Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom Camaro Ram Air Boxes Question...
Old Sep 7, 2010 | 07:52 PM
WhiteysTA's Avatar
Car: 87 Chevy Camaro Iroc-Z
Engine: 350 LT1
Axle/Gears: 3.27 9-Bolt w/TA Perf. Stud Gurdle
Hello, I was looking for any information on plans for the ram air boxes that go behind the fog lights. I work at a company that fabricates metal electrical enclosures, and can design/build these, but want to take the short road and get the specs on them from somebody. I know Hawks sells these, but dont want to spend $100 for something I can make myself for $20. Thanks for any info!
Old Sep 7, 2010 | 10:23 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: Custom Camaro Ram Air Boxes Question...
Do a search or pm 1bad91z. He did the same thing years ago and so have others.
Old Sep 8, 2010 | 06:20 PM
88camaroluvr's Avatar
I made mine out of aluminum and then bent and riveted them together. I even angled mine forward a little.
I first built it up with cardboard
Then took it apart and put on tabs that could be tucked under and riveted together.
After I transferred it onto aluminum, I started bending it all together and tucking it in.
Old Sep 8, 2010 | 06:25 PM
Here it is all riveted together.
I then used RTV silcone on all the edges to seal it up
I then painted it with a dark primer and riveted it onto the plastic intake.
Old Sep 8, 2010 | 06:36 PM
I then ran into a problem I seemed to have over looked.
The back of the tube didn't go all the way over the edge of plastic on the back. I couldn't make it all one piece and cover it because it was physically impossible.
So, I made this little piece to cover the back.
Like so.
It turned out perfect and runs great. I still have the template I used and I could measure it out a little but I don't know if you would want to use it. I guess you could make the tube a little wider and not need that little cover for the back.
1992rs/ss
Jan 31, 2025 05:10 PM
9192camaro
16
Feb 3, 2019 12:21 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bryan623
Aug 10, 2015 11:33 AM
