Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Viper Powered 85 Z28
Old Jan 2, 2012 | 06:57 PM
Cray z28's Avatar
Car: 1985 Z28
Engine: 8.3 ltre viper
Transmission: Tremec T6060
Hello everybody,
I just started my first major project of putting a Gen 4 Viper Motor in an 85Z28. Yeah Yeah haters I know but if it wasn't for people who thought out of the box then you wouldn't have cars like the Cobra, Tiger Sunbeam, Superbird...... and many more. So for the Chevy fans I am trying to make it as stock looking as possible with a few minor exceptions. The interior is going to be very modern as well as the drivetrain and suspension. I just started the tear down and will post as soon as I start the first build-up. Unless you guys want to see the deconstruction. The first problem I encountered was a rear end hit some time ago. Very Very bad repair.
Old Jan 2, 2012 | 07:19 PM
gp90gta's Avatar
Car: 1990 GTA
Re: Viper Powered 85 Z28
I'm always intrested in a different twist on Third gen, so please post those pic's when you get them.
Old Jan 2, 2012 | 07:28 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Almost like this more than a LSx swap. But that viper engine is REALLY long. You sure it will even fit? It's tight with an LS engine.
Old Jan 2, 2012 | 08:30 PM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
if this can be done its going to be bad ***
Old Jan 2, 2012 | 08:46 PM
memphis1967's Avatar
Car: '84 Z28
Axle/Gears: 98 T/A 10 bolt. Auburn, 3.42
very interested in this build. You're gonna have to brace your car like crazy to handle the torque
Old Jan 2, 2012 | 09:18 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
post pics!
Old Jan 2, 2012 | 09:19 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
sounds awesome!
Old Jan 2, 2012 | 09:30 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
This sounds almost as crazy as my idea to create a modern version of the second gen firebird engineering special called the Pegasus. They put a Ferrari V-12 in a 71 Firebird. I was gonna stuff a Ferrari 550 Maranello V12 and trans into a third gen. Those who didn't scream crack pipe said it would be awesome, but its not happening without serious engineering and modifications. Same could be said for the viper motor. Best of luck, hope you do pull this off somehow. For all I know I might come across a wrecked Ferrari and somehow pull off my own idea. And if you ever do make progress, I'm with the others. Pics!
Old Jan 2, 2012 | 09:41 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
Saw a Datsun Z with a viper motor in it. They had to cut the center out of the firewall and move it back 6" but if it can fit in that i'm sure it will fit in a 3rd gen.
Old Jan 2, 2012 | 09:58 PM
82z28 wrencher's Avatar
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
i got a grinder and a welder we'll make it fit lol
Old Jan 2, 2012 | 10:06 PM
90_383's Avatar
Car: 87 vert
Engine: 355
Transmission: wc t5
Axle/Gears: 4th gen 373 posi
I cant wait to see this go down
Old Jan 2, 2012 | 10:14 PM
mh82camaro's Avatar
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
i like different ...nothing wrong with that bud...good luck canpt wait to see it
Old Jan 3, 2012 | 08:30 AM
Cray z28's Avatar
Car: 1985 Z28
The engine will fit, I did some research and front to rear is 34.5", 23" across the valve covers and 26" pan to intake. The torque wont be a problem with the full frame and cage welded to frame. Thanks for the interest. I will post pics soon. Also I came across a ferrari engine in a late model mustang. The cool part was they kept it mid engine.
Old Jan 3, 2012 | 09:21 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yep, it should fit, I thought I seen something like this done before but cant recall. I know they put a Lt5 motor ina thirdgen...that was pretty awesome.
Only problem I see, is will the exhaust manifolds allow for exhaust to go down in the factory thirdgen location? May need to fab a set of headers for it.
Else a tubular K-member could help free up some room and give more mounting options with the motor.
Old Jan 3, 2012 | 11:24 AM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
There will be no haters if the project gets completed.
Old Jan 5, 2012 | 07:54 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
This sounds Like it could potentially be pretty cool. Do you already have the drivetrain?
Old Jan 5, 2012 | 08:38 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
in for updates! should be a sweet swap. no haters on something this crazy
Old Jan 5, 2012 | 11:39 PM
85Irocket's Avatar
Car: 85 Iroc
Engine: Don't have one yet.
Transmission: T-5 non wc
Axle/Gears: Disc brake 10 bolt with 373 gears
I'm in also.
Old Jan 5, 2012 | 11:59 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Count me in.
Old Jan 6, 2012 | 04:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Pics or its not happening....
Old Jan 6, 2012 | 06:45 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
You building some sort of tube chassis for this?
Old Jan 6, 2012 | 07:49 PM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Subscribed. Pics!
Old Jan 6, 2012 | 08:09 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I wanna see it, too!
Old Jan 6, 2012 | 09:27 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Checkin in...
Old Jan 6, 2012 | 09:54 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
They did that mostly for oil pan fitment reasons, something about how the oiling system, or crank clearance from the oil pan. They made a custom crossmember to push it as far forward as possible.
If it wasn't for my insurance, there would be a second Viper powered Datsun S30.
Old Jan 9, 2012 | 09:00 AM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
"My uncle is a TV repair man.. he's got a master set of tools. He can fix it."
