Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Viper Powered 85 Z28
Old Jan 27, 2012 | 09:46 AM
  #101
Cray z28's Avatar
Car: 1985 Z28
Engine: 8.3 ltre viper
Transmission: Tremec T6060
Re: Viper Powered 85 Z28
Where did you get a gen 1 for 1000 lbs? You can get the trans ecu and everything else you need from xvipers.
Old Jan 27, 2012 | 09:52 AM
  #102
shone190's Avatar
I bought the engine for 1000 euros, that is about 1300$
Engine is from one and only first gen Viper in Serbia which is crashed about 10-12 years ago.
Old Jan 27, 2012 | 10:21 AM
  #103
mh82camaro's Avatar
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
yeah you two guys have definately got to get this done....to prove to everyone who says it cant be done or finished that is can. it will be truely awesome when its done...more pics...when you get them.
Old Jan 27, 2012 | 11:01 AM
  #104
shone190's Avatar
Great site, thank You
Old Jan 27, 2012 | 11:19 AM
  #105
jchaussee's Avatar
Car: 85 Z28
Engine: 327
1300 is so cheap.
Old Jan 27, 2012 | 11:24 AM
  #106
shone190's Avatar
I know, that's why I bought it. I had plans to build up L98 or to put LS1 but when I found this engine, I had to buy it for this price So now plans are changed and I have to find some informations about this engine, ECU, transmission and electrics to find out how to put this in my GTA.
Tonight I will open new thread about my project, still this is Cray z28's thread
Old Jan 29, 2012 | 05:25 PM
  #107
Cray z28's Avatar
Car: 1985 Z28
Hey shone keep me posted. We can accomplish this helping each other with the issues we find. I also found a site called x2vipers. LOTS of parts. I wont have my Z back for a few weeks while the rear quarter gets realligned.
Old Jan 30, 2012 | 11:29 AM
  #108
shone190's Avatar
Deal
Do You mean x2builders?
http://www.x2builders.com/
I'm going tomorrow night to pick up the engine and see what exactly engine has on itself
Old Jan 30, 2012 | 11:58 AM
  #109
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Holy smokes. Those guys are parting out 10 GTs. I figured those would be cars to fix.
Old Jan 30, 2012 | 04:13 PM
  #110
Cray z28's Avatar
Car: 1985 Z28
Yeah Shone its x2builders. I just got my mock block today and UPS broke a 6" chunk where the bell housing bolts on the right side. Then I pull the heads out and the right one has a 3" break at the rear. PISSED. I also found out that the Zinik Z28 wheels I want don't come in 10-13" widths. So the hunt begins for a new wheel. I am thinking of the 2012 Corvette ZR1 wheels.
Old Jan 30, 2012 | 05:54 PM
  #111
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
.....I also found out that the Zinik Z28 wheels I want don't come in 10-13" widths......
Simple....Send them off to be widened. That is how my 9" wide wheels became 11"s. 9" is the widest they are offered.
Old Jan 30, 2012 | 08:59 PM
  #112
mh82camaro's Avatar
hey, where exactally do you send them...do you have a name,number or web address...because i was wanting to do that with my rims as well...i honestly didn't know you can do that
Old Jan 30, 2012 | 09:43 PM
  #113
Car: GTA
http://www.wheelsamerica.com/index.php?page=main is where I sent mine to. I used the Dallas location since it is the closest to me. I hae mine powdercoated too while they were there. I just used a colored pencil to label where I wanted it black & what was to be polished. So mine went off as bare, 9" wide & back back as black powdercoat (spokes & the inner loop that you could see by looking between the spokes) w/polished lip.
Old Jan 31, 2012 | 07:57 AM
  #114
Cray z28's Avatar
Car: 1985 Z28
That is awesome. That is exactly what I am going to do. Thanks.
Old Feb 1, 2012 | 12:06 AM
  #115
mh82camaro's Avatar
blackenedbird.....thanks i will check into it...they look good
Old Feb 1, 2012 | 12:36 AM
  #116
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Originally Posted by shone190
No I don't, I accidentally bought this engine a few days ago for 1000€ , so first I need to see how to purchase transmission, engine harness and ECU.
