Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
replace radiator core support
Old Sep 18, 2011 | 12:02 AM
aablack911's Avatar
Car: 89 Iroc-Z/well in theory
Engine: 5.7 350 TPI
A truck sat on my front end and am looking to replace my core support. I am wondering on the best way to remove spot welds. Do I drill the welds out? I wanna remove mine also remove one from another car and want to ensure proper installment. Just looking for tips on doing it right
Old Sep 18, 2011 | 12:08 AM
toomany's Avatar
Re: replace radiator core support
Spot weld cutter is one of the easiest and cleanest ways to remove spot welds. A grinding disc works too, but that makes the metal thinner and gets dust everywhere. You could even use a regular drill bit if you wanted. I'd use a spot weld cutter for my first choice. Body shops have them, Harbor Freight does as well.
Old Sep 18, 2011 | 12:36 AM
aablack911's Avatar
Engine: 5.7 350 TPI
cool didnt know they actually had something just for spot welds. ya why use anything other than a specific tool for the job if its an option. thnx for opening my eyes. been searching forums and seems no one ever posts about this subject even tho everyone has front end damage lol. Pull a part is my friend where an entire front clip is under $100. I dont have the set up at home for an engine swap as it seems everyone else does. So I will get the drill bits you are talking about. any other do's and definite dont's? any personal experiences would help
Old Sep 18, 2011 | 09:22 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Eastwood has a skip proof spot weld cutter with replaceable heads for like $50 or so. It works really well if you use a little oil and slow with the drill speed and will last a long time.
Old Sep 18, 2011 | 10:17 AM
83 Crossfire TA's Avatar
If you find a spot weld cutter for cheap I'd love to know where. Either way a drill bit will usually work OK and you can use the hole left over for a plug weld to hold the new piece.
Just be ready for a lot of messy prying, grinding and cutting in addition, I've never seen something just pop apart after drilling out the welds. If you end up doing a lot of work an air hammer/chisel is helpful.
Old Sep 18, 2011 | 11:50 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Originally Posted by 83 Crossfire TA
Just be ready for a lot of messy prying, grinding and cutting in addition, I've never seen something just pop apart after drilling out the welds..
Most of the time the weld wil pop apart after using the Eastwood spot weld cutter. At most I usually have to use a panel seperating knife, and that is mostly when the spotweld isnt round, but tear drop shaped. Using the dril bit is not an efficiant way to do it since you dril through both panels
Old Sep 23, 2011 | 10:01 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
i replaced mine, and to remove mine i used a chizzle and a grinder, cleaned up real good even for a rusted ontario car.... heres mine, it was right solid, i had two 8 inch arms that attched to the bottom of the frame, i dont have it anymore as that went to scrap with the car (way to rusty and found exact same car but no rust for under 500 no brainer)
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
