Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Floor starting to rust
Old Feb 8, 2012 | 10:36 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so I notice when I was under the car that rust building up under my feet I can push up on the floor pan an can see the sheet metal move up an down is it possible to cut one section of the floor out an get a new piece of the same shape an weld it into the existing floor then touch it up with rust prevention paint
Old Feb 8, 2012 | 11:02 PM
87ohcamaro's Avatar
Car: 87 Camaro
Re: Floor starting to rust
Yes, it is very possible and that is how most of us have done it. rather than buying an entire floor pan, I just patched mine with some spare sheetmetal I had lying around. A new replacement floorpan, would be the best option if you were looking to restore, but some sheetmetal patches or a piece cut of a donor car will work just as good.
Old Feb 9, 2012 | 07:43 AM
Engine: LR4 4.8
See thats the thing a entire floor pan cost 300 bucks crazy for sheet metal if u tell me but I have asheet metal shop right down the street of me that could cut out a piece the exact same shape, the rest of the drivers floor is solid It's just that one area right under my feet
Old Feb 9, 2012 | 08:16 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Cut it out weld some steel in place and coat with rust bullet or POR15
Old Feb 9, 2012 | 10:36 AM
Engine: LR4 4.8
No jig would have to be made or anything like that it's a hardtop Gta so don't have to worry about to much flex
Old Feb 9, 2012 | 09:33 PM
87ohcamaro's Avatar
Car: 87 Camaro
Nope, no jig needed. Just cut it to fit and weld her in.
Old Feb 9, 2012 | 10:24 PM
Engine: LR4 4.8
Now this is what I like to hear glad that it ain't that gonna be a hard job looks like I gotta start learning how to weld lol should I use a mig welder to do it or does if have to be arc, or spot welded
Old Feb 10, 2012 | 12:09 PM
85Irocket's Avatar
Car: 85 Iroc
Engine: Don't have one yet.
Transmission: T-5 non wc
Axle/Gears: Disc brake 10 bolt with 373 gears
mig would be best
Old Feb 10, 2012 | 08:40 PM
Engine: LR4 4.8
Cool I'll ask my buddy to come over an mig weld it in for me
Orr89RocZ
Apr 25, 2016 08:28 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
