Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
87 iroc new floorpan and restoration
Old Nov 23, 2011 | 01:23 AM
lexmyster137's Avatar
Car: 87 Iroc
Engine: 355 sbc 12:1 compression
Transmission: Swapped t5, thanks Denny!
Axle/Gears: 10 bolt 3.42
well I shouldnt be redoing this car... again! the cars completely gutted and down to the firewall welding in all new floors and braces as well as a new radiator support and quarter panel. car looks like swiss cheese!
Attached Thumbnails 87 iroc new floorpan and restoration-third-gen-.jpg   87 iroc new floorpan and restoration-third-gen-outside.jpg   87 iroc new floorpan and restoration-iroc-beggining.jpg
Old Nov 23, 2011 | 01:25 AM
Car: 87 Iroc
Re: 87 iroc new floorpan and restoration
more to come if anyone wants them, also how do i post the big pics?
Old Nov 26, 2011 | 08:24 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
upload your photos to photobucket, then copy the HTML here. Bam, big photos.
Old Nov 30, 2011 | 12:31 AM
TwinTurboROC's Avatar
Are you going to be welding in OE style floor pans, of making your own? I had the joy <as well as many others> of running into floor pan issues.
Old Nov 30, 2011 | 10:17 AM
Car: 87 Iroc
I got lucky enough to get a whole pan from third gen ranch, so I'm using that, also fixing the front end damage I found from a previous owner, it'll be fun when it's done! I'll get more pics up this weekend,
Old Nov 30, 2011 | 10:20 AM
Car: '91 LS6/T56/9"
Engine: LS6
Hey man I'm in Niles, so power to the Chitown people! Did you drive down to pick up your floor pan? Got any pics? Here's my current project:
https://www.thirdgen.org/forums/body...ml#post5108477
Old Nov 30, 2011 | 04:07 PM
Car: 87 Iroc
Ya I've made that trip a number of times, 3 or 4 I believe. He definitely does have every part imaginable.
Old Dec 1, 2011 | 12:03 AM
Car: 87 Iroc
Last edited by lexmyster137; Dec 1, 2011 at 12:04 AM. Reason: trying to get pics to upload
Old Dec 1, 2011 | 12:06 AM
Car: 87 Iroc
Old Dec 1, 2011 | 12:07 AM
Car: 87 Iroc
that was the reason for the hold up had to get the 4th gen ready for winter after it had been hit. ive got progress pics coming though
Car: 87 Iroc
Old Dec 1, 2011 | 12:08 AM
Car: 87 Iroc
Old Dec 1, 2011 | 12:09 AM
Car: 87 Iroc
Size:  169.4 KB the shitty job that was done before, time to bring back the roc to its orignal self!
Old Dec 1, 2011 | 12:10 AM
Car: 87 Iroc
^not to mention the wirings garbage. split splice short and butt connector heaven.
Car: 87 Iroc
dashs out.
Old Dec 1, 2011 | 12:11 AM
Car: 87 Iroc
both doors off! Thanks to len at TDS there shall be no more sag! (thank god)
Old Dec 1, 2011 | 12:12 AM
Car: 87 Iroc
night mare!
Old Dec 1, 2011 | 12:13 AM
Car: 87 Iroc
messy garage but theres the donor pan! thank you third gen ranch
Old Dec 1, 2011 | 12:15 AM
Car: 87 Iroc
tore the rest of the car down and look what i found a wrecked front end and a previous repair. so the front came off.
Old Dec 1, 2011 | 12:16 AM
Car: 87 Iroc
new front end mocked up. ignore my friend
Old Dec 1, 2011 | 12:17 AM
Car: 87 Iroc
Old Dec 1, 2011 | 07:04 PM
nice, how did you measure up the front end, like to cut, etc? im trying to learn how to do "restoration" cuts. On another hand, i should not be let near a sawz-all and a welder.
Old Dec 1, 2011 | 10:54 PM
Car: 87 Iroc
use the body lines, the frame has stock drilled holes and bends. just look at them and measure 102039302949430230349 times cut once. also take little metal at a time its easier to cut a million times then replace metal you dont have. !
Old Dec 1, 2011 | 11:40 PM
Car: 87 Iroc
cutting out the old oneName:  IMG_0231.jpg
without the radiator supportName:  IMG_0230.jpg
Size:  106.5 KBName:  IMG_0191.jpg
the last time it will be outside in chicago now its gunna be hidden away in the garage till spring
Old Dec 1, 2011 | 11:45 PM
Car: 87 Iroc
some of the old frame with some humor
its me!
super bent!
sorry these are out of order i just got my camera to work, they will be in order once i catch up
the passenger well floor
Old Dec 2, 2011 | 08:48 PM
Love the propane tank behind you as your grinding/cutting. LOL. Safety first
Old Dec 2, 2011 | 09:40 PM
Awesome-X's Avatar
Car: 87 Camaro
Cool I need to do some floor pans this coming spring so I'll be watching this one.
