sfc
Car: 92 rs & 89rs
Transmission: auto & t5
sfc
ok now that i built the stb now i was thinking i need sfc's. i built the stb for next to nothing why caint i build the sfc also. i just got a couple questions. i really like the idea if the round tube for ground clearence {my car sits real low}. i used 1.25" od x 1" id pipe for the stb will this be good enough for the sfc or would i need to go bigger?
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Re: sfc
What about using rectangle tubing? That might be able to tuck up under the car even better.
Post pics&dimensions of ur build. Im planning on making my own in a couple months too
Axle/Gears: stock
Re: sfc
I am personally wanting something like the BMR SFC008 design that will work with my LTs and true dual setup im wanting to run. If anyone has dimesnions can you PM me with them or post em up? (sorry dont mean to hijack your thread)
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: sfc
square or round will still have the same ground clearance, it all depends on where you route them. I would say at least 1.5 tubing, if not 1.625 or 1.75. Dont use pipe, use steel tubing. Pipe is rather "soft".
.120 -.134 wall tubing is more than enough
Car: 87 GTA
Re: sfc
I'd say concentrate more on wall thickness than tubing size. Wouldn't a thicker wall basically allow a thinner tube, to a limit, of course. I'm not suggesting 1/2" thick, solid wall tubing or anything like that.
Guest
Posts: n/a
Re: sfc
Actually its the opposite, for the element itself. Either in bending or in torsion, having the material further away from the center will make it stronger leaving out issues from having walls too thin that can buckle under load or similar problems. However I was thinking about it after your post and if you view the entire car as a structure, the lowest areas furthest away from the vehicle's center (where the rockers are) are going to be in tension almost all the time, if not all the time. That makes the location of the metal in the element itself (the sfc in this case) kind of irrelevant. I wouldnt wash it away completely mind you, but its not going to end the world to use something a little smaller.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: sfc
Look at the size and thickness of the Spohn and UMI sfc's to use as a reference.
The stb tubing is too small.
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
Re: sfc
I don't know if you want to cut up your floorboards or not, but I just finished sfc's in my car. They're made of 1 5/8" 4130 chromoly .083 wall. This is how they look, and also no ground clearance issues.
Uploaded with ImageShack.us
in this picture its only tacked up but you can get the idea.
Car: 92 rs & 89rs
Re: sfc
does anyone that have the spohn tube sfc know what size they used? i am thinking 1 1/2" or 1 3/4" but not sure . i like the look of the spohn where its almost like you cant see them.
Car: 87 GTA
Re: sfc
"Our "truss-style" framing system is constructed of 1.75" x .120" wall DOM (round) tubing for serious, uncompromised rigidity."
For comparison, UMI says.....
"- Built using 2.000” x 1.250” x 0.120” Mild Steel Rectangular Tubing"
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
