Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Cup holders with LED's
Old May 12, 2011 | 04:30 PM
Cpt Vos Bradley's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: W/C T5
I've seen quite a few custom cup holders posted. Only recently did I get around to installing some I made myself. It replaces the ash tray.
Made from Plexiglas which I cut using a CNC mill I had access to.
The lighting was pretty simple too, I just ran wires under the center console to the light bulb that lights up the shifter.
Glued together using a sort of chemical that melts the plastic together, to form a nearly seamless seal.
Old May 12, 2011 | 04:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Cup holders with LED's
cool.
Old May 12, 2011 | 04:52 PM
dustinxix's Avatar
Car: 1988 firebird formula
Engine: 5.7 TPI :)
Transmission: Auto :(
Axle/Gears: 9 bolt LSD
should start making a bunch of those, theyd sell on here pretty good bro, nice work!
Old May 12, 2011 | 04:59 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Cool idea, but IMHO, bad location.
Drinks would be in the way of accessing the radio controls & you can pretty much forget about ejecting a CD or inserting a one.
And it looks like anything bigger than a 16 ounce can wouldn't fit. Like a Sonic cup. The upper wider portion of those would be resting against the radio & cause it not to fit without tilting badly.
Old May 15, 2011 | 11:37 AM
Car: 1989 Camaro RS
Engine: 2.8L V6
You are absolutely correct about the radio controls. But most of the time i'm running the radio through my MP3 player, which is on a cord, so it works out.
As for what fits, and what doesn't, its sort of a gamble. Any sort of can will fit, and sometimes fast food drinks will fit. I like your honesty.
Old May 15, 2011 | 11:47 AM
Car: 1989 Camaro RS
Engine: 2.8L V6
You might want to check my other thread.
https://www.thirdgen.org/forums/inte...ml#post4921787
Old May 15, 2011 | 11:48 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
id buy it if it, but then again i dont let people have drinks in the car
Old May 15, 2011 | 11:52 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Looks cool! just not for me. nice job
Old May 15, 2011 | 01:49 PM
Scootermunch's Avatar
Car: 1989 Trans am GTA
any body out there with the firebird console do something like this? i have seen a lot of nice cupholders for the camaro, and wish my shift plate (s) made it more possible to do it to make it look flush.
Old May 16, 2011 | 03:04 PM
Car: 1989 Camaro RS
Engine: 2.8L V6
I've not seen many cup holders for firebirds. I'm sure someone's made a set that look nice
Fanatic1074
Oct 3, 2022 05:57 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
