Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Help me find a nut, the right one that is
Old Nov 1, 2010 | 05:17 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I am looking for something to anchor a bolt / sheet metal screw into the front sheet matal just in front of the radiator near the nose. I know GM used some speed nuts (pictured below) in this area to hold down the plastic. Is there anything else that I could use, something I could drill a ROUND hole and drop in , similar to a dry wall anchor to secure the bolt/ screw. I found the following two things is there anything else that is better/will work better any ideas appreciated.
BTW: I will be securing the radiator to the front using two metal straps and I need to attach them to the sheet metal in front of the radiator ( towards the nose, in the same area as the factory shroud but a little further forward).
Old Nov 1, 2010 | 05:22 PM
Twin_Turbo's Avatar
Re: Help me find a nut, the right one that is
nutsert
Old Nov 1, 2010 | 05:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Originally Posted by Twin_Turbo
nutsert
something like this
http://www.mcmaster.com/#nut-certs/=9j8mqr
Old Nov 2, 2010 | 01:29 AM
THETANK's Avatar
Car: 91 rs
Thanks!!! that is exactly what I was looking for. Also check this out found it on another forum seems like it works:
http://www.ridgelineownersclub.com/f...?t=1360&page=2
I was also looking at this tool from harbor freight seems like a decent piece for the occasioanl user like myself and it will hopefully allow me a little more money for parts.
http://www.harborfreight.com/45-piec...-kit-1210.html
Old Nov 2, 2010 | 07:14 AM
GFR88IROCZ's Avatar
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
They sell these at Menards $20. if you have one locally, Also have the 1/4 20 refills
Old Nov 2, 2010 | 07:27 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
just keep in mind that just about everything Harbor Freight sells is cheap Chinese crap and will break if you use it more than a couple times
Old Nov 3, 2010 | 12:45 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
A couple times? The brake caliper tool set broke the first use. Torque wrench lasted one and a half engine rebuilds (was probably never accurate either, amazing I never blew a head gasket). My vibro tumbler's been going strong for years though, cleaned hundreds maybe thousands of nuts, bolts, and rifle casings by now.
I was thinking maybe tee nuts, bend the teeth over so theyd stay, but that would take an extra couple holes around the main hole for the teeth to go through.
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
New2Chevy
Sep 28, 2015 12:35 AM
383cam
Sep 9, 2015 06:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
rjcme
Sep 5, 2015 01:23 PM
