making a spohn torque arm mount
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
as you can see in the first photo the spohn torque arm mount fits pretty tight up in the tunnel. plans are to buy a u channel like the original and use one side for the right leg of the mount and the other side to be where the actual torque arm bolts to. and cutting off the left side of the u channel making it basically a 90 degree angle iron. BUT! another brace shall be welded from the rear of the transmission crossmember to the piece holding the torque arm mount to add support. the right side of the u channel gets welded to the trans crossmember and the flat part of the u channel gets welded to the flat part of the crossmember. more than likely im going to weld a complete plate on the side where im cutting the leg off the u channel to make it a solid connection between the crossmember and the u channel. its hard to explain exactly whats its going to look like but im confident it should hold AND give awesome exhaust clearance.
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
Re: making a spohn torque arm mount
good idea, but i sure dont like thats peice of flat bar you got fabed up for that trans, thats thing will bend under load, maybe you should add stiffeners to it, just a thought! great ideas though.
Car: 1986 camaro
Engine: ls2
i bought it from hawks third gen. its made from 1/4 flat stock
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I also vote down the trans crossmember. I would go with some 1x4 square tubing.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
That trans crossmember is fine, the stock one is way more flimsy
Car: 1986 camaro
Engine: ls2
I assure you guys it wont be a bit flimsy when im done.
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
I have a million different ideas myself but it would be very easy to 'over engineer' this crossmember when all that holds it in is 4 bolts on a flimsy floor.
Car: 1986 camaro
Engine: ls2
i should have some pics to show tomorrow of the finished product. IF the guy comes over and wires up a plug for the welder.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I like the way it looks ( crossmember). Add a few gussets here and there. By the way what did you use to connect it to the frame, flat plate ? Or angle iron?
Car: '89 GTA
Engine: 5.7L LS1
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Car: '89 GTA
Engine: 5.7L LS1
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
That has nothing to do with the question. I wanted to know if it is flat plate or angle that is used to connect it to the frame. Or to satisfy white, the bolts connecting the crossmember to the subframe are going threw what type, shape, metal?
Car: 1986 camaro
Engine: ls2
i believe it is angle iron shaped to the form you see... but im not 100%
Engine: Cammed 6.0L LSX
I'm really excited to see how this turns out, and will be even more excited if you will make me one this spring/summer after I start my 8.8 swap
Car: 1986 camaro
Engine: ls2
yeah i got started late (freaking electrician didnt get here till 3!!!!!) but i have my main supporting peice cut and ready to be welded. i just cut the spohn greasable joint off the original mount and should have it all together tomorrow or saturday. Then redo my exhaust....yippee
Car: '89 GTA
Engine: 5.7L LS1
I'm sorry your question had room for interpretation. Be a little more specific next time because he didn't make it as stated in your original post.
Sorry about that Nasty
I really wanna see this thing. Thread Starter
Car: 1986 camaro
Engine: ls2
ok teaser pics. it doesnt look like much but it rides the drives side crossmember leg great! the grinded hole in the front is there the transmission mount bolt where it bolts to the transmission sets.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks 1nasty, I thought it looked like angle but not sure. I see we have another Steve who dissects everyones comments instead of leaving it to the OP.
Car: 1986 camaro
Engine: ls2
finished the mount today. im very happy with it! semi gloss black finish.
Car: '89 GTA
Engine: 5.7L LS1
I wasn't sure which way you were going with it but it looks great! Very simple and effective. How much did you have to adjust the torque arm to position it?
Car: 1986 camaro
Engine: ls2
the greasable joint legs are basically straight up. and there are still alot of threads in the torque arm. and there is alot of room for my exhaust now, comparing it to my old exhaust it looks like i have about 2 inches of ground clearance over my old setup.
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Next time you build one take .500 steel rod and cut a piece the width of the greasable joint for the front and back on the joint. Then you won't need to run that strap up the joint. You just place those in the wedge for and aft the joint.. It's more eye appealing and will prevent the rocking if your welds ever cracked plus it's more removeable if you even need to change things up.
Car: 1986 camaro
Engine: ls2
thanks for the suggestions.... mounts is still holding up but i havent REALLY but any stress on it yet. 275 555r's wont hook worth crap. 315's are in the storage building