LOL, I'd like to "accidentally" purchase a Viper engine...
Old Feb 1, 2012 | 12:49 AM
  #117
shone190's Avatar
@Cray z28
What will you do regarding these damages?
@Six_Shooter
I had plans for LS1, but this was so cheap that I couldn't miss it
Old Feb 1, 2012 | 08:38 PM
  #118
Cray z28's Avatar
Car: 1985 Z28
shone.. what damages?
I cant do my zinik z28 rims because the profile goes to the outside of the outer lip. I think you can only widen rims with profiles that sit on the ID of the rim. Correct me if im wrong please.
Old Feb 1, 2012 | 08:42 PM
  #119
Car: GTA
Huh???
Considering where the rims are cut at for widening, I don't see much of anything stopping a rim from being widened.
Old Feb 1, 2012 | 08:58 PM
  #120
Car: GTA
Here is a pic that shows the weld seam.
Old Feb 1, 2012 | 09:02 PM
  #121
Cray z28's Avatar
Car: 1985 Z28
it would leave me with a 10 inch back spacing.
Old Feb 1, 2012 | 09:19 PM
  #122
Car: GTA
I have 7"bs & cut out the bumpstop & 1 layer. 10"bs would pretty much require a mini-tub, so that amount of work is up to you. Wheels America says they only do the widening to the inside & I am sure that is basically because the seam would be visible & "ugly".
Old Feb 1, 2012 | 09:41 PM
  #123
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
U mean stick out like mine do??
not the best picture but it still shows.... It is illegal but it all depends on the strictness of the law in your area... if there are a lot of jacked up trucks on the road with mud tires on... I'd say go to it... Keep a set of spare wheels/tires kicking around for backups just in case. I've had these tires on my car for 10 years now and I've been stopped by the cops for un-necessary noise in city limits, among some other minor infractions and the cops have almost always mentioned the tires being a bit wide but they dont do anything or tell me to get them replaced.. I've actually had a lot more people compliment the way the car looks than compliment how illegal it is.. Hell I have 2 cops in the Local Camaro club I got started that absolutely love the look haha.
Old Feb 1, 2012 | 09:43 PM
  #124
Car: 1986 Camaro
and.... I think I totally misread your comment..... hahaha
Old Feb 2, 2012 | 03:56 AM
  #125
shone190's Avatar
That's what You mentioned e few posts above.
Old Feb 2, 2012 | 12:23 PM
  #126
Cray z28's Avatar
Car: 1985 Z28
Oh Shone, gotcha. I have to screw and epoxy the busted pieces. Here in Taxachusetts, you can't have the wheel hanging out the well. I am mini tubbing for the 13" wide meats.
Old Feb 4, 2012 | 02:30 PM
  #127
Cray z28's Avatar
Car: 1985 Z28
Hey every body. What do you think of these. 335/25/20 out back and 285/30/19 up front. Plus I ordered the chrome molly 10pt cage.
Old Feb 4, 2012 | 07:04 PM
  #128
mh82camaro's Avatar
.......NASTY......lol....in a good way...i like them
Old Feb 6, 2012 | 10:20 AM
  #129
h1-vltg's Avatar
Car: 91 Camaro Z28
Engine: LS3
Transmission: 6 Speed
Axle/Gears: 3.71
I like the look of the wheels, but I wonder if 20's in the back will look too big. But the width at 335 will be just plain AWESOME!
Old Feb 6, 2012 | 08:45 PM
  #130
Cray z28's Avatar
Car: 1985 Z28
O.K. guys. I had the Z kicked out of the stretch shop(peacefully) for the owners daughters ride. Thus I brought the Z back to the shop, pulled the motor and set the Viper block in place. I am uploading the pics in a minute.
Old Feb 6, 2012 | 08:57 PM
  #131
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
ick, not my cup of tea.
Old Feb 6, 2012 | 09:26 PM
  #132
Cray z28's Avatar
Car: 1985 Z28
Here is the block with enough room for headers.