Old Dec 3, 2011 | 01:51 AM
Car: 87 Iroc
yep safety first. nah the tanks attached to the heater so it wont explode because its already ad open flame. gotta heat the garage in this damn weather!
Old Dec 5, 2011 | 02:12 AM
I wish i had the time to do floor pans on my blue car but was strapped for time. This was part of the un-expected joys i ran into when i got my blue iroc.
what a **** show that was rebuilding the foot rest at the top left. And it was all shot together with flux wire. Oh yeah and all the rust intrusion was cuz of that high beam switch at the right near the trans tunnel.
last one was the after, new seam sealer on everything, primed it and dropped some insulation down.
Old Dec 5, 2011 | 08:49 AM
Car: 87 Iroc
Pretty sweet outcome. I'm (unfortunately) going ***** out with this theres nothing at all in it. But once I'm done it lives 100% of its life with me onthe garage so it'll be safe. I know prolly should just be getting a new shell, but it's the classic sob story, bought at 16 drive it to prom and graduation... It goes on so nonetheless it getting fixed -_-
Old Dec 6, 2011 | 01:56 PM
I hear that dude. Same story with my black iroc. I think alot of owners ran/or will run into the same boat your in right now. Had it since i was 16. Bla bla bla. Did the typical **** of making it too fast, now all i want is to have it back to stock, no problems, NO HEADACHES, enjoy it for what it was when i first got it. But of course after letting it sit to long, the por 15 backfired when my t tops sprang a leak, now the floor boards on that car are fubar, and i dont wanna put sheet metal back there. I was thinking when i gather enough enough courage. Im gonna be following this thread like a hawk.
Old Dec 6, 2011 | 02:33 PM
Car: 87 Iroc
We're u from man?
Old Dec 7, 2011 | 02:49 PM
Pm-ed
Old Dec 9, 2011 | 09:41 AM
Fearless1's Avatar
Car: 1989 RS Camaro
Engine: undecided lol i have options
Transmission: 700R4 for now....
Axle/Gears: open 10 bolt, ratio?
Gutting the interior on my '89 RS this sunday to scope out the floors. Just bought the car and somebody was in there putting in ghetto patch panels. They "beer can" like crazy on the passenger side lol.
Old Dec 9, 2011 | 01:40 PM
Car: 87 Iroc
Can't wait to here the update in that. Rust on these cars is so common it's sad
Old Dec 11, 2011 | 12:11 PM
Post up some pics when you get it apart fearless1. Every little bit helps out somone.
Old Jan 6, 2012 | 07:20 PM
jamieschott's Avatar
Watching this. Gonna replace pan when I get back from Korea.
Old Jan 6, 2012 | 08:30 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Man, what a job. Ya' gotta really love 3rd gens to do this much work. Hope it all works out for you. Keep us posted.
Old Jan 6, 2012 | 10:07 PM
Car: 87 Iroc
I got the front end completely done I'll post pics later this weekend, got the whole harness out and am going through it thoroughly (it's a nightmare) floors hopefully this week, and ya I got a love for bowties and I love these cars, camaros in general. Im 19 and have had almost 11 3rd and fourth gens lol
Old Jan 7, 2012 | 05:32 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Wow, 11 already? I've owned one for 26 years.
Old Jan 7, 2012 | 10:40 PM
Car: 87 Iroc
The one I'm restoring was my first car I bought. That ones not going anywhere
Old Jan 16, 2012 | 09:55 PM
  #42
Car: 87 Iroc
NEW UPDATE! started hacking apart the donor floorpan i got. Then it goes in! ill post pics tommorow!
Old Feb 2, 2012 | 08:35 AM
  #43
Car: 87 Iroc
Old Feb 2, 2012 | 08:37 AM
  #44
Car: 87 Iroc
Size:  149.7 KB all tacked up!
Old Feb 2, 2012 | 08:38 AM
  #45
Car: 87 Iroc
Old Feb 2, 2012 | 08:39 AM
  #46
Car: 87 Iroc
All welded up! frnt passenger is done! the seat lines up perfect and all the body lines are good. good start
Old Feb 3, 2012 | 04:10 PM
  #47
madhatter's Avatar
Nice work man, I really should have done mine when I had my car all chopped up. Now I have the cage in the car making it that much worse to do.
Old Mar 24, 2012 | 12:01 AM
  #48
Car: 87 Iroc
sorry about not posting! been busy though!
  #49
Car: 87 Iroc
the rust on the drivers side was the worst!
Old Mar 24, 2012 | 12:02 AM
  #50
Car: 87 Iroc
i chassis save under were i air hammered and chisseled what was left of the old floor out.
the replacement pan chassis saved
