Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
rust repair
Old May 18, 2010 | 08:56 PM
firebirdton's Avatar
Car: 82 Firebird
Engine: 383 stroker
Transmission: 350 turbo
Axle/Gears: 3:73
rust repair
i have a 82 firebird and the left side cab corner is rotted how do i fix this problem and the inside of the rocker panel is bad is there a replacement for it please help
Old May 19, 2010 | 07:04 AM
Awesome-X's Avatar
Car: 87 Camaro
Re: rust repair
Good question, I have the same issue. I would think you could cut the bad spot out and weld some new metal in, but I'm not sure what to use in terms of what kind of welder or what kind of metal so..
Old May 19, 2010 | 08:52 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Re: rust repair
That's pretty much what you have to do. Floor pans are actually sold for our cars but other areas like the firewall, most of the sub-frame, etc. are not. You'd need a donor car to transplant metal from or fabricate what you need yourself. Though this is much more difficult to do and even more so if you try and match the factory metal/body contours. You can use MIG or TIG welders and many people have their preferences and thoughts on which is best. My research led to the thinking that MIG is typically best for most jobs but TIG has its uses. Fabrication of exhaust headers etc. is typically best accomplished with TIG welding.
Old May 19, 2010 | 08:03 PM
Car: 82 Firebird
Engine: 383 stroker
Axle/Gears: 3:73
Re: rust repair
thanks you for the input i appericiate it
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
