Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
1st or 2nd Gen Front End on a 3rd Gen
Old Apr 4, 2010 | 10:23 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
Would it be a lot of fabricating to put like a 71 pontiac front end on a third gen pontiac? it doesnt seem to be to hard, besides making adjustments for the bolts to hold down the assembly. I need advice and I really would like an honest answer. THANKS!
Old Apr 5, 2010 | 12:33 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 1st or 2nd Gen Front End on a 3rd Gen
Nothing is impossible but a factory 71 front will be nowhere near a direct fit. The best you could hope for would be to use one as a template to build a custom front end so that all the dimensions would fit properly. It won't even be the right size or shape to match up to the third gen body lines.
Old Apr 5, 2010 | 09:07 AM
92Firebug's Avatar
Engine: 305 TBI
okay that gives me a good idea on what im going to have to do, i still do not know which front end i want though, which is the real problem for me. but until i make my decision, thank you for the info
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bellez77
Sep 5, 2015 08:39 PM
