Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Help
Old Jun 22, 2011 | 02:08 AM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Help
I have a 1988 Pontiac Trans Am with a 305 T.P.I. I was wondering if anybody can give me any hints or anything or pictures of custom fabricating to the body,interior, or audio or give me websites. Greatly appreciate it, thanks
Old Jun 22, 2011 | 06:20 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Re: Help
www.google.com
For anything more specific it might be good to know what approximately you want to do with the interior or exterior and whether you prefer to start with the interior or rather with the exterior.
As for audio, this forum has an audio section.
I modified audio by taking everything audio related out.
Old Jun 22, 2011 | 06:25 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Help
Search is your friend. This site has had custom hoods, bumpers [front and back], dashes, subwoofer boxes, fenders, hatches, consoles, and much more.
For starters try looking at some of mine:
Fiberglass Heater Box
Z20 Special Appearance Package (just the molds)
Hood repair
2 18" subs in a hatch
Old Jun 22, 2011 | 06:39 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: Help
i wanting to go with the 91-92 dash with the later 4th gen seats and console
Old Jun 22, 2011 | 06:40 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: Help
thank you, im new here and trying to figure it out, thank you
Old Jun 22, 2011 | 06:41 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: Help
and that car looks awesome, especially the box u made
Old Jun 22, 2011 | 07:04 AM
Engine: 383 SBC
Re: Help
Thank you. This site has great information. Many people have done 4th gen dash swaps. Check over in the interior board section. There should be some sticky posts.
Old Jun 22, 2011 | 07:48 AM
Engine: LO3
Re: Help
As for 4th gen seats, that pretty much depends on your personal taste.
I went with 4th gen base firebird seats in my Camaro to keep a stock appearance but have the added comfort of the 4th gen seats rather then the worn out 3rd gen seats.
Then again, the 4th gen Camaro seats, also occasionally offered in the trading area, would clean up the look of the interior quite a bit.
Not much modification there. They are a direct bolt-on. Swapped mine in about 40 minutes time (fronts and rears)
Old Jun 23, 2011 | 09:14 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: Help
and for my taillights i was going to custom paint them with honeycombs and over the reverse light should i do just the cut out of a phoenix or outline it?
