Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
HID Fabrication
Old Aug 10, 2010 | 06:19 PM
Stephen's Avatar
Car: 87 GTA
HID Fabrication
I know several people have cut the back of the housing, made a plate back, to mount the projectors on them. I wanna try a different route, but I'm running in to a road block.
How can I separate the glass lens, from the metal housing? Will oven heat soften the glue/whatever they use to hold the glass on? (i tried, but maybe not enough heat or time) Is there some sort of adhesive remover liquid that I can ooze down into the seam, to break up the adhesive?
Old Aug 10, 2010 | 07:42 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: HID Fabrication
what no pics man? tisk tisk tisk
Old Aug 10, 2010 | 07:47 PM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
Nothing special, just black buckets.....And yes, I'm pulling the fake projector lens out & putting in a REAL Hi/Low Bi-Xenon HID projector.
Old Aug 10, 2010 | 07:56 PM
ls1fiend's Avatar
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
Re: HID Fabrication
Just make sure to hit the mute button. This should help you out a bit, maybe.
http://www.youtube.com/watch?v=imIiglkq7HA
Old Aug 10, 2010 | 08:02 PM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
Yeah, I've seen that one. And I ran if for 2 minutes at 200. Didn't budge. Popped it back in for 4 minutes at 400. Still didn't budge.
All I got was a hot headlight.
Old Aug 10, 2010 | 08:23 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: HID Fabrication
you can try it with a heat gun, but if that don't budge, then you will have to use a dremel and cut around it... then use some Nissan Sealer and a heat gun, along with clamps and let it seal overnight...
Uploaded with ImageShack.us
Old Aug 10, 2010 | 08:32 PM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
The headlight in that video is a plastic housing & plastic lens. Mine is real glass & a metal back. My tail lights came apart that easily, without even heating them.
If I use my Dremel, that would be cutting away the "socket" flange that the glass lens fits in, so I really hesitate to try it that way..
Old Aug 10, 2010 | 08:37 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: HID Fabrication
on my retrofit of my Trailblazer, I had no choice but to cut away... I used that sealer and haven't had any problems... I did use some silicone a couple weeks later just as a precaution... I have not had any leaks or anything...
Old Aug 11, 2010 | 02:11 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: HID Fabrication
@ Stephen:
You find a solution?
Old Aug 11, 2010 | 02:28 PM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
Well, sorta....
I broke down last night & pulled out my Dremel. Discovered I only had 4 cutting discs. And I went to town on the seal between the glass & the housing, then I realized just how it is built.
I made this jpeg to show how there is a mounting "wall" on the inside of the glass. So the glass is setting over it, like a bottle cap sits on a bottle, just without the screw threads. So I have to cut all the way through & then tere is no real mount, other than glue/seal/adhesive, to hold the glass after I put it back on.
And the projectors came in today! Ordered on Monday, arrived today. Too bad the housings aren't ready to test fit them yet.....
Old Aug 11, 2010 | 09:43 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: HID Fabrication
I hope you find a way to make it work, I ran into same problem and gave up because I could,nt find a secure way to put it back together.
Old Aug 11, 2010 | 11:59 PM
firbird's Avatar
Re: HID Fabrication
How do you plan on getting it to fit length wise? What projector are you using?
The reason I ask is I ordered similar fake projectors in hope to find a way to put in real projector in there. No luck. There is not enough room length wise. It is possible you could limit the angle in which the headlight lifts and reconfigure the angle to shoot forward at say half way up. This would allow more depth to put the projectors in. The way I have mine setup is of course the way you wish not to do yours. However, there is no possible way it could move any farther back and is one of the most compact design in the plug that goes into the HID bulb. With that being said the front of the glass on the projector is maybe 1/8 of a inch away from the front bumper as it rotates up to open. Given this is bi-xenon there isn’t much length to save by going without brights, still same focal point. You may be able to put the smaller HID housing in there that hella makes, something like a 60mm?
Old Aug 12, 2010 | 12:06 AM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
Mount them like this..... Just need a lens back over it.
http://s119.photobucket.com/albums/o...t=P8110001.mp4
The projector mounted right into the H4 socket, with zero modding.
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: HID Fabrication
your best bet would be to forget using the lense and just use the base of the headlight housing... there is an article on a 4th gen projector retrofit floating around.. not sure if it's on LS1.com... but he used plaster to mold a clear plexi glass lense and from what I remember it worked pretty well... I think that was the route I was gonna go with with my 3rd gen...
Old Aug 12, 2010 | 12:09 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: HID Fabrication
my research skills came into play and have found the post I was talking about ... hopefully this will inspire you to go a different route and perhaps it will turn out better...
http://www.ls1tech.com/forums/appear...-write-up.html
Old Aug 12, 2010 | 12:24 AM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
Not bad. You can see my video in Post #13 above, showing the projectors mounted with zero mods, except for no housing lens.
I just need to figure out a lens for these.....
Old Aug 12, 2010 | 12:34 AM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
I've trued & tried & tried....The damn lenses won't budge.....HELP!
Everything else is going so good, who knew this :"simple" road block would stop me. I thought the glass would be easy to get off.
I've tried my heat gun...I've tried baking at 300 degrees for 4 minutes. Not even the slight hint of movement from the lens.
Old Aug 12, 2010 | 01:08 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: HID Fabrication
I'm telling you... with my trailblazer headlights, I had to cut the perimeter it also had a lip similar to the one you drew up ...
Old Aug 12, 2010 | 01:13 AM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
The lip on the INSIDE though, and being like 1/8" thick, I can't just stick my Dremel in through the back & grind away at that lip from inside.
From the outside, the seam is completely exposed & the Dremel cutting disc slips right in.
Old Aug 13, 2010 | 11:45 PM
Stephen's Avatar
Car: 87 GTA
Re: HID Fabrication
1-handed assembling of a projector into the H4 bucket (after the lens is removed).....
1-handed assembling
Old Jan 5, 2011 | 09:06 PM
sjgrimsley's Avatar
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
Re: HID Fabrication
Any more progress?
Old Jan 5, 2011 | 09:11 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Re: HID Fabrication
they sell a kit that looks good on ebay its only 80.00 and the bulb comes with low and high beams. ima try and get it once i have the money.
Old Jan 5, 2011 | 09:13 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Re: HID Fabrication
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_5296wt_938
Old Jan 6, 2011 | 12:00 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: HID Fabrication
problem with this kit is that it doesn't have a proper projector setup, so the light pattern is going to be very scattered and un-focused. you're gonna have some angry drivers on the road ahead of you....
progress looks good Stephen, keeping an eye on this thread for updates
Old Jan 6, 2011 | 12:03 PM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Re: HID Fabrication
But this kit has a shield on the bulb to prevent that.
Old Jan 7, 2011 | 07:24 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: HID Fabrication
not the correct type of shield though; if you pull apart a projector, you will see a "guard" that blocks light from being let out horizontally (which is what gives you that distinct HID line). that shield just reflects light back towards the rear reflector; an H4 has a high and low beam inside the single bulb package, so you cannot make the proper cut off
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
customblackbird
Oct 1, 2015 04:30 PM
Royal_Z
Sep 30, 2015 08:45 PM
