Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Structural question
Old Feb 3, 2012 | 08:25 AM
Kip Latshaw's Avatar
Structural question
I am not a structural Engineer but after looking at some of the Photo’s of Sub frame connectors I was wondering if you just wanted to strengthen the under carriage if you stitch welded, Say 2 OD x .120 wall x 1.760 ID tubing along the inner rockers would that help any with flex I like how the Spohn sub frames get welded… Like the UMI for tie in, But the UMI look to far from the rocker for Stitch welding.
Any Thoughts?
Old Feb 3, 2012 | 04:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Structural question
1.75 OD fits better. Go ahead and make your own, make the best of both worlds
Old Feb 23, 2012 | 12:57 PM
jwdomino's Avatar
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
I dont have any pics but I did very similay to what you are saying. I stitched in 1/2"x1.5" rectangle tube front to rear along the entirelength of my rockers (except for the several inches in the passenger side where the exhaust routes), and there I did a piece of 5/16"x1.5" plate in place of the tube.
Very rigid, I can jack the car now and no matter where I start front or back and both the front and rear wheels come up at close to the same time.
Makes for a handy jacking point too. Havent tied into the lca mounts in the back yet and I am not sure I need to. Car is very rigid
Old Feb 23, 2012 | 03:48 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Global West connectors may be the ticket to ride for you - check them out...
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
