Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
URGENT READ for fabricators!!!
Old Mar 29, 2010 | 08:48 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Just found this on another forum--
http://www.brewracingframes.com/id.75htm
If you can't get it, this is a quick over view--
A welder was cleaning a surface for patching using brake cleaner. He used a torch to dry off residual brake cleaner.
While he was working, he noticed a small whisp of smoke... turned out to be a poison gas used in WW 1!!! ( Phasogene, phosgene or something like that )
Symptoms include--
seizure, vertigo, constipation, kidney failure, chronic bronchitis, emphosima. Maybe a few more, writing from memory.
Be careful out there!!!
Last edited by t-top havoc; Mar 29, 2010 at 09:03 AM. Reason: Problem w/ server possible
Old Mar 29, 2010 | 09:08 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: URGENT READ for fabricators!!!
He's a moron for just putting a torch to it. Brake cleaner is flamable as hell.
Old Mar 29, 2010 | 10:13 AM
Car: '87 Camaro
I will try to link from home tonite--seems the iPhone won't give a propper link.
Old Mar 29, 2010 | 11:15 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
And for waiting so long to go to the hospital...
Old Mar 29, 2010 | 11:30 AM
Twin_Turbo's Avatar
This has been popping up on every forum for the last couple of months
I don't know about over there but here Tetracholorethene and similar chlorine compounds have been outlawed here for ages. A real common one was called "tri" for trichloroethane, Tetrachloroethene is also called perchloroethene, or " per". It used to be commonly used in dry cleaning. Brake solvents here don't contain it anymore.
Old Mar 29, 2010 | 10:21 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Half the chemicals in my garage are going to emit high concentrations of noxious gases if I use a torch to dry them. One of the first things they taught me in school was WHMIS, and they mandated that we read the MSDS and take notes on safety procedures, PPE required, first aid measures, and safe disposal for any chemical we used.
Old Mar 30, 2010 | 03:58 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Usually solvants with those compounds say specifically not to expose them to a source of flame due to the emmissions of toxic fumes. If you ignite it and kill yourself, its kind of your own fault.
Old Mar 30, 2010 | 09:26 PM
83 Crossfire TA's Avatar
they're not really that flammable, but when exposed to heat or combustion they do give off phosgene... not good.
carb cleaner is sort of the opposite, it is very flammable, but besides that not that dangerous to you (besides the flames) when burned, but it does permiate skin and get into your system much easier than brake cleaner.
the fact is that most things that are helpful around the shop can be dangerous if misused... don't do dumb **** and if you do, don't blame anyone but yourselves. It seems like way too much "good" (as in actually works well) stuff has been made illegal or hard to get to protect the idiots from themselves.
Bubbajones_ya
Jul 6, 2024 08:32 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
86IROC112
Sep 11, 2015 04:04 PM
