Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Any Ideas on getting this to fit under my hood
Old Jul 16, 2011 | 09:39 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
So I got my harwood 3in. cowl hood and test fit it, its just a little to short to clear my supercharger.
I need about a 1/4 so i can get a air cleaner tube on top of my carburetor so i can get ample air to my setup from the front bumper or wheel well.
Should i consider a shorter carb? Im using a holly 600, is there any carbs that are a little shorter?
Think i should use a solid motor mount to drop the entire engine a little?
What do you guys think? I will not use a taller cowl hood
Old Jul 16, 2011 | 09:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Any Ideas on getting this to fit under my hood
cut a little hole in the hood and re-glass the bulge.
IDK how much you can lower the engine before clearance elsewhere becomes an issue. what motor moutns do you have? if they are original, they are already a bit lower than what the solid or poly mounts would be at.
can you get a thinner bonnet for the top of they carb? not sure you can get a thinner carb...
Old Jul 16, 2011 | 10:15 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
If the carb is setting on top of a huge spacer, look at getting a thinner one. I've seen some people setting the carb on top of a 2" thick plate on top of the manifold to get more plenum volume.
Old Jul 17, 2011 | 12:26 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Lets see what this induction system looks like before we can offer suggestions.
Old Jul 17, 2011 | 05:12 PM
im trying to figure out where to buy what im talking about, i know spectre sell the kit im thinking of but ive seen the gm part before and would rather something like that. Ill figure it out guys,
ITS A TIGHT FIT FOR SURE no matter what i do
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Wvcamaro
Sep 4, 2015 08:38 PM
bryan623
Aug 10, 2015 11:33 AM