Six_Shooter- when did you become a mod over here? Yes.. this is the same "metalhead" from v6z24.
Dan
Old Jan 9, 2012 | 09:44 AM
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
I'm interest to see this (hope it happens)
WE WANT PICS
Old Jan 9, 2012 | 11:07 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Been done before, so yeah it "fits"
Old Jan 9, 2012 | 01:49 PM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
In for pics!
Old Jan 9, 2012 | 02:28 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Signing onto the thread.
Old Jan 9, 2012 | 09:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Old Jan 9, 2012 | 10:11 PM
L695speed's Avatar
Commence Evil laughter--> On a side note, please tell me those vipers in the background are not done for.
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
im in!!!!
Old Jan 9, 2012 | 10:20 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
I'm in. This is going to be one bad-*** ****!
Old Jan 10, 2012 | 12:24 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
That pic was of the only thirdgen known to go thru the v10 viper swap. Never seen it finished or heard anything about it since. I believe this was done in 2003
Old Jan 10, 2012 | 12:48 AM
Alwaysboosted's Avatar
Car: Turbo Z31, RX7, and 2 F-bodies
Engine: 1.LS1, 2. L98
Transmission: 1.4L60E, 2. 700r4
Axle/Gears: 1. 3.23, 2. Unknown
Count me in! Subscribed.
Old Jan 10, 2012 | 12:03 PM
86_sportcoupe's Avatar
Car: 86 Camaro Sport Coupe
Axle/Gears: stock
This will be sweet if it gets done. Best of luck to you.
Old Jan 10, 2012 | 12:07 PM
Twin_Turbo's Avatar
Looking forward to seeing this
Old Jan 10, 2012 | 12:28 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
The real question is though.....
Was it ever actually done/really tried? Or was it one of those "What if?" moments in the shop?
Old Jan 10, 2012 | 12:52 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Not sure. I have searched on this forum for the threads but the only one that had a pic was short and never updated. I found a link to the supposive build on Viper Club of America forums, but the link was old and didnt work. I went to VCOA forums and searched but found nothing so not sure what happened to this project.
Old Jan 11, 2012 | 02:10 PM
Cray z28's Avatar
Car: 1985 Z28
I have some starter pics showing that this is going to happen and it is not just an idea. Of course the beast will have a full cage-to-frame. Other mods are:
one piece fiberglass electric ram flip nose
butterfly flip fiberglass doors w/power windows
I am designing shock hinges for the rear glass(I hate the long arm gas shocks)
complete custom interior(obviously)
independent rear suspension
Z 06 front suspension
shaved doors
Fisk electronics(no keys for this beast)
also glassing a gen 4 viper hood into the camaro hood
zinik z-28 rims rears 18 fronts 17
flushing all the ground effects to the panels so its seamless
Thats the start of it and we shall see what I come up with later.
Attached Thumbnails Viper Powered 85 Z28-camaro-build-043.jpg   Viper Powered 85 Z28-camaro-build-040.jpg   Viper Powered 85 Z28-camaro-build-042.jpg
Old Jan 11, 2012 | 02:57 PM
  #42
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Dare to be different is always good. This should be a neat project.
Old Jan 11, 2012 | 04:00 PM
  #43
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
im in. cant wait for it to be a finished deal
Old Jan 11, 2012 | 06:39 PM
  #44
Cray z28's Avatar
Car: 1985 Z28
Wow everybody. I really appreciate the support. I am not a wealthy man, just determined to do what no one has done before. I don't think that other 2003 addition was completed. I am also contemplating twin turbos. I figure why the hell not!!!
Old Jan 11, 2012 | 08:14 PM
  #45
Car: '84 Z28
Twin turbo vipers aren't horribly uncommon, I know Hennessey has done a couple. Ever heard of Sir Hiss? Dodge Viper with a blown big block chevy. You're not breaking entirely new ground, but it's the first viper powered camaro that I've heard proposed. Good luck!
Old Jan 12, 2012 | 08:16 AM
  #46
Cray z28's Avatar
Car: 1985 Z28
Well I know I am not breaking new ground on engine swaps. Of course I know all about the twin turbo Vipers. I am talking about a twin turbo viper powered camaro. Thats the new ground.
Old Jan 12, 2012 | 08:30 AM
  #47
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Heck if you needed to fab new headers to fit the car anyway...might as well make some log manifolds for turbos! I like where your head is at.
Old Jan 12, 2012 | 08:57 AM
  #48
Car: '84 Z28
Wasn't trying to downplay your project, i just meant that you're not starting from scratch, you have shoulders to stand on to reach new heights.
Old Jan 12, 2012 | 10:30 AM
  #49
Cray z28's Avatar
Car: 1985 Z28
My Bad!! I hear yah.
Old Jan 12, 2012 | 10:41 AM
  #50
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Its been quite a few years back, but there was one guy on the board that did the swap. It was a yellow camaro and he posted pics of the finished product. If I remember correctly, he caught a lot of flack for it.
Here are a few posts, but some of the links are dead. I did find one pic.
https://www.thirdgen.org/forums/auto...red-89-rs.html
https://www.thirdgen.org/forums/atta...e-fit-v-10.jpg
Maybe Zepher saved some pics from the link.
