Ford 8.8 to replace the 7.5
I decided to try and build a ford 8.8 for my car out of a 92 explorer. I am going to go with a mini ladder bar setup which will work fine for my application eliminating the torque arm. I decided to use the 8.8 which was by far cheeper to start with. The ring gear is .075" smaller then the gm 12 bolt which measures 8.875 , so strength is not the issue with this axle plus it comes with a 31 spline posi carrier.
Last edited by ck88camaro; Mar 12, 2010 at 07:46 AM. Reason: Updating link photos, removed link..
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Ford 8.8 to replace the 7.5
WOW!! How straight did the tubes stay? Also, why did you add that to the lca? I assume your still running a torque arm right?
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I like that, cool custom work. Haven't seen that exact kind of design for the control arms, but looks good. I think you'll be surprised how that setup will lift the back-end up when you get on the gas.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm thinking the same thing. Welding all the way around the tube for the sleeve will have warped the tubes. I doubt the axles are lined up properly. be prepared to break an axle.
Those "lift bars" are junk. You went through all the trouble to install a better diff than the 7.5" and took a step backward with junk suspension.
As far as the axle tubes being welded I had an alignment bar machined that center in an old carrier with out the spider gears, then I had it machined to firmly press into the axle bearing which I replaced. As far as my " junk lift bars" are concerned, if g-force suspensions make them for camaros, which they have time and research in , they are good enough for me. Thank you for you constructive opinions!!!
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Looks great!
Can you put up some pics of the alignment bar for the axle tubes?
Wouldn't it be easier to just have welded the Camaro spring perches and bearing axle tube ends onto the Ford tubes, saving the need to align the tubes?
All that work too, and still have the drums..?
I am sorry, of all the pics I took I did not snap one of my alignment bar. Just had it machined to fit the carrier and then had the wheel bearing end machined to 1.401" when I was done welding just pulled the bar out. I did tack weld at 12:00-6:00-3:00-9:00 on my tubes to start with then filled them in oposite axle sides to keep the heat down. I could have welded the brackets to the axle tubes but the explorer has offset axles. That would not have worked. I could have used a mustang axle which has 0 axle offset, but people are proud of those things around here. Now as far as my high dollar drum brakes, come on give me a break here!! Ha.. If this all works out ok I will put more $$ into it later and upgrade. This has been fun project so far. I want to add one more thing, I got alot of my info on this from ls1tech.com. Alot of camaro guys there to, heck ya!! So take the time to check out there drivetrain section.
Engine: Many
Transmission: Quite a few
what are you using for axles?
nice work so far. Did you have to narrow the rear as it sat, or would the original width have worked?
Car: 1988 Trans Am GTA
Engine: 350 .060 over carbed
Transmission: TH-700R4 w/2800 stall
Axle/Gears: 9 bolt w/3.27s till it breaks
What happened to the pictures? I was thinking of doing this just want to see how you did it, could you email them to me please, otecnick@yahoo.com
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
