Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Removing last 8" off front subframes.....thoughts?
Old Nov 15, 2012 | 12:10 PM
  #51
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
Re: Removing last 8" off front subframes.....thoughts?
Ok I want to run dual exhaust by running a tube done each side under the car could I etch out a whole just big enough to run my drivers side exhaust tubing threw the frame it I braced it with some steel
Old Apr 24, 2013 | 10:53 AM
  #52
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
so finally got it up on a lift to cut cut cut.
I had to cut a "v" notch out of the passenger side subframe stub that was left in order to have clearance for the 3.5" collectors I'll be running. Planning on plating the ends and welding roll cage tubing from that to the jegs perimeter subframe connectors and it should be stronger than stock. Some of that sheetmetal is very thin that was cut out.
Old Apr 24, 2013 | 11:58 AM
  #53
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Old Apr 25, 2013 | 10:57 PM
  #54
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Good ideas guys!
Hey xpndbl3, what headers are you planning on using?
Old Apr 26, 2013 | 12:24 AM
  #55
xpndbl3's Avatar
Car: 1984 Z28
I'm building a set of stepped headers out of mandrel J bends.
Old Apr 26, 2013 | 06:33 AM
  #56
mw66nova's Avatar
Engine: 7.0L
Originally Posted by LB9GTA
Good ideas guys!
told you there was interest
Old Apr 26, 2013 | 09:59 PM
  #57
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
My Ed Quay 1 7/8 headers fit awesome and were reasonably priced if you are looking for SBC headers.
Old Apr 26, 2013 | 11:08 PM
  #58
mw66nova's Avatar
Engine: 7.0L
lsx headers ftw
Old Apr 27, 2013 | 07:21 AM
  #59
xpndbl3's Avatar
Car: 1984 Z28
Yes as matt said they're ls headers and I built stepped headers which no one offers iirc. Either way the subframe had to come out for the size collectors I chose and to have any kind of ground clearance for street driving.
Old May 6, 2013 | 11:27 PM
  #60
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Hey xpndbl3, what did you do when you cut out the frame there?
Do you have any pics of the end result?
Old May 7, 2013 | 12:10 AM
  #61
xpndbl3's Avatar
Car: 1984 Z28
A few posts up say what I did. Only have pics of it plated off. Nothing to see really. Too busy with my business to take anymore at the moment. Give me a week or so to get it back up in the air for pics
Old Jun 1, 2013 | 10:44 PM
  #62
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Updates?
Old Jun 12, 2013 | 02:22 PM
  #63
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Bump. Started cutting into mine yesterday. Have any finished pics?
Old Jun 20, 2013 | 07:53 AM
  #64
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Finished my sfc and frame mod. I will post pics tonight.
Old Jun 20, 2013 | 11:34 AM
  #65
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Box that area and send a piece of 1 5/8 tubing to the front lca eyelet from that boxed area. It's a straight shot and gives a lot of room for headers, TA etc.... Plus you can ditch the heavy sfc's then. The round tubing will give a great base to make a removeable tubular trans crossmember and also if you need to add a sperate TA mount.
Old Jun 22, 2013 | 10:04 PM
  #66
xpndbl3's Avatar
Car: 1984 Z28
Thanks its on my list of things to do soon. Haven't had a chance to touch the car since thirdgenfest due to working too much. I'll have to measure how much tubing to get soon. Definitely need to make a trans crossmember. Still have your pics saved....I'll try my best to make it the same way.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
anesthes
Mar 10, 2016 10:35 PM
3rdgenparts
Aug 8, 2015 07:09 PM