Attached Thumbnails Viper Powered 85 Z28-image02062012165756.jpg   Viper Powered 85 Z28-image02062012165812.jpg
Old Feb 6, 2012 | 09:28 PM
  #133
Cray z28's Avatar
Car: 1985 Z28
sorry about the blurry photo. The block in the engine cradle.
Old Feb 6, 2012 | 09:30 PM
  #134
Cray z28's Avatar
Car: 1985 Z28
Image of the clearance to the stock radiator brace.
Attached Thumbnails Viper Powered 85 Z28-image02062012165931.jpg   Viper Powered 85 Z28-image02062012165921.jpg
Old Feb 6, 2012 | 09:31 PM
  #135
Cray z28's Avatar
Car: 1985 Z28
Finally a look through the radiator housing.
Old Feb 7, 2012 | 07:51 AM
  #136
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Is that a 'Viper' v-10 or a truck v-10? I thought Viper v-10's were aluminum headed. I know the(non-srt) trucks arnt.
Old Feb 7, 2012 | 07:57 AM
  #137
92 BBC Z's Avatar
Sorry, I see it is a mock-up block, I must of missed it.
Old Feb 12, 2012 | 09:33 AM
  #138
weberflorida's Avatar
Car: 1991 Camaro Z28
I can't wait to see the finished product. Subscribed. Please update with more pictures
Old Feb 12, 2012 | 11:41 AM
  #139
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Your in Mass? What town? I have to see this car!
Old Feb 15, 2012 | 08:59 PM
  #140
Cray z28's Avatar
Car: 1985 Z28
I got the rims and tires done today. Got the rims for $500 and the rubber for 2K. I got the rims and tires first because I want to do the FAB based on the tire size and stance I want. IrocZ30589 I am in Westfield,MA.
Old Feb 21, 2012 | 02:06 AM
  #141
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
you should be fine. My 521 Big block ford in my 87 formula 350 is alil bigger than that V10. Took some work but i made my own headers and a bunch of other stuff and it dropped right in lol.
Its hard to see how wide this thing really is but its massive. the valve cover is .250" away from the top left of the brake booster lol.
good luck with the swap! Its always better to be different!
Attached Thumbnails Viper Powered 85 Z28-2011-07-14_19-48
Old Feb 22, 2012 | 10:05 AM
  #142
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
i'm in!
Old Feb 29, 2012 | 09:41 AM
  #143
shone190's Avatar
Hi Cray,
what about motor/engine mounts?
Did You use original V8 mounts or Viper mounts and do You have some pictures of modifications?
Old Mar 2, 2012 | 01:02 AM
  #144
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
sub'd, maybe now i'll get updates
Old Mar 2, 2012 | 01:41 AM
  #145
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
i almost did this once when i was going to school at UTI in az i had the motor out of a 98 viper i picked up for $4000 but i couldnt aafford it so had to sell it before it even got close to being done
Old Mar 2, 2012 | 09:00 AM
  #146
Cray z28's Avatar
Car: 1985 Z28
Sorry guys. I have been wrapped up at work for a little bit. Then I had a great vacation in N.C. I have a friend that works at Majestic Motorsports. Sick,sick,sick, turbo powered cars. I am back and I will get back on the project. Shone I just set the mock in there to check for clearance. I will be using stock Viper mounts on a 4x2 frame.
Old Mar 2, 2012 | 09:03 AM
  #147
shone190's Avatar
I suppose You need to cut and modify something to put Viper engine with Viper mounts?
Old Mar 3, 2012 | 01:46 AM
  #148
68Strat's Avatar
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
Incredible... Anyone who flames someone for putting a v10 in one of our cars, has absolutely no right to be posting in this thread, because they obviously can't appreciate interesting fabrication. On the other hand, I would definitely laugh if someone made a third gen 4 cyl/front wheel drive conversion thread
Old Mar 3, 2012 | 11:18 AM
  #149
Cray z28's Avatar
Car: 1985 Z28
No prob guys. I don't sweat the haters and doubters. I am sure shone doesn't either. All I have to say is that when the builds are done the haters and doubters will be lining up for a chance to look and ride.
Old Mar 3, 2012 | 11:24 AM
  #150
shone190's Avatar
Just like that
