool...eater-box.html
Attached Thumbnails deleting AC keeping heat...-84-s-10.jpg   deleting AC keeping heat...-91-s-10.jpg
customblackbird
Oct 1, 2015 04:30 PM
pacoelrapido
Sep 11, 2015 02:41 PM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
mantaguy
Sep 2, 2015 10:42 PM
