Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Iroc hood on formula without pop up head lights
Old Nov 29, 2011 | 09:35 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
I have put new headlights on my firebird that dont raise, so i was wondering could i use a iroc hood to cover the holes that the head lights were in?
Old Nov 29, 2011 | 10:04 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Iroc hood on formula without pop up head lights
Nope. Camaro hoods are relatively flat vs the the curve of the sloped nose of Firebirds.
Old Nov 29, 2011 | 03:30 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
ditto; front of the firewall, almost every curve and angle is different from bird to camaro
Old Nov 29, 2011 | 08:29 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Ok thank you! i will have to figure somethin new then
Old Nov 29, 2011 | 09:09 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
if you had two hoods to sacrifice you could more than likey take apart the two halves and weld the camaro top to the bird base so that it contours too it. not sure if that will work but something to look into if your minds set on doing this
Old Dec 3, 2011 | 09:37 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I saw a nice harwood cowl hood for a camaro at a junkyard, but someone cut squares from the front corners and installed it on a bird, it was painfully obvious that it was the wrong hood, the contours were all wrong. Just tossing that out there.
Old Dec 8, 2011 | 12:21 AM
Patrick Day's Avatar
I do remeber seeing that someone made a fiberglass hood with out the head light area being cut out but VFN's web site isn't coming up any more.
Ever think about welding some metal in the place of the pop up head light area.
Do you have pics of what you have ? maybe some people here can come up with something for you
Frozer!!!
Jan 19, 2024 04:55 PM
Randomtask2
Aug 13, 2015 01:57 AM
mustangman65_79
Aug 12, 2015 06:39 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Omega
Aug 10, 2015 12:46 PM
