2k hp capable street car build
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Re: 2k hp capable street car build
Wicked setup! You've given me so many ideas
I'm getting ready to start building something at a similar power capability, but its going to be LSx based (I know I know
I'm currently spec'ing out my front suspension and was curious as to what spring rate you went with in the front coilovers.
)I'm currently spec'ing out my front suspension and was curious as to what spring rate you went with in the front coilovers.
Car: 1990 formula
Car: 1990 formula
Car: 1990 formula
I've been swapping the 4.11's for a set of 3.50 big pinion pro gears.... Should be back on the road tonight, hopefully I didn't screw up the install!
Car: 1990 formula
First gear pull on the street with 315/60/15 MT tires, 3.50 rear gear. Let out and got back in because road was curving.
Full res: http://www.yerot.com/~aweil/pictures/log_street.jpg
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Car: 1990 formula
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
thank you for "finishing" the build! this thing is bad!
Car: 1990 formula
Couple new goodies... not installed yet, but working on it.
Car: 1990 formula
Got some more work done.
The Hyperkontrol has an accelerometer in it, it's critical that it is mounted with either connector or opposite end towards the front of the car, and installed level.
I fabbed this mount plate to do the job. You can see the level adjustment screw to make sure it's installed level. I mounted it on the floor under the passenger seat to keep with the theme of 'clean install'.
Here's a bracket I fabbed to mount a ferrous metal proximity sensor to sense the back of the front wheelstuds to give me a VSS sensor for the boost controller.
Looks awesome this beast just keeps getting better keep it up I love looking at the pics.
Videos are even better
Car: 1990 formula
12-13 psi smokes the 315/60 drag radials at 85. Estimated 1150 flywheel hp from fuel usage.
16 psi blows the tires off from 60. Not planned, but that happens when you forget to hook the hose back up to the side of the waste gate..... Still pulled a peak of .93g while spinning the tires on the limiter! Estimated 1320 flywheel hp.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
hahaha thats just sick. I hope my motor can get up near 1000 hp on 15 psi 1100-1200 on 20 or so
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
that setup should be able to handle 35-38psi if i had to take a guess. and will make the 2000hp mark.
need some track times!
Car: 1990 formula
Car: 89 Iroc-z
Transmission: TH400
It aint never gonna hook on the street with 30 psi
It would spin at 150+ MPH
It would spin at 150+ MPH Thread Starter
Car: 1990 formula
Fabricating the chute mounts.
Trimmed the license plate
Chute cable handle and bracket
Beginning of chute mount anchor point
dual stroud 430 with launchers mounted to bracket
When you get to the track PLEASE get video of this awesome build.
Car: 1984 Camaro Sport Coupe
Engine: RHS/LSx 427
Transmission: Powerglide
Axle/Gears: Fab9 3.00 gears
really planning on going 200+ (when dual chutes are required)?
Engine: RHS/LSx 427
http://ls1tech.com/forums/forced-ind...dont-60-a.html
Car: 1990 formula
not sure which 76s you have...but here's a guy running twin 76s and running pretty freaking good
Mine are precision billet 7675 turbos.
Got the dual chutes from the outlaw car, might as well use them.m hoping for 150 1/8th mile traps and some of the tracks have short shutdowns.
Car: 1990 formula
Went out and took some pics tonight.... rolling on big and littles.
I love this car and I really love how from the front it almost looks stock.
Car: 1990 formula
Car: 89 Iroc-z
Transmission: TH400
You are officially getting nominated for car of the month for sept.... that is absolutely ridiculous and sooo bad ****. Love it
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
I see you found some "remove before flight" tags to attach to the parachute mechanism. Love it.
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Awesome car! How does Murphy's Finest feel about your car? Reason I ask is because out here in the Soviet Rebublic of California that car would be begging for trouble.
Car: 1990 formula
Actually, I was driving home a couple months ago after getting the car aligned. It was about 10:30 am, and I'm driving right at the speed limit through town. I see a policeman turn on the road I'm on and follow me, going pretty slowly. I keep driving, turn onto my street, and he follows.
I turn in my driveway, and he parks in front of my house and comes up the driveway... I think OH NO.
He comes up and says "man, that thing sounds pretty good! I was trying not to follow too close because I didn't want to scare you. Do you mind if I take a look at it?"
15 minutes later, my wife comes out of the garage, having heard my car pull in but I haven't come in... she sees the policeman and his car and thinks uhoh! After hearing the conversation, she shakes her head and walks back inside! hehe
The policeman thought the car was pretty cool!
Car: 89 Iroc-z
Transmission: TH400
Nice i had some local boys stop and talk to me about my car too way back when it was stock haha. Job well done surprised that exhaust setup is working well enough to be legal to drive. Has to be wicked loud
Car: 1984 Z28
Engine: Vortec 350, hotcam
That is amazing. I wish you lived by me i'd pay you to take me for a ride haha. By the way what kind of wheels are the black ones? Thread Starter
Car: 1990 formula
Car: 82 firebird
Engine: a few
Transmission: th350
Axle/Gears: wondering this myself
wow man... just wow. one day i hope to be able to do a build like this, its just so damn crazy
Car: 1990 formula
Installed a window net this weekend to be legal for the track. I'm using the Jerry Bickel window net kit.
http://www.jerrybickel.com/safety-eq...-jbrc3011.html
with this net
http://www.jerrybickel.com/safety-eq...et-std501.html
Here are some pics of the install....
Location for threaded adapter for rear of upper net
Welded in and installed. Always run a tap through the threaded adapter after welding!
Buckle installed nice and tight up against the headliner. Used a small square of aluminum sheetmetal with rounded corners and some wet cardboard to keep the headliner from burning. A buddy of mine told me about this trick, it works very well!
Outside of finished install
Inside of finished install
with this net
Car: 1990 formula
Car: 89 Iroc-z
Transmission: TH400
Looks good. Didnt know window nets needed weld in bungs for bolts i thought they just wrapped around the bars and tied in or buttoned in
Car: 1990 formula
Window net must be securely mounted on the inside of the roll cage, with the permanent attachment at the bottom. All attachment points must be designed in an attempt to protect the driver and avoid contact with track surface or guardwall. Eyelet clips, dogleash hardware, hose clamps, etc. prohibited. Penetration of webbing, except as performed by manufacturer, prohibited. Any modification to net must be performed by manufacturer.
