Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
removing a/c and air pump
Old Mar 24, 2012 | 01:19 PM
kimberanton's Avatar
Car: 89 IROC-Z28 Camaro
Engine: 350 TPI IROC
I want to remove them both but don't know what to do with the pulleys. Any ideas?
Old Mar 24, 2012 | 03:05 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: removing a/c and air pump
You can buy delete pullies for both.
Old Mar 25, 2012 | 10:44 AM
Do you know where i can buy them?
Old Mar 25, 2012 | 07:30 PM
Mounty Man's Avatar
Car: 1989 Camaro Iroc-z
I ended up buying mine from summit but I am sure jegs or ebay has them too. I only bought the one for the a/c and then re-routed the pulley like shown here https://www.thirdgen.org/serpentine
Old Mar 25, 2012 | 08:03 PM
Awesome man, thanks.
Old Mar 26, 2012 | 09:00 AM
what do i do with the vacuum line that runs into the smog box after i remove it and the connectors that plug into it also??? do i keep the egr valve solenoid or tke it off to?
Old Mar 28, 2012 | 09:13 AM
b_the_j's Avatar
Car: 92 RS
I ended up creating a setup that uses no delete pulleys... i moved the altenator to a/c compressors old location drilled a new index hole for tensioner spring and used a belt that was a foot shorter....i did this about 8 years ago and have since lost all pictures sorry
Old Mar 28, 2012 | 09:18 AM
b_the_j's Avatar
Car: 92 RS
btw you want to keep your egr if you enjoy fuel economy.....it is always closed at full throttle and has no effect on total performance
Old Mar 28, 2012 | 11:07 AM
what about the harnesses that plug into the smog pump tubes?
Old Mar 28, 2012 | 10:07 PM
b_the_j's Avatar
Car: 92 RS
I leave stuff like that in place...its always handy to have wires hanging around that can be reassigned purpose... specially ones that travel through the firewall
Old Mar 28, 2012 | 10:08 PM
b_the_j's Avatar
Car: 92 RS
Took a couple pics today will post em tommorow if I have time
Old Apr 8, 2012 | 10:23 AM
blackjack12982's Avatar
Post the pictures, please?
I'm going to be deleting AC and AIR next to clean up the engine bay. I'm always up for new ideas.
Old Apr 8, 2012 | 03:29 PM
i would like to see the pics too. im in the process of removing them both too. thanks
Old Apr 9, 2012 | 08:28 AM
b_the_j's Avatar
Car: 92 RS
i put them on facebook
http://www.facebook.com/profile.php?id=100003374703201
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
mcquigg
Aug 13, 2015 02:26 PM
3rdgenparts
Aug 8, 2015 07:09 PM
